hello tuners recently my ac stopped working about 2 weeks after i had the system vacumed and regassed the low side was filled with 40psi and the high side was filled with 145psi r134a gas the front of the car was off overnight to fix a radiator problem anyways everythng was working as it should when suddenly the ac stopped blowing cold air.
I scanned with my vag com and got the basic codes for the flaps nothing hard core as the n280 valve etc did some logging as well here is what it shows when the ac is runnning please note its blowing hot air when his data was being taken.
measuring blocks group 1
a/c valve n280 current 0.648 A
a/c valve n280 duty cycle 63.2%
high pressure signal g65 26.0%
refrigerant circuit pressure 7.0bar
group2
current criteria 0.0
last criteria 3.0
last but one criteria 12.0
last but two criteria 0.0
i checked the high and low sides with a gauge today but since the compressor doesnt engage i didt get a reading my econ button goes on and off and fans spin up when i push the ac buttonis is there a relay that i can check? also i checked the fuses and they were good to go
when i changed the internal temperature the duty cycle and current would change but slightly also the circuit pressure would go up to 8bars is that normal?
also if i put in around 145psi on the high side now the circuit is saying 8bars isnt that like 114psi? would that indicate a low refrigerant level causing my compressor not to engage
thanks for the help guys.
