A4 1998 2.4, 160,000km. RHD in NZ. Car well serviced and in excel nick.
Climate control stuck on giving slightly cold air only ever.
If left on auto will just slightly cool air (outside temp 20-24c). On manual I can set any temp I like but it does nothing, cannot heat air ever.
Fan comes on and off randomly it seems, even on manual it won't do what the bar graph says on its display, but will come on sometimes, mostly on start-up.
Diagnosed (inexpertly) as needing new thermostat. If this was simple I'd do it but it seems it's a big job on the V6 as it is almost a full cam belt job, and it is not in need of that for another 40,000km.
And I am not confident of this diagnosis.
Water temp comes up to 80 and pretty much stays there, drops to 75 and will rise to 85 at standstill. There is hot water in heater pipes leading through bulkhead so can't see why stuffed thermostat will stop it heating.
When turned off there is hissing noise from behind bulkhead - passenger compartment side that is, though hardly noticeable inside car, more noticed outside car with engine lid open.
Coolant level good and not using any, no leaks at all.
Checked fuses 15 and 25 and all else is good electrically. Dash displays all work as does climate control displays.
I'm not a mechanic though handy and patient with tools so if it is something I can get too will happily pull it out, others its off to Audi mechanic.
Any experience of this good people?
