Results 1 to 23 of 23
    Jun 15 2010
    Chicago
    Should I go with GIAC or APR for my B8?
    I know there's tons of info out there comparing these two but after searching, I've become more indecisive. I've only had my S4 for two months but I already got a Roc-Euro intake and AWE Track exhaust for performance mods. Now I want a tune. So my understanding is that for both, I have to remove my ECU and sent it to APR or GIAC for tuning? I just had a few questions for owners to help me decide but I'm just looking for whichever one puts out the most power really. My car is 6MT as well.
    Which is more user-friendly? I want a tune for 93 octane and 100 octane but how do you switch between them with either tune?
    What's the highest HP numbers for APR and GIAC for those who gotten a dyno done? Not the numbers posted by APR or GIAC but from actual users. 1/4 miles times would be great too but I usually see APR with better numbers.
    And it is possible to switch it back to stock tune without losing the tune?
    Jan 21 2015
    2015 Infiniti QX50
    Chi...
    As it stands, GIAC has the fastest trap speed at 11.5 seconds on the drag strip. They also have a DSG tune, and have mulitple versions, they have been around the block, it'll be reliable.
    APR, I'll let somebody else comment on this, my experience (I used to have their STG 2+) is quite biased, and very negative, they have been working on a DSG tune for over 6-7 months.
    Revo, they also offer a reliable tune, and have a DSG tune
    All above vendors offer an ability to switch the tunes yourself with a small OBDII device, I can't remember if EMCS supports changing the tune file, but there is APR mobile (Which is just a bluetooth OBDII device)
    Unitronic, after leaving APR, I decided to go with Unitronic for a few reasons. I have been challenged on my opinion, however there is data that proves this tune is much more aggressive, again no DSG tune, but its coming SOON, and these guys have an excellent reputation, huge in the Vdub market as well. They will be issuing Uniconnect shortly as well, which will allow you to change between tunes.
    Advise wise... Go with a tuner that is close to you, supports you well, and takes the time to listen to your concerns. most importantly
    !!!DO NOT ASSUME THAT FLASHING BACK TO STOCK WILL PROTECT YOU FROM TD1 STATUS!!!
    Even if you switch back to stock, they can tell that the file has been modified with a new timestamp. I consider flashing back to stock to be a "smoke screen" of sorts. It might work, or you may have an Audi tech who is also a clairvoyant.
    (Also, search the forums sir.. this has been discussed, MANY times).
    2014 S4 Lava Grey - DSG - Rear Diff - Dynamic Steering - Unitronic STG2+ - APR STG 2+ w/ DSG Tune - Euro Code AK - Euro Code Front/Rear Sways & End Links - Roc Euro Intake - Apikol Rear Diff Mount - 034 Trans Mount
    Veteran Member Three Rings Sean@APR's Avatar
    Feb 01 2013
    C7 S6
    Opelika, AL
    Quote Originally Posted by EWM AMIN View Post
    No, they can't. ECUs don't contain a real time clock, therefore, they cannot possibly apply a timestamp to anything. Further, they also don't have a filesystem. Without a filesystem, there's nowhere to put a timestamp anyway.
    Senior Member Three Rings JMUNFORD's Avatar
    Sep 26 2012
    B9 S4, B5 S4, Grand Cherokee Trailhawk
    Tampa,Fl
    Revooooooo
    Established Member Two Rings audiyyc's Avatar
    Jan 12 2015
    Quote Originally Posted by Sean@APR View Post
    So does this mean if you flash back to stock there is no way for them to tell?
    Veteran Member Four Rings cobrario's Avatar
    Oct 28 2014
    2015 Q5 3.0T, 2019 Toyota Tundra CM Limited , 87 Buick Grand National
    Northern VA
    Quote Originally Posted by audiyyc View Post
    In my conversations with Revo HQ they will not guarantee you won't get flagged if you flash to stock -but what they did tell me is that they've yet to have a car throw a TD1 that has been flashed stock. (I'm guessing it's the same for APR/GIAC)
    2018 Ara Blue RS3
    IG @cobrario_rs & @audivstheworld
    Jun 15 2010
    Chicago
    Chi...
    I'm leaning towards GIAC due to their pricing and now that you mentioned a GIAC tuned S4 has the fastest 1/4 mile time. However, the dealer I purchased my car from is an authorized APR dealer and Unitronic has a dealer close by too. Only downside for me seems that APR is the most expensive and the guy at the dealer I bought my car from isn't all that helpful. With Unitronic, it's the cheapest but it's still a new tune.
