Hello all,
I had my pre-cats gutted a couple of weeks ago in addition to adding ecs h-pipe. I picked up the car from the shop with the cel on which I was told was normal for "piggies" however once I got my jhm tune it would code it out. I just got the jhm tune installed on Thursday and in less than 15 miles the cell is back. I have attached the scan that I ran this morning. I clear the codes and took it on another spin and cel just came back with just the 2 fault codes.
Could the O2 sensors have been damaged during piggie install? I also have been noticing slight moisture droplets coming from where the O2 sensors may be. If I let the car run for a few minutes in the driveway and then move it. I see to identicle moist spots on ground which I'm baffled about.
Am I overthinking things here? Could the installer of the tune messed up and not tuned correctly, what I mean is that when he was attempting to select which program to install, he wasn't sure as he said that jhm had a couple of software options to choose from for the rs4. I told him that I had the h-pipe and piggies installed and it seemed like he didn't really understand what I was talking about. Thank you all in advance!
Saturday,01,November,2014,09:02:23:32264
VCDS Version: Release 11.11.3
Data version: 20120401
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WUADU78EX8N902462 Mileage: 163400km/101532miles
Address 01: Engine Labels: 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 A HW: 8E1 907 560
Component: 4.4L 91/V6 JHM Ş0060
Revision: 57H19--- Serial number: XXXXXXXXXXXXXX
Coding: 01040009180F0160
Shop #: WSC 22302 444 54544
VCID: 244DF249E7C0DE9
3 Faults Found:
000313 - Oxygen (Lambda) Sensor B1 S2
P0139 - 004 - Response too Slow - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 163357 km
Time Indication: 0
Freeze Frame:
RPM: 3261 /min
Load: 16.9 %
Speed: 86.0 km/h
Temperature: 79.0°C
Temperature: 32.0°C
Absolute Pres.: 970.0 mbar
Voltage: 13.716 V
004372 - Oxygen (Lambda) Sensor; B1 S2
P1114 - 008 - Internal Resistance too High - MIL ON
Freeze Frame:
Fault Status: 11101000
Fault Priority: 0
Fault Frequency: 1
Mileage: 163357 km
Time Indication: 0
Freeze Frame:
RPM: 3210 /min
Load: 16.9 %
Speed: 85.0 km/h
Temperature: 79.0°C
Temperature: 32.0°C
Voltage: 13.589 V
000320 - Oxygen (Lambda) Sensor B1 S2
P0140 - 004 - No Activity
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 1
Mileage: 163398 km
Time Indication: 0
Freeze Frame:
RPM: 776 /min
Load: 14.9 %
Speed: 0.0 km/h
Temperature: 93.0°C
Temperature: 39.0°C
Absolute Pres.: 960.0 mbar
Voltage: 13.589 V
Readiness: 0000 0100
Address 03: ABS Brakes Labels: 8E0-910-517.lbl
Part No SW: 8E0 910 517 G HW: 8E0 614 517 BD
Component: ESP8 quattro H06 0150
Revision: 00000000 Serial number: 00000000000000
Coding: 0004533
Shop #: WSC 06335 000 00000
VCID: 2B5F19758A1E111
1 Fault Found:
01314 - Engine Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 1
Fault Frequency: 1
Reset counter: 36
Time Indication: 0
Freeze Frame:
Hex Value: 0x0000
Hex Value: 0x4022
Hex Value: 0x0013
Hex Value: 0x8593
Hex Value: 0x0001
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Part No: 8E0 820 043 BM
Component: A4 Klimaautomat 3233
Coding: 00000
Shop #: WSC 00000
VCID: 6DDBD76D278ADF1
1 Fault Found:
00819 - High Pressure Sensor (G65)
07-10 - Signal too Low - Intermittent
Address 09: Cent. Elect. Labels: 8E0-907-279-8EC.lbl
Part No: 8E0 907 279 N
Component: int. Lastmodul ECE 0907
Coding: 01021
Shop #: WSC 06335
VCID: 3D7B272D376A8F1
No fault code found.
