Results 1 to 6 of 6
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    Anybody have a coolant tester?
    Long story short, I've had misfires happening for a while now.
    2008 a4 2.0t
    I got all new spark plugs. Swapped out all he coilpacks for working oem coils. I've done a compression test and each cylinder hit 155-160 so it's not the rings.
    The last thing I can think of besides injectors would be a head gasket or cracked block. Wondering if anybody has a tester to see if there are exhaust fumes in my coolant. Or have any other ideas?
    Thanks in advance guys.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Veteran Member Three Rings DoItAllGarage's Avatar
    Oct 29 2013
    WA to ID
    Do a leak down test!
    Aug 20 2011
    Seattle Wa
    Quote Originally Posted by DoItAllGarage View Post
    Just looked that up, was not sure what it was before. This would lead to more info about the possibility of my head gasket being broken. If anybody has a Leak Down Testing Tool that would also be appreciated. They are 39.99 at harbor freight right now..
    -James
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Quote Originally Posted by Solarsuplex View Post
    2008 a4 2.0t
    Did you do a VCDS scan for codes ?
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Aug 20 2011
    Seattle Wa
    Quote Originally Posted by 02 A6 2.7T View Post
    I have a scan tool, not vcds. But it doesn't show any codes once I clear the cel for misfire.
    -James
    Oct 29 2013
    WA to ID
    The Horrible Freight tool works just fine. (same one I have). Grab a 20% coupon code and go pick it up!
