Page 1 of 3 123 LastLast
Results 1 to 40 of 118
    Apr 26 2004
    Raleigh
    Rear suspension noise?
    I noticed the past few days that I am hearing a faint clunk or knock coming from the rear of the car when going over small bumps or uneven pavement. It is most noticeable at low speed and I don't hear it all the time. I don't think I have heard this before and while it isn't dramatic it is a bit annoying. Almost sounds like a loose suspension part. Has anyone heard anything like this before? Any clue what it could be?
    I did just have the wheels off of of the car to get Opticoat put on them but I wouldn't think that could cause any sort of issues.
    Thanks in advance!
    13 S6
    01 S4 (Gone)
    Veteran Member Four Rings HyperM3's Avatar
    Mar 20 2004
    Lawrenceville, NJ
    Check the torque on the lug nuts just to rule that out. Sometimes not all places tighten them properly.
    21 S5 Coupe - RacingLine strut brace/034RearSwayBar/CTSTransMount/034 tune/VPS Res Delete/CTSIntake
    10 S4 (gone),13 S6 (gone),14 S6 (gone),14 S6 (gone),16 S6 (gone),17 A4 (gone),19 S4 (gone)
    20 BMW R1250RS
    ACNA Lifetime Member - 26690
    Respond to a post with an answer, they will keep asking questions. Teach them how to RTFM, they will learn to help others.
    Senior Member Two Rings Eugeinus's Avatar
    Mar 12 2013
    NOVA
    Maybe it's a bad bushing?
    Mar 28 2014
    The Big Apple
    Quote Originally Posted by nobodeuno View Post
    Thanks in advance!
    Same here. Appears to be coming from right rear. Will have to bring to dealer to get it looked at.
    Veteran Member Four Rings kiku's Avatar
    Jul 11 2013
    2001 Audi S4
    Pittsburgh, PA
    A7 platform? If so, check the rear deck. The two tongues which go into the hatchback make noise of the rubber sleeves are not in them. My rs7 makes this noise.
    2008 997.1 GT3
    2015 Allroad
    2014 Ram 3500 Dually (the double wide)
    2014 Phantom Black RS7 w/ APR Stage 1 Tune (sold - farewall fast rs)
    2001 B5 S4 (the track slut)
    2013 Q7 S-Line (sold)
    Veteran Member Four Rings MileMan402's Avatar
    Mar 14 2012
    PHL | BOS | SEA
    I notice something similar but on multiple corners. I've chocked it up to just typical to the AAS.
    2014 S6 - SOLD
    2016 Focus RS - SOLD
    2012 Wrangler Unlimited
    Apr 26 2004
    Raleigh
    Yes I agree right rear. Going to check the lugs but I used a torque wrench myself to reinstall the wheels so they should be fine but it sounds like a bushing of some sort. Seems like that sort of thing wouldn't happen with 14k miles...
    Question when you put the car in Tire service mode via mmi...when I went back in it was disabled. So I assume it automatically disables?
    13 S6
    01 S4 (Gone)
    Sep 05 2014
    Houston, Texas
    I have had the same exact problem. Originally I believed it was from a set of ST coil-overs that were installed, so then I replaced them with a brand new set of KW V2's. The noise at all corners is slowly coming back, but the noise is most noticeable on the passenger side rear.
    I'm about to the point where I will sell this car over a rattle, I have done it before lol.
    IG: @bad646 | 2012 A6 Prestige | Brilliant Black | Titanium Grey | 21x10 RSV Forged Wheels | 255/30/21 Pirelli P Zero Tires | STaSIS 390mm BBK | Adam's Pattern Match Rear Rotors | KW V2 Coil-Overs | RocEuro Intake | RS6 Grille
    Jun 15 2013
    Wisconsin
    I have '14 S6 with 13k miles. I've noticed the same sound, seems to be coming from the passenger rear side. Its noticeable more in the cold, when I'm at slow speeds over payment bumps (like a parking garage). Very annoying.
    Veteran Member Four Rings Kevin1's Avatar
    Oct 19 2008
    Long Island
    Check the sway bar bushings
    19 years and 320,000 miles behind the wheel of an Audi
    2022 A6 55 3.0 Prestige with Luxury Package and Black Optic Sport Package (all options). Daytona Gray Pearl Effect. Sarder Brown Interior. (July 2022 - presesent)
    RIP Audis
    2015 A6 TDI Prestige All Options except B&O - (August 2014 - July 2022) (146,179 miles)
    2005 A6 4.2 Prestige All Options - (February 2005 - August 2014) (141,179 miles)
    Sep 05 2014
    Houston, Texas
    Quote Originally Posted by Kevin1 View Post
    You know this from experience? Or just making a suggestion?
    Mar 14 2012
    PHL | BOS | SEA
    Quote Originally Posted by skenn1977 View Post
    Pretty much the exact same experience for me - '14 S6 with 12k miles, more noticeable in the cold at slow speeds.