Address 0F: Digital Radio Labels: 8E0-035-593-SIR.lbl
Part No SW: 8E0 035 593 N HW:
Component: SDAR SIRIUS
Revision: Serial number: AUZ4Z7H0247360
Shop #: WSC 00000 000 00000
VCID: 346D020954204E9
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Address 11: Engine II Labels: 079-910-560-BNS2.lbl
Address 15: Airbags Labels: 8E0-959-655-94.lbl
Part No SW: 8E0 959 655 M HW: 8E0 959 655 M
Component: Airbag 9.41 H01 4240
Revision: 91H01424 Serial number: 003CS000H1L$
Coding: 0432607
VCID: 41835BDD1892EB1
Part No: 8E0 910 339 D
Component: BF-Gewichtsens. H03 0080
Address 16: Steering wheel Labels: 8E0-953-549-T.lbl
Part No: 8E0 953 549 T
Component: Lenksáulenmodul 0401
Coding: 04441
Shop #: WSC 06335
VCID: 448D52C95480FE9
Address 17: Instruments Labels: 8E0-920-9xx-8EC.lbl
Part No SW: 8E0 920 983 F HW: 8E0 920 983 F
Component: KOMBI+WFS 4 H10 0100
Revision: 0100 Serial number: 00000000000000
Coding: 0023208
VCID: 32610411AE34409
1 Fault Found:
Address 36: Seat Mem. Drvr Labels: 8E0-959-760.lbl
Part No: 8E0 959 760
Component: Sitzmemory R2 F 0305
Coding: 00002
Shop #: WSC 00000
VCID: F1E34B1DBBB2BB1
Address 37: Navigation Labels: 8E0-035-192-RNSE.lbl
Part No SW: 8E0 035 192 P HW: 8E0 035 192 P
Component: RNS-E US H75 0250
Revision: 05S Serial number: AUZBZ7H2402566
Coding: 0309637
Shop #: WSC 02197 785 00200
VCID: 31630B1DAB327B1
2 Faults Found:
02261 - Data Medium
014 - Defective - Intermittent
Freeze Frame:
Fault Status: 00101110
Fault Priority: 5
Fault Frequency: 1
Reset counter: 42
Time Indication: 0
Date: 2008.12.10
Time: 14:33:59
Freeze Frame:
Mileage: 655350 km
Count: 1012
Clock: 14:34
00858 - Connection; Radio ZF Output to Antenna Amplifier
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 23
Reset counter: 43
Time Indication: 0
Date: 2008.11.19
Time: 17:47:55
Freeze Frame:
Mileage: 655350 km
Count: 1402
Clock: 08:47
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Part No: 8E0 959 433 CP
Component: Komfortgerát T7B 4336
Coding: 11880
Shop #: WSC 06335
VCID: 81031BDD8B12AB1
Subsystem 1 - Part No: 8E1959801G
Component: Tőrsteuer.FS BRM 0706
Subsystem 2 - Part No: 8E1959802G
Component: Tőrsteuer.BF BRM 0706
Subsystem 3 - Part No: 8E0959801E
Component: Tőrsteuer.HL BRM 0606
Subsystem 4 - Part No: 8E0959802E
Component: Tőrsteuer.HR BRM 0606
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000019
VCID: 2953E37D80E2031
Part No: 8E0 941 329 A
Component: AFS-Modul links H05 0030
Component: AFS-Modul rechtsH05 0030
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 28
Time Indication: 0
Address 56: Radio Labels: 8E0-035-192-RNSE.lbl
Coding: 0309637
2 Faults Found:
02261 - Data Medium
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 42
Time Indication: 0
Date: 2008.12.10
Time: 14:33:59
Freeze Frame:
Mileage: 655350 km
Count: 1012
Clock: 14:34
Freeze Frame:
Fault Priority: 5
Fault Frequency: 23
Reset counter: 43
Time Indication: 0
Date: 2008.11.19
Time: 17:47:55
Freeze Frame:
Mileage: 655350 km
Count: 1402
Clock: 08:47
Address 65: Tire Pressure Labels: 8E0-907-273.lbl
Part No SW: 8E0 907 273 A HW: 8E0 907 273 A
Component: Reifendruck 3 H04 0130
Coding: 0062523
VCID: 2A511C7186E4089
Address 76: Park Assist Labels: 8E0-919-283-8EC.lbl
Part No SW: 8E0 919 283 D HW: 8E0 919 283 D
Component: Parkhilfe 4-Kan H06 0010
Revision: 00H06000 Serial number: 00067802020807
Coding: 0000304
Address 77: Telephone Labels: 8P0-862-335.lbl
Part No SW: 8P0 862 335 R HW: 8P0 862 335 R
Component: FSE_255x BT H26 0350
Revision: 00000000 Serial number: 00000005069950
Coding: 0011877
VCID: 458B4FCD0FBAC71
End ---------------------------------------------------------------------
