Results 1 to 34 of 34
    Feb 12 2008
    Michigan
    about to pick up a symphony 2+ and harness but...
    the unit im getting comes with the s2+ harness, but the car it was in was not Bose, my is Bose. Looking at euro-parts, theres an option for bose or non-Bose harness, are they different?
    just wondering if im going to need to order a harness
    thanks
    Veteran Member Four Rings Andrew149's Avatar
    Apr 19 2009
    Modesto/CA
    I think the coding in the headunit is different so you may need vagcom.
    Sent from my HTC One_M8 using Tapatalk
    2012 Audi A6 3.0t
    2019 GTi 2.0t 6 speed
    2013 Touareg VR6
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    You'll need a different harness, and I believe coding once installed.
    Sent from my Moto X
    Feb 12 2008
    Michigan
    copy that thanks
    Feb 17 2004
    Liberty Hill, TX
    you don't need a different harness (the non-bose just has an extra connector that will be unused), just code the unit correctly with VCDS
    2012 TT-RS | Sepang/Ebony
    Sold: 2007 RS4 | Sprint/Ebony
    Feb 12 2008
    Michigan
    Thanks Matt!
    Established Member Two Rings amkmeco's Avatar
    Jan 14 2012
    PA/ USA
    Quote Originally Posted by Matt Devo View Post
    I recently upgraded mine from 2 to 2+. My car does have Bose but the car from where I got the 2+ was non-Bose. The installation was just plug and play then entered the 4 digits code. I didn't need any vagcom at all.
    Jan 14 2012
    PA/ USA
    And as Matt Devo said, there will be an extra connector that won't be used.
    Feb 17 2004
    Liberty Hill, TX
    works doesn't necessarily equate to set up properly. There are numerous config options which should be set via the coding, including the EQ profile for the Bose system
    Feb 12 2008
    Michigan
    How do you figure out the options the car has that can be reprogrammed?
    Jan 14 2012
    PA/ USA
    Do you mean there are other EQ options other than pressing the Tone button?
    Sent from my iPod touch using Tapatalk
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by amkmeco View Post
    yes. see: http://wiki.ross-tech.com/wiki/index...ration_II_Plus
    Jan 14 2012
    PA/ USA
    Thanks but unfortunately I don't have vagcom. So what will I gain if I vagcom my radio?
    Feb 12 2008
    Michigan
    I bet someone in PA ha one they would help you out with
    Feb 12 2008
    Michigan
    Coding
    0?x0xxx: Options 3
    +1 = Analog Input (AUX)
    +2 = Multifunction Steering Wheel
    +4 = Telephone
    0x?0xxx: Options 2
    +1 = Digital Sound System
    +2 = CD-Changer
    +4 = Satellite Radio
    0xx0?xx: Options 1
    +1 = Leather Interior
    +2 = Diesel Engine
    0xx0x?x: Sound System Correction
    0 = Sound System (No passive Speakers/No Correction)
    1 = Sedan/Coupé with passive Speakers
    2 = Wagon/Avant with passive Speakers
    3 = Cabriolet/Roadster with passive Speakers
    0xx0xx?: Country
    1 = Europe
    2 = North America
    4 = Japan
    5 = China
    i have a 2002 avant with Bose, going to add the 3.5mm auxiliary input jack from euro-parts, and the non-Bose harness will work just fine yes? No steering wheel controls, no external cd changer, I have perforated leatherette, no phone, no sat radio
    My coding will look like: 0110022 correct?
    Thanks
    Feb 17 2004
    Liberty Hill, TX
    Quote Originally Posted by Fast4esT View Post
    Coding
    Thanks
    011002 I'd think, but you can play with the correction value and see what sounds best for you
    Feb 12 2008
    Michigan
    Pulled the sym 2 headunit out to test the 2+ (still waiting on code)
    I only have 2 plugs behind the radio instead of the 3 I keep reading about. Anyone else only have 2 plugs?
    Feb 17 2004
    Liberty Hill, TX
    yes, everyone else with Bose. The 3rd plug is for the (HU) powered front speakers in a non-Bose system
    Feb 12 2008
    Michigan
    I was under impression that Bose had 3 plugs and non Bose had 4 plugs. Is this 3rd (nonexistent) plug a phone plug? If no factory phone, then no wiring for it?
    Long as there's only supposed to be 2 plugs then I'm happy.
    Thanks
    Feb 17 2004
    Liberty Hill, TX
    yes, see:
    Feb 12 2008
    Michigan
    Thanks Matt. No nav, no tele
    Feb 12 2008
    Michigan
    Ok, the radio is not accepting my coding, tried a couple times, different codes, keeps saying not supported
    Aug 26 2005
    What code value are you trying to enter? I suggest using "0100112". Clear any existing fault codes from the radio fault memory before trying to recode the radio.
    Vorsprung durch Technik
    Feb 12 2008
    Michigan
    0110022 is what I wanted to do, I'll reset the DTCs and try the code you suggested.
    Currently has codes for incorrect programming, no antennae, phone, sat, nav, and bus something
    Feb 12 2008
    Michigan
    Cleared the codes and got 0100112 to work.
    Data bus display: no signal/no communication (sporadic)
    What does that mean, it was one of the DTCs.
    This radio sounds a lot better than the old symphony wow.
    Aug 26 2005
    If you have an Avant, use 0100122 unless your A4 has cloth upholstery, or 0140122 if you have or add later SAT radio. Our Standard or Bose sound systems do not use the "Digital Sound System" coding.
    Aug 26 2005
    Amazing how much better the Sym II+ audio quality is compared to the Sym II. It's even better with a pair of upgraded front speakers. I have Infinity Kappa speakers at 2 Ohms impedance, the HU drives a 2 Ohm load no problem.
    I think the display data buss DTC is about the data buss between the radio and the instrument cluster, that is used to display the radio/CD/Aux program channel/source information on the IC DIS display. The Sym II+ uses the CAN Infotainment Buss to send info to the IC display. IIRC, the Sym II used a dedicated connection to the IC for this. Is your A4 a sedan or an Avant?
    Feb 12 2008
    Michigan
    It's an avant, damn, I have not noticed if the dash display works or not, now I gotta go find out. Yeah new speakers would be awesome, 1 more item on the list!
    I was thinking the Bose system was digital sound system, must be why it was not excepting my coding at first
    Aug 26 2005
    Yeah the non Bose and Bose systems use the same HU. Bose systems have the Bose terminal in the quadlock connector jumpered to chassis ground, disabling the front channel internal amp and activating the "Bose" display at turn on. With a Bose system all four channels are low level outputs from the HU to the Bose amplifier. I don't know what the Digital Sound System consists of, but if it exists, it is Euro market.
    Aug 26 2005
    I am not sure at the moment, but IIRC, 2002 A4s being somewhat unique in subtle ways compared to later model years, the '02 may be setting a display data buss DTC because the radio is trying to use the Infotainment CAN buss for the radio IC DIS display, but the IC is not setup for the radio display data over Infotainment CAN, expecting the data over a dedicated CAN data connection instead.
    Feb 12 2008
    Michigan
    Kinda like how the radio can read and display certain cd album artist and song names? This is gonna get interesting
    Aug 26 2005
    Yes, correct. However not all CDs display more than the track and title number. The text title and album info must be included on the CD for that to display on the radio display and the DIS.
    Aug 26 2005
    "Data bus display: no signal/no communication (sporadic)" What is the VAG 5 digit DTC number for this DTC?
    Feb 12 2008
    Michigan
    01305 036
