Results 1 to 40 of 57
    Jul 13 2014
    1997BMWZ3
    Daly City,CA United States
    Start up Rattle and Accusump
    hello im planning to buy an Accusump to prolong my engine from the cold/warm start up rattles I get. I have 94k miles right now. My question to you guys is how long have you had the Accusump in your B6/7 and did you have cold/warm start up rattles before? Mileage before Accusump and present? Success stories? Anyone had Accusump but still had a timing chain failure from broken tensioners? Where did you mount the Accusump?
    Established Member Two Rings cobraBLACK's Avatar
    Dec 06 2010
    UK
    They may well work but they're not going to reverse the damage that's already done.
    Audi S4 Avant (B6, 2004) in Goodwood Green. V8, motherhubbards!!
    Active Member Four Rings EUROSWAGR's Avatar
    Oct 11 2008
    2015 Ford F-150 FX4 (twins) / 2012 Audi Q5 S-line
    East Coast
    IMHO, this accusump hype is a waste of money. DO the timing chain job and drive the car for 100k more miles
    "Make yourselves sheep and the wolves will eat you." ~ Benjamin Franklin
    Oct 13 2009
    Other Broken Vehicles
    Farmington Hills, Michigan
    Quote Originally Posted by EUROSWAGR View Post
    i'd have to agree with this.most vehicles have made it up to now without the use of one. now if you tore down your motor and built it with tighter than stock main, rod, and ptw clearances then maybe id tell you to install one, but thats the only time you'll really need one.
    (\_/)
    (o o)
    00 Laser Red "stage III" S4: Sold
    04 Moro Blue S4 6MT: Sold
    01 Allroad 6MT: Sold
    06 A4 Avant 6MT
    09 C63 P30
    Senior Member Three Rings m-ys4's Avatar
    Jul 29 2014
    Toronto, Ontario
    I've been reading about this all morning and it seems like a great thing to have. yes damage is already done but I guess this will further prevent damage from happening? Are guys still installing this? Today was the first time I've ever heard about it.
    2018 B9 S5 Coupe Technik Mythos Black- Current
    2013 B8.5 A4 Technik manual - Sold
    2007 GTI manual coupe - Sold
    2005 B6 S4 manual - Sold
    2008 Mazdaspeed3 manual fully built - Sold
    2004 Volvo S60R manual - Sold
    Oct 13 2009
    Its not needed, its use is for engines (Racing applications) with tight tolerances to have oil pressure before start. most all production engines have looser clearances to prevent this, and to allow a film oil accumulate on the mains and rods. The rattle is either a broken guide and upon start up the engine has to build pressure to allow the tensioner to remove excess slack, even on engines with unbroken guides you may have initial start up rattle, its caused by the tensioners backing into the housing a little and upon start up the thrust load on the chain from the crank allows some deflection until the guide rail supports it, most tensioners today have the piston machined with slots and a spiral spring to prevent the piston from being pushed back into the body of the tensioner allowing only a one-way outward motion. so it may always be apparent on these cars without that mechanism, but its no real worry as it won't cause any damage. people changed driving habits and adding all these sub systems are going over board is just my opinion. auto manufacturers test these engines in conditions no consumer will see in most applications. Audi did the same testing when these were developed so i wouldn't worry and start adding all this stuff. I bought the JHM intermediate timing kit with the updated guide and haven't worried since.
    (\_/)
    (o o)
    06 A4 Avant 6MT
    09 C63 P30
    Jul 29 2014
    Toronto, Ontario
    Brandy, are the upgraded guides in the timing kit pretty much solid and 'unbreakable'? I worry one of my guids might be cracked or something, I get the rattle upon cold start sometimes, not all the time. but mainly on cold, never warm. this accusump would prevent the rattle and from making things more worse than they already are no? Im just trying to get a full understanding of the product.
    Oct 13 2009
    Quote Originally Posted by m-ys4 View Post
    For the conditions these engines see i'd say the guide is more than enough, its quite robust. i still have some on these cold mornings 10F-0 but its barely audible, but thats just the tensioners settling in and residual pressure bleeding off as i know my guides are new and unbroken. unfortunately adding an oil accumulator may just be putting a big bandage on existing damage.
    (\_/)
    (o o)
    06 A4 Avant 6MT
    09 C63 P30
    Sep 09 2011
    2011 Chevy Duramax, 1999 Mazda Miata
    Chardon, OH
    Quote Originally Posted by kevinye77137 View Post
    Check out my build thread. I mounted a 1qt accusump in my trunk. I have been using it for over a year so far. Let me clarify for you. The 1qt system is for PRE OILING your motor. This is NOT a chain rattle solution. If you have rattle on start up, the accusump can actually hide a potential timing issue.