    2014 S6 - SOLD
    Sep 05 2014
    Houston, Texas
    I'm surprised there isnt more information on this. I'm gonna contact the dealer and see if they know about this
    Active Member Three Rings a4magnet's Avatar
    Dec 18 2011
    BMW M4
    Sweden
    Hi guys
    I changed my springs about a month ago on my car to get it down a bit. I went with H&R 35mm all around. Then when everything was tightened and done, I took the car for a test drive and I heard some strange sound in the rear of the car when going over bumps (for me it sounded lite some rubber noise). Went out and swayed to the rear end a little and heard from both sides that there is a "rubber sound" ... What could it be?
    About 1 week after I did wheel aligment and I told them about the noise, he couldn't locate it.. But he sprayed on some liqued on the bushings and it seems like the noise is gone for the moment..
    Veteran Member Four Rings gk1's Avatar
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by MileMan402 View Post
    Same here. '15 S6 9k miles, but noticed it earlier. As you state, more noticeable when cold at slow speeds.
    2023 e-tron GT Daytona Gray
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    2014 SQ5 Glacier White
    2012 S4 S-Tronic Monsoon, Stage II [email protected] 4275lbs
    2008 A6 3.2Q S-Line Daytona
    2007 A4 2.0T S-Line Ice Silver
    2001 S4 Nogaro Blue, Stage I [email protected] 3944lbs
    Account Terminated Four Rings
    Mar 11 2014
    Dallas/TX
    Anybody got this problem solved? Starting to hear this on my A6
    Sent from my SM-N920P using Tapatalk
    Senior Member Two Rings goliath1's Avatar
    Apr 13 2014
    custom built softail
    RI
    I hear the exact same noise...but mostly from the front. service didn't find anything...go figure. I might bring it in again since I am 4k away from end of warranty.
    Senior Member Three Rings hubris's Avatar
    Jul 07 2015
    Midwest
    Driving me nuts on my S6
    2014 S6 | Prestige | Ibis White | APR Stage 2 | Milltek Turbo-back Exhaust, Resonated, ValveSonic, High-Flow Cats | P3 Boost Gauge
    Sep 05 2014
    Houston, Texas
    This is what I've come up with on my 2012 A6. I have a rear suspension noise that sounds like both a light pop/tap on uneven roads and small bumps, and also a rubber creaking noise when taking angled parking lot entrances. I have found on other sites that there has been a TSB for the rear shock mount and confirmed this true with the dealer. I have bought brand new OEM rear shock mounts, PN 4G513353D, from what I understand have been revised from the original design. I'm hoping to change these parts out in the next few weeks, I'll report back with my results.
    Sep 05 2014
    Houston, Texas
    Quote Originally Posted by goliath1 View Post
    As for the front, I have brand new revised OEM sway bar end links. From my findings I have found these to cause suspension noises similar to what we all are having on the A6/S6, along with many other models. Audi OEM PN 8KO411317D.
    These items may be covered under warranty, however with all the modifications on my car, I've chose to chase these noises myself.
    Senior Member Three Rings carymac's Avatar
    Jan 14 2014
    2014 RS7
    Miami, FL
    I've got the same issue. When I go over bumps and the suspension flexes or when cornering. I planned on letting my tech take a look at the next service in two weeks.
    IG - @sxty3
    2016 Florett Silver SQ5
    2014 Suzuka Grey RS7 - SOLD
    Apr 26 2004
    Raleigh
    Has anyone solved this yet? I'm due for my next service and plan on asking the dealer about it. The cold weather has arrived and it has gotten substantially worse so hopefully they will hear it this time. It does sound like a swaybar bracket loose or a suspension mount or something but I don't get why it would get worse when it is cold...
    13 S6
    01 S4 (Gone)
    Mar 02 2009
    State of Confusion
    There was a TSB to replace upper rear shock mounts on A6 for noises. I had mine changed and it went away. I dont know if the air suspension in the S6 uses the same upper mounts?
    Mar 20 2004
    Lawrenceville, NJ
    Quote Originally Posted by turbonator S6 View Post
    Ok so I just started hearing this on my S6 when it got really cold. The thing is, I only hear it once each time Im backing out of the garage in the morning. Otherwise, I dont hear it again.
    20 BMW R1250RS
    Jan 14 2014
    2014 RS7
    Miami, FL
    I took my car in and the tech tightened all the bits and bolts on the suspension but I still hear the noise.
    IG - @sxty3
    Apr 26 2004
    Raleigh
    Same here...tech said he thought it was the ski shoot but pretty sure the sound went away because it got warmer. Got cold again the other morning and I heard it again. Wish I could figure this out!
    13 S6
    01 S4 (Gone)
    Jul 07 2015
    Midwest
    Audi dealer replaced the entire passenger rear strut assembly on mine, attributing the sound to that. Sound has persisted. I haven't been back to the dealer yet to continue troubleshooting. Character is identical to what is described above - most prominent when cold, heard at slow speeds over bumps and undulations.
    Oct 19 2008
    Long Island
    Quote Originally Posted by BrentAdams646 View Post
    Experience. It fixed the problem in my car.
    RIP Audis
    Apr 04 2015
    PA
    Same here^.
