Results 1 to 7 of 7
    Veteran Member Three Rings bpat1017's Avatar
    Jun 29 2012
    Torrance ca usa
    B7 ac compressor not engaging and radiator fans not working
    Took my car to the dealer to get ac checked. They said single wire signal lost. That's all they could tell me.
    Manually ran voltage to a/c compressor and compressor engaged
    Econ light is NOT on
    System vacuumed and charged properly.
    CORRECTION. Radiator fans turn on properly.
    Ambient temp is always 5 to 10 degrees higher then actual temperature
    What is preventing my A/C compressor from engaging? Ambient temp sensor? Climate Control Unit? or Something else?
    Senior Member Two Rings SoCal Driver's Avatar
    Nov 28 2012
    2016 VW Tiguan S 4motion
    Oxnard, CA
    The drivers side fans runs when the coolant temp reaches temperature (don't recall the exaxt temp), the passanger fan runs when the A/C is on. If your radiator fans aren't spinning at all then it can be the fans or the fan control module (FCM), or both. you can test the fans by applying 12v direct to them, it if the fan spins then it's the FCM. If it doesn't spin then it's the fan. A faulty FCM can burn out the fans and visa versa. My B6 had a faulty FCM and it caused both my fans to fail.
    Current: 2015 Audi S4 P+ | Ibis White | Sports Diff | B&O | Carbon Inlays
    Past: 2008 A4 2.0T Quattro 6-Speed | 2004 A4 1.8T Quattro 6-Speed USP in Arctic White
    Jun 29 2012
    Torrance ca usa
    Correction!! The Fans work fine. bad fuse. Something isn't opening to send voltage to the A/C Compressor
    Quote Originally Posted by SoCal Driver View Post
    Sep 11 2009
    A4 B7 2.0T MT, A4 B5 1.8 MT
    South Africa
    Your problem seems similar to mine. How did you run voltage to the compressor? Just applied 12V at the connector? Someone suggested my problem could be the pressure switch.
    Established Member Two Rings Humble tree's Avatar
    Aug 25 2014
    Salt Lake City, UT
    Any luck? Having same issue. New FCM and fans turn on when tested with 12 volts
    Do what thou wilt
    Veteran Member Four Rings Biged243's Avatar
    Mar 27 2013
    Vr6 gti
    Metro Detroit Michigan
    Have yall checked the relay? Also what is the temp outside? Are you using auto, or forcing the ac on?
    What ever makes sense go with the opposite and you got it
    Jun 29 2012
    Torrance ca usa
    So I had audi look at the car. They serviced the system and changed out the control module. They ended up telling me the germans are complete retards. I have to come back next Saturday for them to recode the entire car. They did it for free but ran out of time due to a 2016 A7 needed to be worked on for oil problems. Can't wait to get this problem fixed. Once this problem is fixed I will be selling my audi dirt cheap. Rs4 wide body and complete rebuilt motor to handle 500hp. Need to sell asap.
