Results 1 to 7 of 7
    May 29 2013
    Jacksonville Fl
    Getting my brakes worked on. They want to rebuild my calipers?
    So they say that my calipers are over heating the pads a causing the rotor to warp! Now I'm not a mechanical engineer
    But I would think that rebuilding them would fix the rotors.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Well, the piston could be seized. Rebuilding a front caliper consists of one seal and one dust boot, and maybe a couple slider pins if they don't just clean up the ones that are in there.
    If the rotors are warped, they are warped. Time for new ones.
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    May 29 2013
    Jacksonville Fl
    Yeah I just told them I want new pads and rotors. The calipers are fine.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Are you sure the calipers are fine?
    2000 S4- Working?
    Jun 30 2008
    Erie, Pennsylvania
    Yeah, you probably need new rotors and pads.
    But those new pads and rotors are going to be junk in a month if you don't fix the actual problem. The shop is telling you the problem is that the calipers are sticking on. And they may not even be able to install new pads/rotors due to the inability to compress the caliper.
    Common Failure mode:
    - Dust boot fails
    - Rust happens to piston surface
    - Rust on piston surface prevents piston from retracting properly
    - Failure to retract makes brakes "stick on" slightly all the time
    - Pad and rotor life are shortened dramatically. Rotors may warp.
    - Cannot compress piston manually due to rust issue
    Fix:
    - Almost universally people replace calipers with a reman unit.
    - Persons who are measurably more awesome will rebuild the caliper with new seal and dust boot, so long as the rust on the piston is minor.
    - Rebuild is half the cost or less of a new caliper, but requires more labor time. If you are paying for labor, a reman caliper is usually a better choice.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    I don't think most realize how easy and cheap it is to rebuild your own calipers. Parts are less than $10 on rock auto and it takes about 10 minutes. I did all four on that avant I bought. Very gratifying
    Rear caliper rebuilds do indeed suck though. A lot
    2000 S4- Working?
    May 29 2013
    Jacksonville Fl
    There called brakes for less I think they where just trying to up sell me. Anywho I will prolly just rebuild them myself if it would stop raining and warm up here in Florida.