    I agree with the hype of the accusump. People keep thinking its a chain rattle solution. It was my personal preference to buy and install an accusump, not because I wanted to solve rattle
    No it will not prevent any damage. The accusump in this situation is only for preoiling your motor. This is only on start up if you use the electric valve switch. If using the electric valve switch, the accusump does nothing when you are driving
    Quote Originally Posted by Brandywine050 View Post
    Its not needed, its use is for engines (Racing applications) with tight tolerances to have oil pressure before start. most all production engines have looser clearances to prevent this, and to allow a film oil accumulate on the mains and rods. The rattle is either a broken guide and upon start up the engine has to build pressure to allow the tensioner to remove excess slack, even on engines with unbroken guides you may have initial start up rattle, its caused by the tensioners backing into the housing a little and upon start up the thrust load on the chain from the crank allows some deflection until the guide rail supports it, most tensioners today have the piston machined with slots and a spiral spring to prevent the piston from being pushed back into the body of the tensioner allowing only a one-way outward motion. so it may always be apparent on these cars without that mechanism, but its no real worry as it won't cause any damage. people changed driving habits and adding all these sub systems are going over board is just my opinion. auto manufacturers soak these engines to -15 ambient air temps,-20 coolant-10` oil, start them and ramp them to peak power or torque for quite the duration of time. Audi did the same testing when these were developed so i wouldn't worry and start adding all this stuff. I bought the JHM intermediate timing kit with the updated guide and haven't worried since.
    Not all accusumps are made for racing purposes or for start up purposes either. They can be used to keep constant oil pressure in a motor during a run period. With that said, I still agree it is not needed, and people just need to update their timing
    RIP 2004 S4 built by Gellner Engineering Racing Engines
    Jul 29 2014
    Toronto, Ontario
    ok, so you bought it for the pre oiling the motor before startup, not the chain fix. I got that, but if you do get the electric valve switch and leave it on while driving isn't it still flowing until it is shut off by the switch? Overall aren't there benefits from this system using it daily?
    Sep 09 2011
    Chardon, OH
    If you leave the switch on, the only thing it will do is match the current oil pressure of the motor. So if oil pressure drops, so will the pressure in the accusump.
    The electric switch is not made to run all the time. That is what the EPC switch was designed for. It will only release oil in your accusump when you go below a certain oil pressure set by the valve.
    Jul 13 2014
    1997BMWZ3
    My only purpose of buying an accusump is to extend my engine life for another extra 30k miles if that is possible. I know that it is a bandaid for it and i will need to do the timing chain service eventually. As a college student I have no money for a timing chain service as it cost more than my tuition. As I read online, 80% of engine wear comes from startups. As for now, I have used the cutoff switch on the fuel pump method to preoil the engine with the starter to minimize the noise and it works 90% of the time with no rattle in cold startups. im willing to drop 400 dollars now than couple of grand just for an extended life and a peace of mind
    Jul 29 2014
    Toronto, Ontario
    Totally understand lol. it would be nice to have even after the timing chain service, I think I would buy it regardless.
    Sep 09 2011
    Chardon, OH
    I want to point out as well the guy who posted the DIY for the accusump is not the proper way to run the accusump. The line to the rear of the filter housing is too small. The lines really need to be a -10an line. I have JHM's oil cooler kit so I was able to use a tee fitting in that line for my accusump and stay at a -10an line. I was able to run accusump's suggested check valve as well in the lines
    Like such...
    Jul 13 2014
    1997BMWZ3
    Quote Originally Posted by aroderick56 View Post
    Like such...
    Canton also sells the modified oil filter cap just for accusump. I sent an email asking if it fits in our engines and they said yes.
    Link to the oil filter cap : https://www.cantonracingproducts.com...DI-FILTER-CAP/
    Sep 09 2011
    Chardon, OH
    I completely forgot about the cap they made for our cars so yes that is another option for the oil line
    Jul 29 2014
    Toronto, Ontario
    so the only thing he did wrong is install a smaller line? How difficult was it to install? I see the DIY it doesn't look to difficult but some of the pictures are unclear to me
    Jul 13 2014
    1997BMWZ3
    Yes the hole is too small but for just the startup rattle it should be fine. since the oil filter cap is available now it should be easy to install. The most difficult part is to mount the accusump.
    Jul 29 2014
    Toronto, Ontario
    Whats the benefit of the cap? Does this mean we domt have to install the line at the back/bottom of the oil filter housing?
    Veteran Member Four Rings SquiddyB6S4's Avatar
    Apr 24 2010
    B6S4, CD5, Gen4 T4R, NA8 aka ugly track slut
    Teh!cks-us
    Remember, though, that if you install the line on the top of the oil filter housing cap, you will have to remove the line every time you change your oil. The inconvenience wouldn't bother me as much as having to remove the line over and over again, and possibly introduce a leak over time as you wear out the fitting threads, or if you forget to tighten or seal them properly, or overtighten them, etc. The oil filter housing has a piston seal style o-ring installation and the drain nut has a soft crush washer, both intended to be replaced each usage, to prevent issues with repeated loosening and tightening of the liquid tight seals.
