    Senior Member Two Rings S4Sumi's Avatar
    Jan 22 2008
    Black B7 S4, gsxr 600
    San Jose, CA
    Black B7 S4 Sedan 6-speed - JHM Tuned, lots of upgrades - No Longer Available
    116K miles on the car, ready to go another 100K with nothing but oil changes. Clean car fax, Engine Timing chain, stage 3 clutch/ LW flywheel, power steering pump, water pump, all hoses, gaskets, seals replaced within the last 6K miles. Have receipts for work --- major maintenance item work performed by JHM.
    Upgrades:
    RS4 Replica wheels $900
    Michelin Super sport tires/Alignment $1400(Less than 2K miles on the new tires with warranty)
    APR Exhaust $2600
    Piggy pipes, intake spacer, JHM tune $1400
    JHM LW flywheel, stage 3 clutch $1500
    Light weight crank pulley $350
    Stereo, custom box, amp, speakers, install $1600
    Kenwood double din, Navigation/Sirius, Bluetooth.
    Custom radar V1 & install $600
    APR Carbonio Intake $450
    Rear spacer and wheel studs $120
    Hotchkis rear sway bar $250
    O34 sway bar end links $155
    Ported Throttle body $200
    Cupra front lip $200
    35% Tint all around w/ lifetime warranty $350
    New Battery 11-20-14 $179
    JHM Tune
    Ported Throttle Body
    Timing Chain, engine work, and all hoses replaced $7994
    Control arms and mounts $950
    Headlight bulbs replaced $209
    PS pump and hoses $996
    New brakes (8K miles) $550
    Front crank seal and alternator belt 10-20-14 $450
    Fresh oil change, always used Lubromoly 10-20-14 $150
    List Date: 2/17/2015
    For more info, click here to view the original listing: Black B7 S4 Sedan 6-speed - JHM Tuned, lots of upgrades
    This item is no longer available.
    Dec 07 2009
    East Coast
    Listing model year might be helpful and useful to potential buyers
    Forget the B8, keep the V8!
    Veteran Member Three Rings [a]bek.'s Avatar
    Mar 14 2013
    I think you're asking way too much for you car, no offense. I think you should do a bit of research and lower your price. Mods don't mean much to people as if you took them off, someone would get new stuff anyway.
    Jan 22 2008
    San Jose, CA
    Quote Originally Posted by Mr.Wrong View Post
    just updated...its a 2005.5
    Jan 22 2008
    San Jose, CA
    Quote Originally Posted by [a]bek. View Post
    I've seen some other S4's with high mileage w/o all the maintenance and upgrades I've done so I think asking is fair. Timing chain and maintenance items while timing chain was getting done was about a 10k job, so if you want to roll the dice and get a stock high mileage s4 for 10k then deal with the headache of getting the timing chain done be my guest. This car is ready to go...
    I've updated the ad to OBO... I'll consider reasonable offers. Thanks for looking!
