Results 1 to 7 of 7
    Senior Member Three Rings Ryan_qttro's Avatar
    Oct 17 2011
    2005 2.7T Allroad
    Baton Rouge, Louisiana
    Factory Pulley size vs APR STAGE 2 pulley
    Figured since I had the 2 cars available I would post pics, It was discussed in the thread with RAD69 looking at a used S4 over the wknd, and wasnt sure if it had pulley upgrade or not.
    This is Factory Pulley
    This is APR's pulley
    Sorry its flipped upside down, I've got the picture sitting the correct way in photobucket
    Kinda worked out you can see the pullies closer to each other this way.
    Anyway enjoy.
    05 2.7T Allroad
    Audi Tech
    May 13 2014
    New Orleans, LA
    Normally you can tell if you put the supercharger/engine cover on, there is an a tad larger than normal gap between the cover and the pulley. I don't have any pictures because my car is at the dealership right now, maybe someone can offer some up.
    edit:
    My bad if you were looking for actual diameter size, didn't read fully
    (03-29-2015) 2015 8V S3 in Mythos Black, Prestige + 19" Package
    2013 C7 S6: Stock, not for long
    2011 B8 S4 APR Stage 2: Totaled
    Senior Member Three Rings usmc1994's Avatar
    Nov 11 2013
    2014 Audi S4, 2014 Audi A4, 2005 1/2 A4
    Home
    Quote Originally Posted by Ryan_qttro View Post
    Anyway enjoy.
    I measured them both with calipers, OEM was 69.69 APR was 64.64 Awe is supposed to be smaller but haven't seen one to measure it yet.
    Apr Stage 2, Stasis touring suspension, 20x9 Stance Wheels SC-8 with Michelin Pilots, AWE exhaust 102mm tips Vag Com, Alu Kreuz, Awe Boost Gauge
    Senior Member Two Rings alexdell's Avatar
    Jul 29 2011
    Central NJ
    Bumping up an old thread but hoping someone can confirm if the pics is a stock OEM pulley or APR? Thanks..
    IG: @puzoyAlex
    C6.5 A6 Avant Ibis White | KW V3's| H&R F+R Sways| XLR8 Dual Pulleys| EPL Stage 2 tune| S4Matty Ported SC+TB| APR CPS| JHM Downpipes| SkiGuard Roofbox|
    gone ---> B8.5 S4 Sepang Blue (6MT) |APR Stage 2+ UC|
    Veteran Member Four Rings Jroyalty7's Avatar
    Jan 10 2016
    Porsche Macan Turbo
    FL
    Quote Originally Posted by alexdell View Post
    The only way to know is to measure the pulley diameter and compare to the known tuner pulleys.
    Sent from my SM-G955U using Tapatalk
    Current: ‘21 RS5 Sportback B9.5 Nardo Grey
    Retired: ‘13 S4 B8.5 Phantom Black Pearl
    EPL Stage II DP Tune | EPL 57.60mm SC Pulley | 183mm Fluidampr Crank Pulley | S4Matty Ported SC and TB| Aquamist WMI 375cc Jet @ TB| AMS Alpha Heat Exchanger | Milltek Sport Non-Resonated CBE | ECS Kohlefaser Luft-Teknik Intake | Alu Kreuz | CR-15 | 034 Drive Train & Trans Inserts | Bilstein PSS10 | SPC Upper Control Arms | TSW Bathurst 20x10 | Pulley Ratio=3.177
    Jul 01 2012
    14 B8.5 S4, 90 Toyota Supra turbo (575 whp), 02 Subaru Wrx (stock atm),
    North little Rock, Ar
    these numbers are off too can find all the correct info in the beyond stage 2 thread
    Apr 05 2016
    Portland, OR
    Quote Originally Posted by mrb5_supra_wrx View Post
    The sizes in the table are measured at tips of the belt ribs.
    I think the sizes measured here are at the tips of the shoulder.
    Doing the shoulder is easier as you don't have to remove the belt.
    @OP measure the pulley diameter and get back to us.
    Geoff