    -Jason
    2004 B6S4 6MT - Apikol Snub Mount, Piggie Pipes, Magnaflow Cat-Back, JHM Tune with Launch Assist, Squid Rear LSD #01 20lb wheels + Michelin PSS
    2013 Veloster Turbo 6MT - For sale
    1996 Miata - DE car; every moving part new or rebuilt, almost stock
    1995 Accord Wagon - Beautiful, stock, DD Duty, trip-mobile, track day support wagon
    LifeWithSquid
    Jul 29 2014
    Toronto, Ontario
    I was thinking about that the other day, I would just install it the regular way
    Sent from my SM-N900W8 using Tapatalk
    Senior Member Three Rings Dirtracer603's Avatar
    Aug 15 2012
    Custom stunt CRF250 supermoto, 06 CBR600rr
    Fredericksburg, Va
    Good gosh people. An Accusump: hides the true issue and simply delays the inevitable.
    Jul 29 2014
    Toronto, Ontario
    We knew this already lol
    Jul 29 2014
    Toronto, Ontario
    Ive seen a few cases where some people have done the timing service and they still have gotten the rattle in short time. Why not use this even after the service just to prevent any possible future damage that could come up again?
    Jul 13 2014
    1997BMWZ3
    Quote Originally Posted by Dirtracer603 View Post
    That is the exact purpose of the accusump for me at least. To delay the time of dropping 6k+ on timing chain service.
    Dropping $500 to go for an extra couple thousand miles is worth it for a DD
    Jul 29 2014
    Toronto, Ontario
    Kevin, did you perform the install yourself? Was it difficult? The instructions seem straight forward, just the fishing and wiring I'm concerned about.
    Jul 13 2014
    1997BMWZ3
    Yes I will be installing it myself. I dont have it yet but once i get my paycheck i will buy it. Im planning on buying the oil filter cap for accusump as well since my stock one is stripped out. It looks pretty straight forward to install. pretty much hooking things up. My concern is how am I going to mount the accusump on top of the intake manifold. Good thing there are mounting holes for the audi engine cover. Same as the DIY. Instead of buying the electronic valve, i will buy the manual cable valve and fish it to the cabin for lower cost. Works the same way but I will have to manually open and close the accusump to retain pressure. I will close the valve right after pressure has reached its peak so there will be barely any heat in the accusump.
    Jul 29 2014
    Toronto, Ontario
    ill probably buy the electronic one just so I don't have to open the hood each time I want to start it up, I don't think ill buy the oil cap just cause of what a pain it comes to be during oil changes. Also, how are you going to mount it? I've been told by a local performance shop that it definitely shouldn't be ontop of the manifold.
    Aug 15 2014
    Ann Arbor, MI, USA
    I relocated the battery to the trunk in place of the stupid satellite radio plastic thing on the driver side. That will give you barely enough room to fabricate a mount in there (I attached it to the strut tower reinforcement bar). There is a large rubber grommet that you can easily remove to run the AN line through the bottom of the firewall.
    Jul 29 2014
    Toronto, Ontario
    can you take a picture of this setup? I was thinking the same thing last night.
    Aug 15 2014
    Ann Arbor, MI, USA
    Haha that will be difficult since my car has been in the shop for months getting various things done (one of them being the timing service). Once I get it back, will try to upload some images.
    Jul 29 2014
    Toronto, Ontario
    sounds good. how much labor is the shop charging you? What timing kit did you buy?
    Aug 15 2014
    Ann Arbor, MI, USA
    They charged $6.2k all in with the JHM intermediate kit (the cheaper one which has their cam adjuster sprocket). Anyway, they messed it up badly and it skipped timing - big mess So I'm getting a rebuilt engine put in with much fewer miles. Now I get to worry about cylinder wall scoring...
    Jul 29 2014
    Toronto, Ontario
    oh jeez how the hell did that end up happening? that's brutal man..
    Aug 15 2014
    Ann Arbor, MI, USA
    Yea, brutal is right. I guess the piston head impacted a valve and broke it off in the cylinder. So it was bouncing around in there for awhile. That must have been a hell of sound/sight to witness.
    Jul 29 2014
    Toronto, Ontario
    that's strange how this would have happened from a timing chain service. so are they going to do a service on the new motor they are putting in?
    Aug 15 2014
    Ann Arbor, MI, USA
    All the new timing kit parts will be transferred to the other engine. So should be good there.
    Timing jump + interference engine = disaster.
    Jan 29 2010
    north ga
    ....funny how I was attacked when I said this from the very start of the Accusump debacle.
    now it just about seems to be the consensus......also I've been waiting for a post of somebody saying their oil lines busted/leaked and they got oil everywhere or possibly even lost oil pressure due to a bad install. None of that ever seemed worth if to me just to put a bandaid on the car.
    Sep 09 2011
    Chardon, OH
    Quote Originally Posted by BCsniper View Post
    If you know how to properly make lines, then it isn't a problem lol
    Jul 13 2014
    1997BMWZ3
    Funny how all I get is negative replies when I know its not a "perm cure" for timing rattle but a delay for a timing job. I did say " prolong" on my first sentence. No one is able to answer my questions. Im going to cry to sleep now
