Results 1 to 12 of 12
    Jul 07 2013
    Kent OH
    B5 A4 1.8T - Won't stay running
    Thanks for taking the time to read this and I appreciate the help
    Went to start the thing the other morning - it turned over, idled, bogged down, went back idle then eventually, slowly died. I'm at a complete lost for what can be the issue here. I've checked the plugs, they are fine. I've put new fuses in for engine timing and the fuel pump. I hear the pump prime up before cranking. Occasionally upon turning the key to start the car I get 3 loud beeps. Sometimes there is a CEL, other times nothing. My V-checker won't read any engine fault codes. Oil isn't burnt smelling and there is plenty of it. It has a full tank of gas.
    My thoughts are CPS, Fuel filter, Fuel Pump, FP Relay, but I honestly have no idea.
    Thanks again for reading and any help.
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    My car beeped bc I had a bad ABS module when I turned it on. Will the car run at all? Or does it always die?
    Jul 07 2013
    Kent OH
    Thanks for the response!
    My ABS module has been out for awhile and typically it doesn't beep until about 1 min. of driving it. Also, it won't run for longer than a few seconds. It quickly dies. The beeping starts upon trying to roll over the car.
    Oct 10 2013
    State College PA
    it does start up every time tho, just dies instantly.
    Jul 07 2013
    Kent OH
    Not instantly. Sometimes it will start, idle a second or two then die. Then sometimes it will try to run for a minute then bog down and die. What about the FPR that is mounted on the fuel rail? Would a failing fuel pressure regulator cause this?
    Veteran Member Three Rings Rodgman15's Avatar
    Jan 12 2014
    Fargo, ND
    Unplug the MAF see what happens, my tip came off my turbo once so the MAF was funky.
    Jul 27 2011
    IN
    Check the hose between the throttle body and the intercooler..
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    When you turn the key to the on position, does the cel come on, every time? Does your vchecker communicate with the ECU?
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Oct 10 2013
    State College PA
    I would start it and give it a little gas to see if it will stay running and hold it for a bit. If I does stay running i would do what other are saying, check hoses, check for a boost leak, unplug the maf. Did you get shit gas possibly?
    Sep 17 2014
    Woodbridge
    Sounds like possible fuel pump or throttle body adaptation to me.
    Jul 07 2013
    Kent OH
    Quote Originally Posted by Avant Nate View Post
    CEL doesn't come on every time. I think it's odd. The V-Checker does communicate with ECU but it won't register that there is a fault code though.
    Jul 07 2013
    Kent OH
    I'll unplug the MAF and check all the hoses today. I'm also going to remove the Fuel Pump service plate to make sure I'm hearing it prime and to make sure it doesn't sound funny.
    Thanks for all the help everyone!
