Results 1 to 12 of 12
    Veteran Member Four Rings diztek's Avatar
    Sep 20 2004
    2016 S3, RETIRED: Audi A4 1.8TQ usp
    Paradise Valley, AZ
    Cel w cat delete file
    just got my ecu back from United motorsports. Got the stage 2, vr6 maf, test pipe. Supposedly I was suppose to get the cat delete as well but after 10 miles I got a cel. Also vacuum is now at 15 inhg at idle. I will call um on Monday, but is it safe to say they did not do the cat delete programming? Also could the 15 inhg have anything to do with going to a vr6 maf? Other than that runs great.
    2016 AUDI S3 Prem+ Monsoon Grey
    RETIRED:Audi A4 1.8t UltraSport - USP CLUB MEMBER #90
    Apikol Snub Mount-United Motorsport stage 2-Bosch 440cc-VR6 maf-034Motor Mounts-AWE Exhaust-RS4 Rear Sway-OEM DSMIC-Evo Billet DV-Podi Boost Gauge-Stasis SS Coilovers
    so cel magically means its a catalyst fault? maybe you should try checking faults first.
    contact via email please.
    Aug 25 2010
    exactly
    Sep 20 2004
    Paradise Valley, AZ
    I was under the impression a cel would never occur for any reason. But your right. Need to check.
    Jun 21 2005
    Milton, Ontario
    Any reason you switched from giac to um?
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    2014 Dodge Grand Caravan
    Aug 26 2005
    Quote Originally Posted by diztek View Post
    Intake manifold vacuum pressure at idle has nothing to do with the MAF meter size, since the MAF meter is before the throttle body. The absolute pressure in the intake manifold is the result of the engine tuning (primarily ignition timing) cam timing and valve lift, throttle opening angle (mass air flow rate,) and the idle speed, (engine air pumping capacity,) being at a balance point at idle. The idle balance point with that tune, results in the absolute manifold pressure (vacuum,) shown. OR, there is a large unmetered air leak into the manifold downstream from the throttle valve.
    Vorsprung durch Technik
    Sep 20 2004
    Paradise Valley, AZ
    Thanks, diagnosticator.
    As for me switching to um, giac does not have a cat delete file so Intead of spending a grand on a new cat, I thought I'd get rid of the cat and pick a software that can accomodate. I chose um because my mechanic highly recommend it.
    Sep 20 2004
    Paradise Valley, AZ
    Also I was pinging a lot with giac. Have not heard one ping with um and it was over 80 degrees yesterday.
    Jun 21 2005
    Milton, Ontario
    Good stuff! It's nice to see a fellow veteran member still going strong after 9+ years. I myself have gone up to a billet 28-sized turbo and still loving it on eurodyne tune.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
    Sep 20 2004
    Paradise Valley, AZ
    Nice!! For some reason I just can't get rid of her. ❤️🚗❤️💰💰💰😬😬😬
    Sep 20 2004
    Paradise Valley, AZ
    Well I got the p0420 code. Any chance this could be a result of a bad 02 sensor?
    Jun 21 2005
    Milton, Ontario
    Catalyst System Efficiency Below Threshold (Bank 1)
    When was the last time you replaced either of the O2 sensors?
    Go back to UM and ask them what's up.
    – Steve
    2021 Tesla Model Y
    2020 Tesla Model 3
