Results 1 to 13 of 13
    Active Member Four Rings landfill's Avatar
    Nov 14 2013
    Pompano Beach, Florida
    3L twin GTX28 build partout. Parts for pick-up in CA. only - No Longer Available
    Cash only picked up in Orange county, California or delivered to you within reason. So within 300 miles. Might go a further for a big ticket item. Also if you really want something I'll consider finding another payment processing service.
    I will no longer use paypal. I'm fed up with them.
    I have a business opportunity amongst other things waiting. I also no longer have access to a 24/7 shop. So it looks like I will not be following through with my build. I was building a big 3L gtx28 twin turbo
    b5 s4. I will list so far only the things I have here in California or things that can easily be
    shipped from central Florida to me.
    To start :
    ARD full vband gtx2867 twin turbo kit
    asking $6,000 Paid much more
    Will include all brand new:
    x2 brand new Garrett GTX2867 turbo's
    x2 Tial 0.64 vband turbine housings-- black ceramic coated
    x2 Tial 38mm MV-S wastegates-- anodized red and come with all springs from Tial
    x2 ARD 3" v-band downpipes--- black ceramic coated
    x2 ARD tubular header exhaust manifolds (full v-band)--- black ceramic coated
    x2 ARD wastgate dump tubes-- black ceramic coated
    I can include a Tial Q 50mm BOV and custom PCV setup, and standalone all depends on what you want.
    2. Wavetrac front LSD differential for th e 01E quattro transmission
    Brand new never used. $1,000 FIRM I paid $1,350+
    3. Integrated Engineering forged connecting rods- $500 new never used
    Applications the 2.7t platform only
    4. Custom made JE pistons. $1,000 FIRM!
    Took 6-8 weeks lead time and cost $1,500
    Specs are as follows-
    Bore: 82.5mm
    Compression ratio: 10:1
    Stroke: 92.8 for 3L crankshaft
    Wrist pins: tool steel
    Coatings: Both - thermal barrier crown and tuff skirt coatings
    5. 3L crankshaft from a b6 a4-- $250 FIRM
    6. CAT billet 264/250 camshafts for the 2.7t engine-
    $1,200 FIRM $300 off
    7. BF Block with 3L machine work
    comes with billet main caps and possibly eurospec girdle if you choose
    specs:
    Hot tanked, mains line bored an honed, cylinders bored to 82.5mm, cylinders machine honed,
    head mating surface decked.
    8. 034 full iic standalone kit for the 2.7t platform-- Asking $2,250
    Comes with a brand new 4 bar iic 034 standalone ECU.
    Used 2.7t standalone harness
    Used 034 standalone relay box
    Used drive by cable conversion( DBC pedal, DBC throttle body, DBC cable)
    9. Custom 2 in 1 out vibrant 800hp intercooler- $500
    10. ATI b5 s4 dual steering column gauge pod -- $100 cash FIRM
    11. Depo smoke and clear tail lights no longer made-- $100 cash
    some minor damage
    12. depo black ecode headlights with RFB hid kit for b5's-- $125 cash FIRM
    13.(red) x2 Tial MV-S 38mm wastegates-- $250 a piece or $500 for both FIRM
    14.(red) x3 Fuel Lab 75 micron -an fitting fuel filters-- $100 a piece or $300 for all 3
    15. (red) x1 Tial Q 50mm blow off valve- $200 cash FIRM
    16. (red) x1 Fuel lab adjustable external FPR fuel pressure regulator kit- $200 cash
    21. custom s4 engraved and color matched analog gauges EGT, Oil PSI -- $100 FIRM
    22. Powder coated Enkei RPF01's with Nitto NT-05 tires-- $1,500 FIRM
    Specs: Enkei Rpf01
    Offset: ET35
    Bolt Pattern: 5x112
    Hub bore: 73mm
    Weight: 17lbs.
