Results 1 to 9 of 9
    Senior Member Two Rings Rsanchez184's Avatar
    May 27 2012
    2015 allroad
    Bethlehem, P.A
    battery replacing concerns
    i have a 04 a6 that needs a new battery a friend told me im better off going to the dealer to get it done because my radio and power windows, door locks etc can reset and not work anymore. the only problem is that the dealership is charging $194 plus tax plus a $20 core charge (which i get back) and $100 labor to swap the battery out.
    $330 is what im looking at with taxes after im refunded the core deposit. i dont want to pay them $100 for 10 min of work.
    i dont mind buying the battery from them but im looking for another solution to install it myself. anybody have any experience or tips
    Senior Member Three Rings peter1992's Avatar
    Mar 07 2012
    Laguna Niguel/CA
    my battery died a couple weeks ago, the radio was locked out, all i needed was the SAFE code in the manual and worked perfect after that, power windows stopped working for like a day and then they were back to normal, no problems noticed with door locks
    2001 S4, BW K04, 034 Stage 3, 485Designs 3" DPs w/ ASP TruDual, Wagner ICs, PSS9s, silver... but slick top!
    May 27 2012
    2015 allroad
    Bethlehem, P.A
    im wondering if i can have jumper cables attached to the terminals to keep the car on using another cars battery (like a jump) while i swap out the battery ?
    Veteran Member Three Rings Chris_s1's Avatar
    Apr 07 2014
    Miami
    I wouldn't do that. Check for your radio code, and if you have it youre fine. Switch them out like usual. The door locks/windows will be fine. I've changed mine twice. If you don't have the code, often time Audi will supply it for free. No sense paying all that money for a battery change dude.
    May 27 2012
    2015 allroad
    Bethlehem, P.A
    I found my radio code after looking thru a bunch of papers. I was just concerned about the door locks and everything else but I'm just going to give it a try
    Registered User Four Rings chris@fifteen52's Avatar
    Oct 04 2012
    Everywhere
    A few years ago I hook my battery cables to a jump box to install a new battery and didn't have to reset anything.
    Veteran Member Four Rings 02 A6 2.7T's Avatar
    Nov 19 2006
    Too much crap
    WA
    Quote Originally Posted by chris@fifteen52 View Post
    ^ X 2
    I used my booster box jumpered through the lighter socket with no issues.
    As a side note, I purchased Walmart Maxx H8 batteries for both my S6 and A6 (it's only listed for the S6, but it fits & works fine in both vehicles). It's under $125 with a 3 year full replacement warranty ... a no-brainer in my books ... http://www.walmart.com/ip/EverStart-...ttery/16782659
    2002 A6 2.7T - 6MT Crystal Blue APR Stage 1
    2002 S6 - 6 MT Black/black
    **SOLD ** 2002 allroad 2.7T 6MT
    Jul 01 2014
    Miami, FL
    Our cars have radio codes? A year ago when we picked it up it had a dead battery. And when I disconnected it, I connected it and just started driving and radio was fine
    Man I miss my AR....
    I will buy another someday... Or any audi with a 2.7...
    Veteran Member Three Rings Sparkstack's Avatar
    Oct 13 2012
    Bits of a 2003 S6, 1990 turbo Miata, 1996 LS400
    Naperville, IL
    Quote Originally Posted by Rsanchez184 View Post
    You need a new friend, as this one is broken.
    EDIT: the worst thing that will happen to the windows is that one touch up or down won't work. To reset that, put them all the way down. Release the button then press and hold the button down again. You'll hear a faint click. Now roll them all the way up. Release the button then pull and hold the button until you hear a click again. Now you should find one touch works again. Do the same for the other windows. Job done.
    2002 S8 - Daily driver.
    2003 S6 - R.I.P. (parting out - PM me if you need anything)
    1996 LS400 - Wife's whip. Thing is bullet proof.
    1990 Miata with FM Turbo - Pocket rocket.
