I have a 2003 A4 3.0 with 169k miles on it. It is currently sitting in my garage unwilling to start and treat me to the driving pleasure you know these cars offer. Early in our relationship, maybe 20k miles ago, I had the common issue of difficulty starting after fueling. Browsing helpful forums such as this, I fixed the problem by replacing the n80 purge valve and charcoal canister. I haven't had the same problem since when it comes to fueling. However in the past couple months I've been suffering similar difficulty starting as I did after fueling before. The difference now being, it occurred randomly and unrelated to fuel stops. It would take a couple tries to get it started, after the initial normal first attempt, I would hold the throttle down about 3/4 and she would fire and clears its throat with some high rpms. Then it would run normally. Well about a week ago I tried starting it and it did the same crank, fire to ~1500rpm and die. So I tried pumping throttle on second, third etc attempts. After a few attempts it wouldn't even start but just crank. And thats where I sit currently. So I bit the bullet and ordered the RossTech Vagcom cable. Here is my auto scan result(I deleted modules w/o faults):
Friday,13,February,2015,14:37:00:40539
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
VIN: WAULT68E03A234223 License Plate:
Mileage: 272700km-169447mi Repair Order:
Chassis Type: 8E (8E - Audi A4/S4/RS4 B6/B7 (2001 > 2008))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 36 37 45 46 55 56 57 65
67 69 75 76 77
VIN: Mileage: 272700km-169447miles
Address 01: Engine Labels: 06C-909-559-ASN.lbl
Part No SW: 8E0 909 559 E HW: 8E0 909 059
Component: 3.0L V6/5V G 0003
Coding: 0016751
Shop #: WSC 63351 000 00000
VCID: 377D127F45D3DF999FA-515E
8 Faults Found:
16815 - Warm Up Catalyst; Bank 2
P0431 - 001 - Efficiency Below Threshold - MIL ON
16805 - Warm Up Catalyst; Bank 1
P0421 - 001 - Efficiency Below Threshold
17978 - Engine Start Blocked by Immobilizer
P1570 - 008 - - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 008 - - Intermittent
16687 - Cylinder 3
P0303 - 008 - Misfire Detected - Intermittent
16539 - Oxygen (Lambda) Sensor B2 S1; Heating Circuit
P0155 - 008 - Malfunction - Intermittent
16840 - EVAP System
P0456 - 002 - Very Small Leak Detected
16497 - Intake Air Temp. Sensor (G42)
P0113 - 002 - Signal too High - Intermittent
Readiness: 0000 0000
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 L
Component: A4 Klimaautomat 1116
Coding: 00000
Shop #: WSC 63351
VCID: 2A5B3B0BD6617271104-5140
1 Fault Found:
00474 - Control Module for Immobilizer
49-10 - No Communications - Intermittent
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Part No: 8E0 953 549 N
Component: Lenksáulenmodul 0308
Coding: 02041
Shop #: WSC 63351
VCID: 3E73075B3AE9EED15CC-4B00
1 Fault Found:
Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 L
Component: KOMBI+WEGFAHRS. RB4 D36
Coding: 03200
Shop #: WSC 02301
VCID: 326B236BFEB13AB1A84-515E
WAULT68E03A234223 AUZ6Z0B0345175
1 Fault Found:
01176 - Key
07-10 - Signal too Low - Intermittent
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0203
Coding: 00001
Shop #: WSC 02301
VCID: 71E9EC673B3741A991E-4AE8
2 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
79-00 - Please Check Fault Codes
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 BB
Component: Komfortgerát T7B 1311
Coding: 11836
Shop #: WSC 40201
VCID: 72EBE36B3E317AB1684-4B00
Subsystem 1 - Part No: 8E1959801
Component: Tőrsteuer.FS BRM 0002
Subsystem 2 - Part No: 8E1959802E
Component: Tőrsteuer.BF BRM 0002
Subsystem 3 - Part No: 8E0959801A
Component: Tőrsteuer.HL BRM 0002
Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0002
9 Faults Found:
01374 - Alarm triggered by Terminal 15
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Rear Right
35-00 - -
00955 - Key 1
35-00 - -
00956 - Key 2
35-00 - -
00915 - Window Regulator Switch; Rear Right; Driver (E55)
27-10 - Implausible Signal - Intermittent
00932 - Electric Window Motor; Drivers Side (V147)
62-10 - No or Incorrect Adjustment - Intermittent
01331 - Door Control Module; Driver Side (J386)
53-10 - Supply Voltage Too Low - Intermittent
Address 56: Radio Labels: None
Part No: ˙˙˙˙˙˙˙˙˙
Component: symphony II ˙˙˙ 0051
Coding: 32767
Shop #: WSC 131071
VCID: 76E3DF7B5259669144C-4E96
2 Faults Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
36-00 - Open Circuit
01042 - Control Module; Not Coded
127-10 - Unknown Error Elaboration - Intermittent
End-------------------------(Elapsed Time: 05:25)--------------------------
Upon seeing that cylinder three misfire, I replaced that coil pack simply because I changed the spark plugs a few months ago and a coil pack was only $20. Unfortunately that didn't work. I've also reprogrammed both my keys after replacing their batteries. I reprogrammed them using my VagCom and they are working to lock and unlock the door. The batteries were failing and I had to reprogram them previously due to weak signal so this should account for the immobilizer faults. Also there is no immobilizer light flashing while cranking. My 02 sensor faults have been there since I bought the car.
Any advice is greatly appreciated!
Thank you
