Results 1 to 31 of 31
    Feb 22 2004
    Monroe Twp, NJ
    B8 newbie question - how to tell if a car is chipped and has a pulley
    I am looking at a used 2013 S4 at a dealer (not audi), it has an AWE intake and AWE exhaust. How can I tell if it is chipped? I assume it is, but how do I tell if it has a pulley? I was thinking I could use a caliper to see, but don't know the diameters... I have a hook up at Audi - so I will see if it is TD1, but I am curious about what software it has and if it has a pulley...
    Senior Member Three Rings Ryan_qttro's Avatar
    Oct 17 2011
    2005 2.7T Allroad
    Baton Rouge, Louisiana
    Maybe someone could put up a pic of stock pulley vs Stage 2 pulley. I'm sure you can see difference by the naked eye.
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Easy test: take it for a test drive, let it get nice and warm (take it on the highway for 10 or so minutes.) Find a safe road, and do a 0-60mph/0-100km/h test. If it's around 5s then there's no chip. If it's faster than 5s then it's got a chip.
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Feb 22 2004
    Monroe Twp, NJ
    That is kinda hard to do that with the salesperson in the car.
    It is almost certainly chipped, I am wondering what software it has, what version, and if it is stage 1 or stage 2 with a pulley. I assume my VAG-Com wont help at all. The exhaust makes it hard to tell, the sound gives the illusion of being faster than the stock ones I drove. My butt dyno is not so good and it is way slower than my last few cars....
    Established Member Two Rings Bus Driver's Avatar
    Dec 09 2012
    Malaysia
    Maybe you can try and contact AWE/GIAC and provide them with the chassis number to see which map the car is having.
    2010 S4 DSG-ADS- Sports Diff-B&O-RocEuro-AWE Catback- GIAC S2/DSG-P3 Gauge-Alcon 365mm 6pot-H&R OE -Eurocode F&R ARB/Endlinks- 19" Breyton BE- Michelin PSS 255/35
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    VIN number to GIAC or APR might help you
    [B]Current: Shopping now....
    Jul 21 2014
    United States
    Log boost requested vs actual with vcds, if possible.
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    The car does sub 5 seconds 0-60 stock so therefore that test is irrelevant. If its CPO I'd assume its not tuned or it would be TD1.
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    Quote Originally Posted by Whitee View Post
    Car is at a non Audi dealer.
    Feb 22 2004
    Monroe Twp, NJ
    Quote Originally Posted by GTItoS4 View Post
    Good Answer! I wonder how they will feel about me plugging my laptop into the car. Hmmmm
    Senior Member Two Rings B8A42010's Avatar
    May 15 2011
    Everywhere
    Measure the pulley
    Mar 26 2014
    Cambridge, Ontario, Canada
    Just vag com the damn thing
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    you can try to see if it has apr by the cruise control stalk
    you can call giac to see if your vin is in their system
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    Measure the pulley?
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Veteran Member Three Rings skiptowncat's Avatar
    Nov 13 2014
    Manchester, England
    Stick it on a dyno?
    2015 C7.5 S6//DS1 STAGE 3//SRM INTAKES//034 X-PIPE//H&R SWAYS
    Deactivated Three Rings
    Oct 03 2014
    Boston
    Quote Originally Posted by Usa View Post
    Measure the pulley?
    pulley is a smaller diameter than stock if it has an aftermarket pulley - stock is 2 3/4"
    Sep 30 2009
    b
    couldn't it have an aftermarket pulley and have been wiped clean of software?
    knowing pulley size does not tell the whole story IMO
    Apr 29 2013
    Ottawa
    Stock we're technically 4.9s 0-60, not gonna notice that. With any stage of tune it will be noticeably faster than that.
    Aug 07 2013
    Granger, IN
    Put your gear in neutral and rev it. If it stops at 4k, then no chip. If it revs all the way, then it's chipped.
    Also, go full throttle on an open road. If it goes past 155 mph, chipped.
    May 19 2014
    Denver
    I would be surprised if former owner/leasee returned the car in tuned mode because it may impact warranty and thus resell value. If it is tuned by GIAC, they license by vin. As others have said, call them and give the vin. Not sure about APR, but they may help if you call them and provide the vin.
    Measuring the pulley before you buy or getting the dealer to dyno the car requires to many calories. Good luck with that advice. Also, I would want to know how many time launch control has been used, subtracted from 200 to determine how many launches remain.
    You will love the car either way. Good luck.
    Mar 31 2014
    2013 Porsche Cayenne Turbo
    Quote Originally Posted by amz View Post
    http://www.motortrend.com/roadtests/...s4_first_test/
    Feb 22 2004
    Monroe Twp, NJ
    Quote Originally Posted by roadkillrob View Post
    That is helpful. How big is AWE or APR? I prolly can find that out in a search...
    Feb 22 2004
    Monroe Twp, NJ
    Quote Originally Posted by schoi623 View Post
    Great idea! Ummm the reving idea. At 155mph the sales chick might poop herself...
    Oct 03 2014
    Boston
    Quote Originally Posted by Ozo8r View Post
    Thinking because it is not at an Audi dealer it may have been TD1 and not able to be CPO, so Audi dealer didn't want it and lease company auctioned it hence ending up at non audi dealer. Also thinking it is a 2013 and therefore too new for a typical 3 year lease return (could have been a 2 year lease) but thinking maybe it was traded for another brand after a couple years and that is why it is on another dealers lot and no reason to wipe the software, if it was a lease return the the intake and exhaust would have had to been removed also.
    So going with trade in for another brand, guy was too lazy to remove and sell mods, so if exhaust and intake is still there, tune and pulley are also - big question is what tune and what stage though - it is most likely Revo, Giac or APR maybe EPL.
    Feb 22 2004
    Monroe Twp, NJ
    Story was that he traded it in to this dealer for a larger car (against his will, needed more room for a car seats) He was the second owner and the one that modded it. I do not think this dealer has any idea that it has so many mods. My head says stay away, but I just gotta have it...
    I am calling the tuners now with the VIN and trying to get TD1 status.
    Oct 17 2011
    2005 2.7T Allroad
    Gimmie the VIN, i can let you know. I work at a Dealer, also I just made a thread showing pics of Stage 2 pulley compared to Factory pulley.
    05 2.7T Allroad
    Audi Tech
    Oct 16 2012
    pa
    Quote Originally Posted by Ryan_qttro View Post
    vin check at a dealer would only tell you if it was td1. i can assure you that isnt the best way to check
    Oct 17 2011
    2005 2.7T Allroad
    I was only checking for TD1 not a tune.
    05 2.7T Allroad
    Audi Tech
    Feb 22 2004
    Monroe Twp, NJ
    Ryan qttro was able to tell me it was not TD1. I called AWE and found out that about 8 months ago the previous owner dropped it off and got an AWE tune, pulley, trans tune, coldfront system, intake, touring exhaust with resonated downpipes (and it has SPM 6-pot alcons 380mm!!??)
    Needless to say i left work early and bought it. Lol i drove it home tonight!!!
    Im back in the Audi family, its been 8 years since my B5 with k24s... This car doesnt feel as fast as my B5, but its a hell of alot nice!
    Thanks again everyone!
    Dec 23 2013
    B8 S4
    Ooo free goodies, can't complain about that^
    Established Member Two Rings SQuattro08's Avatar
    Jan 09 2015
    San Jose, California
    Congrats on the great fine man. Must of sucked for the previous owner who was barely able to have fun after dropping several K's on the car.
