Results 1 to 9 of 9
    Veteran Member Four Rings drewgold's Avatar
    Sep 21 2004
    1981 Kawasaki KZ440 and too many bikes and skis!
    Rocky Mountains, Canada
    Getting a slight miss/stumble/hiccup at idle, any ideas?
    I have noticed lately that at idle, usually more so when the car is warm, I get a slight miss or hiccup. It's very subtle, but can feel it through the steering wheel, shifter and even the seat. It's just a really quick blip, not even enough for the tach needle to dip.
    It's intermittent, and will usually happen a few times while say stopped at a light. There are no misses under hard acceleration or cruising.
    Some forum posts I have read say that this is normal and it's just the computer adjusting the fuel mapping? I have never noticed it before though which worries me a bit.
    Any ideas? It's not bad now but want to be on top of it in case it's a sign of a developing problem.
    2006 A4 Avant, 2.0TQM - JHM Stg 1 Tune - Unitronic HFC/3" Downpipe - 034 Street Mounts - APR Snub - S4 RSB - 034 Turbo Inlet - JHM Short Shifter - Porsche 345mm Brembo Front Brakes w/ceramic pads - S4 Rear Brakes - Stock Sport Suspension/B5 front cups - Black Alcantara Recaro Interior - RoadNav/S100 Headunit - Summer: 19" OEM S5 wheels, 19x8.5 ET32 - Winter: OEM 18" RS4 stye wheels, 18x8 ET43 w/ Nokian studded tires - Dolphin Grey FTW!
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    How many miles? Could be carbon build up maybe.
    2021 Audi S4, P34 Intake
    Sep 21 2004
    155,000kms/96,313miles
    Not likely to be carbon buildup as the cylinder head/valves are almost new.
    I guess it could be carbon on the injectors though, had a shop inspect the injectors with a camera and they said the tips look fine (no fuel dripping with engine off, no excessive carbon on them) and seem to hold pressure well.
    Dec 03 2008
    2018 SQ5
    Could be actually up in the intake flaps. I have a rough start issue and hiccup kinda action, but only when the engine is cold due to a malfunction with the flaps. I did a carbon clean but never thought to look up in the manifold the other way. I replaced the motor, but that didn't fix it. Guessing there is carbon up in the manifold blocking the flaps from their full range of motion.
    Sep 21 2004
    That's a good call! I didn't think about the flaps. I'll take a look. I also have had the motor replaced but to my knowledge, the flaps haven't been touched.
    Sep 12 2009
    Edmonton, Canada
    My b7 has been doing that for the past 275,000 km. lol.
    I get a couple of misfires when I'm stopped at a light after an hour on the highway. It happens almost daily. Like you you described, you can feel it through the whole car.
    I worried about it 275,000kms ago. Not so much anymore. Still running strong.
    Veteran Member Four Rings audimeister's Avatar
    Jan 05 2006
    '07 A4 Avant S line Ti 6MT Quattro
    Oakland, CA
    Coilpacks and plugs?
    "Obsessed" is a word that the lazy use to describe the committed.
    Veteran Member Four Rings BenMTL's Avatar
    Dec 19 2012
    Europe
    Quote Originally Posted by audimeister View Post
    If they haven't been replaced recently, I definitely do that + N80....Always smooths out the idle.
    Race: 2006 A4 2.0 T / Quattro + 6 Speed / JHM Stage 2 93 w/HPFP / Custom 3" Turbo back exhaust / AWE Boost Gauge / JHM Short Shifter + Intercooler / White CF Trim / S4 Door Blades / DTM Conversion / RS4 RSB / HFC
    Daily: 2012 Audi A7 3.0 TDI / Twin Turbo / True Sline / Quattro + 8 Speed ZF / HUD + ACC + Sunroof / APR Stage 1 / Eurocode Alu Kreuz + Mounts / 034 RSB
    Sep 21 2004
    Quote Originally Posted by BenMTL View Post
    I have already put in new plugs and coils. Thought for sure new coils would help but no luck.
    Haven't done the N80. I hate to throw parts at a problem but the N80 is pretty cheap so may give it a try.
    That's actually good to hear, it's really not a big deal but have been concerned that it's a sign of another lurking problem. May just be one of those many Audi quirks!
