Results 1 to 12 of 12
    Established Member Two Rings Cbotello's Avatar
    Apr 29 2014
    Bellingham wa
    Attn anyone running cx racing 3" exhaust and 034 3" test pipe
    I just installed the 034 Motorsport 3" test pipe and cx racing exhaust and I am running into problems the the bolt holes not lining up and from the test pipe to down pipe also I can't get the bottom bolt on the turbo/ test pipe on has anyone else had these problems.. The exhaust tips are also off center and kinda turned to one side any advice ??
    Jan 22 2014
    Fairfield, Ca
    CXRacing sucks. There is no quality assurance. I ran into the same problem, so I got a v-band welded in so the exhaust would bolt up. Then everything hung insanely low so I had my exhaust guy cut a little out of the downpipe and remount all of the hangers. Finally the exhaust sounded awful, so I lined my trunk with insulation and had an ultra queit resonator welded in were the factory second muffler was. I'm finally happy with the exhaust, but I spent the same amount as I would have if I did a custom exhaust in the first place.
    Veteran Member Four Rings adam044's Avatar
    Oct 31 2014
    2024 Jeep Wrangler Unlimited
    NH
    Well your first problem is you bought a cx racing exhaust. I agree with the above. My advice, return it. Go to a custom exhaust shop. Not sure how much you paid but you get what you pay for.
    2019 Audi RS3 - Black Mythos Metallic
    2014 Audi S4 - 6MT
    2008 Audi A4 S-Line Titanium
    2000 Audi A4
    Apr 29 2014
    Bellingham wa
    Sound does suck it's really fuckn loud.. I would put my stock exhaust back on but I freaking cut it off I bought it since a couple guys on here liked it and said it fit well...it was cheap I thought I would give it a try but now I wish I would have gone elsewhere.. I've had it on for not even one day and I freaking hate it it's so loud I can't even just drive with out it being really obnoxious it's actually quite embarrassing
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    I have it with a gutted OEM cat and the only issue I had was the gasket they sent for the cat to dp was a little off and I had to drill a bolt hole bigger. The tips are tilted just a little but I have no issues with it. Sounds great at WOT and it's quiet at idle.
    Jan 22 2014
    Fairfield, Ca
    Davdraco1 - We have different ideas of quiet!
    2005.5 A4 Avant; TSI cam follower conversion. Build Thread
    99.5 1.8TQM; Maestro, GTX2867R, and a ton more mods. RIP
    Build Thread
    Oct 10 2013
    State College PA
    Quote Originally Posted by B5A4coastie View Post
    http://youtu.be/hbQnN1ysZMg
    This is me just reving it.
    Sep 17 2005
    Fremont, California
    Sorry to hear you're having issues fitting your exhaust.
    We verify every 034Motorsport Test Pipe and High-Flow Catalytic Converter after production to make sure that they fit perfectly into our fixture, which was based off of a stock cat.
    Catless Testpipe, B5/B6 Audi A4 1.8T
    If sounds like a few people have had issues with that brand of exhaust, but you can probably just enlarge the bolt holes on the flange to get things lined up.
    Jan 22 2014
    Fairfield, Ca
    "you can probably just enlarge the bolt holes on the flange to get things lined up."
    The issue I had was the holes are right next to the welds, so enlarging was out of the question.
    Oct 10 2013
    State College PA
    It's tight but it will line up. I put the cat on the DP the slid it down into the car. Tough but I got it.
    Jan 22 2014
    Fairfield, Ca
    Quote Originally Posted by Davdraco1 View Post
    Again, there's just no quality assurance. There was absolutely no way I would make mine work. I got the studs and holes lined up, but the gasket never sealed (I couldn't get less than a 1/8 of an inch gap) between the TP and downpipe, the welds prevented me from drilling out the bolt holes any more.
    If you didn't have the same problem, then great for you, I wish I was in the same boat. It just further proves that you get what you pay for, sometimes it might work and sometimes it might not.
    Build Thread
    Oct 10 2013
    State College PA
    I hear ya man. Did you try contacting them to see if they would send you a new DP?
