Results 1 to 3 of 3
    Established Member Two Rings perrytcolts's Avatar
    Feb 12 2014
    London, United Kingdom
    B6 S4 Fuel Filter part
    Hi guys,
    I'm looking to replace my fuel filter as the old girl is developing difficulty starting - starting with basics and rule out the fuel filter.
    Had a look underneath and noticed there's only two lines - in and out as opposed to what everyone says is meant to be 4 lines (car is 2004). However the part doesn't look OEM and the previous owner looks like he might have replaced it with an aftermarket 2 line version and rerouted the other lines - is that even possible?
    Here are some photos:
    Thoughts?
    Veteran Member Three Rings DarrenOman's Avatar
    Nov 03 2014
    2009 Gray A3
    California
    I also have a 2004 B6 S4 and only remember two fuel lines. Just buy an original fuel filter and you should be good to go. I watched a YouTube video to change the filter as the clips are a bit tricky to undo.
    Feb 12 2014
    Sweet thanks that's good to know. Yeah will just go OEM with it.