    Veteran Member Three Rings Unleaded20T's Avatar
    Mar 27 2008
    Ducati Streetfighter V4S
    Allen, TX
    I guess we all have the same issue, my car just turned 2k mi today and i have noticed the same noise at low speeds since it was 17 mi.
    It is definitely not the tire or the torque, the noise is coming from under the car on the right passenger side.
    [Current] 22' S6 | Daytona Gray | BO | Prestige
    [Sold] 21' S5 SB | Glacier White | BO | Prestige
    [Sold] 19' SQ5 | Ibis White | Prestige
    [Sold] 2016 A6 | Moonlight Blue | 3.0T P+
    [Sold] 2011 A6 | Black | Prestige
    "If everything seems to be under control, you are not going fast enough." - M.A.
    Apr 11 2014
    colorado
    So, I had the same slight rattle at low speed on small bumps almost like something was loose in a storage area or inside the door.Part of it was the passenger seat belt male part hitting the seat when not inserted. Inserted it does not rattle but there is still an similar sound coming from the right side of the car. My car is a 2014 rs7 and the sound started this winter at about 20k miles. Keep interrogating your dealers and someone will get the answer. I hope!
    Jun 18 2011
    markham, ontario
    I have this noise from the rear right as well, only when the temperature dips to around freezing and below. I am collecting my issues for a CPO visit :-)
    23 BMW X3 M Competition Brookyn Grey, 17 Golf 1.8 TSI Pure White
    -Traded-in-
    19 RS3 2.5T Nardo Grey, 18 Golf R DSG Indium Grey, 13 S6 4.0T DSG Phantom Black, 11 Golf 2.0TDI DSG Candy White, 11 S4 3.0T S-tronic Ibis White, 10 Q5 3.2FSI 6A Ibis White, 01 Golf GLS 1.8T 4A Black, 06 A3 2.0T DSG 6A Brilliant Black, 04 A4 1.8TQMS 6M Ocean Blue, 00 A4 1.8TQMS 5M Light Silver, 99 Golf GL 2.0 5M Candy White
    Veteran Member Four Rings VeryBadman's Avatar
    Jun 23 2012
    2017 BMW X1
    Bay Area CA
    Quote Originally Posted by kiku View Post
    Quote Originally Posted by noproblemjoe View Post
    So I'm not only one being crazy here. It seems to come from storage area like you said but I can't figure out where the noise originated. Please update once your dealers can figure out so that I can bring mine in for them to fix it. As of now I don't even know what to tell them because it doesn't really happen all the time.
    2020 ///M340i xDrive Mineral White Fully Loaded, IND Front Reflectors Delete Kit
    Remaining Parts: Neuspeed RSe102 19x9 et45 in Texas Grey
    Other: 2017 BMW X1
    Throwbacks: 2018 Audi TTRS, 2014 Audi RS7, 2013 Audi S6, 2011 Audi S4, 2008 Audi A4
    Feb 26 2011
    CA
    I have this sound as well but am at 65,000 miles. Noticeable on slower turns and at speed (vs in stop and go traffic), and from the rear left.
    2012 A6 3.0T now with APR Stage Two, Black Optics, E-Codes, and USS
    Apr 11 2014
    colorado
    Quote Originally Posted by texsun View Post
    Possible solution. Service advisor found a note about this issue with a recommendation to check the right rear bump stop. It may not be in its proper position on the shaft of the shock. A casual inspection would not indicate this and it may take a special tool to access and put it back in the correct position. I will not be in a position to get to the dealership for a few weeks so I cannot know if it is the answer. I can tell you that another place to investigate it the sway bar bushings. They can make noise and silicon grease is the answer. My viper did it so that is how I know.
    Active Member Two Rings salman90's Avatar
    Apr 04 2016
    Dubai
    Same story with my S6, here. Its only gone 3.1k miles too.
    Mind you though, it dosn't happen on tarmac, but only on cobblestone roads and the sort.
    I was afraid the right side exhausts got loose, lol.
    2016' Audi Daytona Grey S6
    Mar 11 2014
    Dallas/TX
    Are you guys talking about a faint clunk kind of noise or a proper rattle coming from the rear- at low speeds only and you just cant point out where it is coming from ( I thought the auto sunshade, door sunshades, seatbelt, central drop down cupholder, headrests..) I had both and both were fixed. The car was at the dealership for a good month since they couldn't find out where the rattle was coming from. The foreman was able to hear it clearly so he took it upon himself to fix it.
    Sent from my SAMSUNG-SM-N920A using Tapatalk
    Aug 06 2014
    NJ->CO
    Quote Originally Posted by agent47 View Post
    ...and what was the solution?
    Perf, Leather, Exec
    2015 S6 Quartz Gray
    Mar 11 2014
    Dallas/TX
    Quote Originally Posted by gk1 View Post
    I called him a few minutes ago to ask. Waiting to hear back from him. Looked through the R/O but there is no mention of how it was fixed.
    Apr 26 2004
    Raleigh
    Did you ever hear back from your tech?
    13 S6
    01 S4 (Gone)
