Results 1 to 19 of 19
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Lucas full synthetic oil stabilizer
    I was at an auto parts store recently getting oil change stuff and was talking to an attendant there (older gentlemen) and I was discussing how i think my turbo might be burning a little oil. He recommended Lucas full synthetic oil stabilizer. He told me that its good for the bearings in the turbo yata yata.. Seeing what yall's thoughts were on this stuff.
    Veteran Member Three Rings B44's Avatar
    Oct 27 2014
    It's bulshit stay away. Use a good oil like mobil or motul. Don't put any of Lucas bucas in.
    Aug 19 2013
    minnesota
    mobile 1 will coat your motor in yellow varnish stay away! Motul or nothing.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
    Veteran Member Four Rings Raus's Avatar
    Aug 17 2005
    B6 1.8TQM, Mk2 GTI
    Hmm, you're both actually righ.../wrong. It's one thing if I'm going to talk about my driveway snowblower or if there's more explaining to do. Try me, while I'm in a position to let you.
    Ich bin der Musikant mit Taschenrechner in der Hand
    Veteran Member Four Rings csosnowski's Avatar
    Sep 05 2010
    Computers
    Terrebonne, Oregon
    K03 have journal bearings, the Lucas helps keep the oil 'stuck' to them. It probably wont hurt.
    I've used it in many different vehicles including both of my current cars with no ill effects. I also run Rotella T6.
    Motul is decent oil, spendy for the same performance as the rotella. Mobil shears out reeealy fast and I don't recommend it for Audi turbo cars.
    If your turbo is smoking OP there isn't a lot you can do if the seals are bad. The stabilizer might mitigate it a little if you're running an oil like Mobil that shears really fast in our cars.
    2001.5 S4 Avant Sport 6MT - Brilliant Black - Nogaro Alacantra - SOLD
    2003 RS6 - Avus Silver - Black / CF - RIP
    2013 Q5 2.0t - Black - Black - RIP
    2004 A4 USP Avant 1.8t 6MT - Silver - Black cloth
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Rotella T6.
    Aug 17 2005
    B6 1.8TQM, Mk2 GTI
    Castrol when I get it on sale, even GC@$25/gallon once in a while. Rotella? Maybe I should, I'll take your word...would be so much easier.
    Dec 01 2007
    San Jose CA
    It's a full synthetic intended for turbo diesel engines so our lil 1.8ts just love it. Makes em purrrrr. Absolutely superb stuff.
    Aug 17 2005
    B6 1.8TQM, Mk2 GTI
    I know you're right...awesome.
    Edit: I meant to imply that otherwise I use Mobile1 synthetic. They're both never the cheapest, but more expensive than Rotella for me here...
    Jan 06 2009
    I switched from Liquimoly to Rotella T6. The rotella has significantly reduced oil burning.
    Sep 17 2014
    Lakeway
    Wow, People on te motorgeek forum talk up the T6 for their older 5 cylinders but damn looks like its good for all the audi's. Looks like I'll be making a switch soon. The turbo isn't making any smoke but I do have to put a qt in every 2000 miles of so.
    Veteran Member Four Rings Jay-Bee's Avatar
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    I have used some Lucas stuff before in small quantities, mostly to add some thick holding oil in our -30*C winter starts
    I ran T6 in my 2.0T, my passat 1.8T and my current B6 will be getting a fresh 4.5 liters as well this weekend.
    2008 Audi A4 Avant 2.0T Tip - Stage 2 94 octane Digitek Tuned
    [AEM Intake, CTS FMIC, B8 IHI Turbo, CTS test pipe, 2.5" Custom stainless exhaust, Rev J DV, H&R Springs, Bilstein shocks, S4 rear sway bar, B8 S-line seats]
    Aug 27 2013
    Philly
    FWIW, I generally run Rotella T6, but due to the winter I switched to GC 0-40. Makes start ups a little less easy and quite.
    Feb 25 2011
    B7 Avant 2.0T
    Calgary, AB
    Quote Originally Posted by SJorge3442 View Post
    T6 has a new 0w40 oil since last summer! Hit or miss finding it though, as I was able to grab a jug for my '11 2.0T Tiguan, but when i looked around again could only find the 5w40 for my A4
    Aug 19 2013
    minnesota
    My only problem is and I've said this a lot is that T6 is only SM rated where Motul is SN rated -SN being the highest oil rating at the moment, motul is also the official maker of the VW specification oils. Castrol is SN but I don't have experience with it, that titanium stuff may be worth a look. I've seen several cars run mobile 1 their entire lives and they are always coated in yellow varnish, including my own 2001 galant. I'd recommend staying away from it for that reason. Motul is really made to work with diesels as well but is designed for turbo motors. I get 5 liter jugs for around 30 bucks at CarQuest. This is my 2 cents on the matter. Oil stabilizer? For burning oil? hm. That bearing is worn... It's only getting worse and when you start noticing the oil loss it's soon to go. You may limp on it for a while but it's gonna blow.
    Veteran Member Four Rings xhackerekx's Avatar
    Jul 23 2007
    10S6C6_12Q7TDI_A4B6 3.0_VNL730
    Scranton , PA / Poland UE
    t6 only :)
    Veteran Member Three Rings Thumper3's Avatar
    Nov 27 2014
    1983 Porsche 944
    Missouri
    Quote Originally Posted by jacobsen View Post
    Mobile 1 is factory fill for some very impressive and expensive motors. I think if it's "good enough" for Porsche, the high powered Benz AMGs, Aston, ect, ect.....it's just fine in our Audi's.
    Yellow varnish? Be more interested in the life and other environments of those cars. Far from scientific methodology there.
    I don't touch anything Shell, but the first most important step is to use oil that meets the required specifications of the manufacturer, not just what you like. I generally stick with Mobile 1 and Castrol if I can, and have not had to deviate yet.
    '23 A4 Allroad Prestige | District Green | Black Optics | 034 Dynamic+ Springs
    '18 TTRS - Mexico Blue | APR Stg 1 e85/TCU Tune | RSe10 Bronze | Girodisc rotors front/Neuspeed 350mm Rears | Black Optics/Sport Exhaust | Red Calipers | Red Stitching
    '14 VW Touareg TDI R-Line - White | Euro paddle shift
    '12 VW Golf R - White | Stg 3 APR | Too much to list here
    Veteran Member Four Rings Audi 4 Life's Avatar
    Jan 16 2011
    06 D3 A8 Black/peanut with alcantara
    Earth
    T6 and Motul are not even close to the same, this topic has been covered many times and I highly suggest everyone who hasn't read this thread in full. T6 is a group 3 oil while motul is a group 5 which is the highest grade of oil that is ester based, group 3 oils are actually conventional oils marked as synthetics because they under go some special process. Its all covered in this thread which is a great read. But to sum up Motul is hands down the best. What is best for each car all depends on the driver and type of driving they do and how that car is cared for, each car is different the only way to know is to get your oil tested.
    http://www.audizine.com/forum/showth...wanted-to-know
    RIP - JHM B6 3.0 6MTQ USP Denim Blue/Black w/ Nappa Silver
    Current- B8 A4 2.0t S-Line Stasis Challenge Extreme Edition, Alcantara Headliner, ALA/ACC and 3g+ swap
    D3 A8 4.2 Black/Peanut (Daily)
    Aug 19 2013
    minnesota
    Motul 8100 Xcess and man 950/4 is the jacobsen approved oil program.
