Results 1 to 3 of 3
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    Dimmable instrument light tap in
    What is a good spot (wire color, location) to tap into to get dimmable instrument lighting voltage?
    Ideally light switch area. Or driver side kick panel.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Veteran Member Three Rings Luis_Heineken's Avatar
    May 28 2012
    Bayamon, Puerto Rico (USA)
    maybe behind the light switch on the dash
    Sep 16 2010
    Central Wash
    Careful what you plug into that circuit, it only dims a few tiny LEDS in the cluster. It's not designed for very much load at all. If it's just a guage or something obvious then no problem. But more than one tiny incandescent bulb might cause trouble.
