Results 1 to 12 of 12
    Feb 08 2015
    Nelson NZ
    Question Wheel bearing noise stops on turning right?
    So she whines, (almost growls) once over 10kmh and it changes pitch as speed increases. Same noise coasting in neutral. Seems to be from rear.
    And on a right turn (even slight) whine stops, to return when turn is finished.
    I'm guessing that indicates right hand wheel bearing - as load is taken off it stops noise? On jack the wheel is noisy to turn but seems solid with no slack - though I realise that it is very hard to detect slack in modern cars. Noise could be merely slight binding on discs pads. It spins freely, pads are good.
    Its a 1998 A4 2.4 Quatro.
    I will probably take to excellent local audi mechanic but if its most likely bearing might look at it myself - good tools kit and some experience though never on Audi.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Probably a bearing. Jack the car up and try to rock the wheel up and down. If there is play, the bearing is bad
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Feb 08 2015
    Nelson NZ
    Quote Originally Posted by redline380 View Post
    Hi and thanks. did that and couldn't detect movement though have read that it is hard to get movement on modern bearings. Any special tools needed to do bearings on these?
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Quote Originally Posted by Tamarillo View Post
    Incorrect info. If the bearing is bad, there will be play.
    The bearings need to be pressed in.
    Wait a second- Is yours front wheel drive? That may be different for diagnosing then. And they do not have to be pressed in. They are simple roller tapered bearings that just need to be torqued properly
    2000 S4- Working?
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    That's becuase you don't wear your bearings out like I just did.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Feb 08 2015
    Nelson NZ
    Quattro, thanks for info, will leave it to mechanics then.
    Feb 02 2015
    Middle of nowhere WY
    My '00 avant quattro had a grinding/growl noise to it and a vibration as well. The noise would come and go at different speeds and while turning. When jacked up I could wiggle the wheel with the bad bearing, but none of the others.
    Veteran Member Three Rings g huns's Avatar
    Aug 13 2012
    Lexus RX350
    Wakarusa, Indiana
    My daughter's '97 has a bad drivers side rear wheel bearing. It growls like crazy, but has no detectable wiggle.
    I am taking that as a sign that it can wait until it warms up a little.
    2012 A6 3.0 Premium Plus w/Sport Package
    Dec 03 2014
    1999 Audi A4 Quattro Avant 1.8t 1998 BMW 328iC 1986 BMW 528e
    United States
    I recently was getting a large amount of road noise from my 99 Quattro. Turned out the noise was actually coming through the completely disintegrated lower spindle bushings. I too thought they were wheel bearings until I had it all apart. This doesn't sound like the OP's case since it varied by wheel speed, but may be a contributor to the noise.
    My cars
    1998 BMW 328iC
    1986 BMW 528e
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I had a rear berring go bad and there wAs absolutely no play in it at all. It hummed like nothing I've ever heard tho. Change it out be fore it drives you nuts.
    Senior Member Three Rings BaconBait's Avatar
    Feb 17 2006
    In my car with a shotgun
    I've changed 4 wheels bearing. None of them had any play. Not saying that people haven't come across it before. The turn test is the best at figuring out which side it is.
    -Craig
    Built: 2.0L Stage 4 3/4%
    Oct 31 2014
    NH
    I think the listening test is the best test. How hard is it to figure out where a loud annoying buzzing sound is coming from.
    2014 Audi S4 - 6MT
    2000 Audi A4