    Color: (custom) Powder coated flat gunmetal grey $100 a wheel
    Cost: $1500 with the custom powder coat when new
    Tires:
    Nitto Nt-05
    Tire Type: Passenger/Performance
    Overall Diameter: 25.43
    Section Width: 225
    Tread Depth: 8/32nds of an Inch at 6/32 now
    Aspect Ratio: 40
    Tire Brand: Nitto
    Rim Diameter: 18
    Car Type: High Performance
    Load Index: 95
    Load Range: 4 Ply Rated Reinforced
    Speed Index: W
    Weight: 24.2 lbs.
    Cost $650 for all 4 when new
    Hubcentric rings
    23. The driveshaft shop rear axle upgrade set brand new.
    $500 cash FIRM!
    25. Eurospec main girdle for 3L engine comes with all hardware. $350 cash Firm
    26. CNC ported 2.8L heads- $1400 CASH FIRM
    27. Full supertech valvetrain - $1,500 OBO
    +1mm valves, springs
    titanium retainers
    valve stem seals
    bronze valve guides
    single groove valve locks
    List Date: 2/13/2015
    For more info, click here to view the original listing: 3L twin GTX28 build partout. Parts for pick-up in CA. only
    This item is no longer available.
    Aug 14 2010
    Buchanan, NY
    So many things I want to buy... but I'm on the East Coast.
    Are the rods I-beam or H-beam?
    PM sent
    Oct 27 2011
    TOYS
    Philly Suburbs
    fly out west and rent a u-haul.
    GLWS landfill. Prepare to lose your ass on selling these parts, not many people want to pay good money for good parts in this platform.
    Veteran Member Four Rings Austonwerner4's Avatar
    Feb 01 2011
    00 S4 & 04 A8L
    MKE
    You're going to have a tough time selling when you are asking for pick up only but good luck.
    Single Turbo on it's Way
    PM me for 17z and 18z Caliper Needs
    Dec 26 2014
    Bay Area, Ca
    Good thing about California is there is a ton of people and a lot of s4 owners out here. I already picked quite a few items out, just waiting for a response from him.
    Aug 24 2014
    Newport Beach, CA
    If only I was closer to a build, so much of the best quality stuff money can buy for this car.
    2024 M3 Comp xDrive
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Noooooooooooooooooooooooo
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Dec 26 2014
    Bay Area, Ca
    Veteran Member Three Rings cinimod25461's Avatar
    Dec 04 2013
    CA
    Quote Originally Posted by OuttyinTheAudi View Post
    I saw this ad yesterday too. For some reason I thought he was in SoCal.
    Dec 26 2014
    Bay Area, Ca
    He probably posted it in multiple areas maybe to get exposure.
    Nov 14 2013
    Just to anyone in California I can meet people at halfway or within reason for a good $ amount of parts.
    It's not strictly pick up in OC. SF bay area is fine. Any CA. residents please get in contact with me if you
    have any questions. Thanks.
    Nov 14 2013
    Also if people out of state are interested I can process payments through Propay services.
    You can google them to read up on their services. Just no more paypal sorry.
    Veteran Member Four Rings johnnybravo!'s Avatar
    Feb 20 2006
    323 EASTLOS, CALIFAS
    Im local in east LA.. i'll buy your rods..pm'd
    SRM K24 - Bosch 1000cc - Rods - 2.8 Cams- RR STG 4 clutch - AA-built 01E+4:1 - OS Giken LSD - ER IC's - JHM SS - SRM DPs - Vibrant 3" - Vast W/M - RS4 Y-Pipe - ASP MAF - APR Bi-Pipe - Ohlins MS Coilovers - AP Racing BBK - 034 Rear Sway
    C7 A7 Silver- Jackal STG 2+E40 Shane Horning ported s/c Merc HX- Pierburg 100-3 - Eibach Springs- OZ 20" UL wheels/Michelin PS4s- Eurocode Sway Bar- Borla- IE Intake
    Audi. Truth in Understeering.