    And what's TD1? Not too familiar since this is my first Audi and I'm out of warranty anyways due to miles and got lots of mods already.
    Jan 12 2015
    Quote Originally Posted by cobrario View Post
    That is good to know. I am thinking of going with the Unitronic Stage 1+ soon here. Thanks for the info.
    Senior Member Three Rings boseephuss's Avatar
    Dec 02 2013
    2000 Dodge Durango (5.9L), 2012 Volvo XC60 T6 (Polestar), 2009 Kawasaki Vulcan 900 SE, Jet Boat
    Houston, TX
    You can also do EPL and flash it yourself, without a dealer. Not sure if the deal is still going, but the Stage 2 with the pulley AND the cord to flash it yourself was $1,100 shipped.
    2011 Premium +, Meteor Gray Pearl Effect, DSG, Roc Euro, Borla, Eurocode ÜSS, Eurocde Alu Kreuz, Alpha Boost Cooling System, EPL Stage II, EPL TCU Tune
    Veteran Member Four Rings saxon's Avatar
    Oct 16 2012
    pa
    As of right now the top two are apr and giac, both with cars less than 1/10 of a second apart in the 1/4 mile.
    No "need" for a dsg tune on a b8, however to get giac's strongest file they require you to get their dsg flash. This is not the case with apr making it the cheaper choice
    Current Ride- 2018 Audi RS3 Glacier White
    Unitronic- 10.0@136mph race prepped
    10.5@133mph winter tires full street prep
    Past cars 2010 s4-2012 Nissan GT-R -2014 S6-2016 s3-2015 M3--2011 b8 s4
    Jun 15 2010
    Chicago
    Quote Originally Posted by saxon View Post
    Mine is manual so no need for the transmission software for me at least.
    Jan 21 2015
    2015 Infiniti QX50
    I have a buddy who has the GIAC v2 tune as I mentioned before. He flashed his car back to stock went to the dealer, they hooked his car up to the diagnostics tool, which said the checksum date was different then original factory. TD1
    I just called an APR dealer in Toronto here, and he also confirms this "Flashing back to stock can be detected". You're also welcome to speak to him, I will PM you his info if you say so.
    You also understand that APR has YOUR file located on their network. EVEN if they flash you with their "BIOS" for their ECU. IT IS RECORDED.
    You can argue the fact that if you're buddy buddy with your dealer, you might be able to get away with it. But in Canada, Audi will hook your car to a computer EVEN ON your FIRST oil change to determine if anything was even PLUGGED IN to the vag com.
    So unless you can prove otherwise, or any tuner states "IF YOU ARE TD1 when flashing back to stock, your money back"
    Or we can bet your S4.. actually on second thought, why would I want a car that doesn't run 11.5? :)
    Maybe it's different for B8.5's?
    Senior Member Three Rings AzWildCat04's Avatar
    Feb 27 2011
    Campbell CA
    Dont do it. It makes the car slower;)
    Current: M2 Competition
    Past: 2016 Mythos Black 6MT - Black Optic Pkg - 034 Stage 1 - AWE Touring - 034 Trans Mount & Inlet Hose - Sport Diff
    2014 Ibis White S4 - DSG - AWE Exhaust + DP's - GIAC DSG Tune - GIAC Stg II v2
    2011 A3 Ice Silver - TI Package - Stock
    Past: 2005 S4 Ice Silver - Many mods
    Aug 07 2012
    Vancouver
    I am going to go with Unitronic. Their stock to stage 2 software with pulley is 1600 canadian... so I save around 500 bucks compared to stage 2 of apr and 1000 bucks compared to giac stage 2 (since DSG software is required at my dealer). Unitronic their BHP is rated at 450hp and 385 torque. (thats not including the exhaust and intake you may choose to install.
    Veteran Member Three Rings creativecody's Avatar
    Jul 20 2012
    I have a b8.5 APR Stage 2+ and have successfully flashed back to stock many times and gone to the dealer with no TD1.
    2013 S4
    APR Stage 2+ (Dual Pulley & Ultracharger) | APR CPS v2 | Milltek Resonated | Bilstein PSS10 Coilovers | Eurocode Alu Kreuz, Front/Rear Sways, Front/Rear Endlinks | Eurocode Transmission & Differential Mounts | SPC Control Arms | Stoptech BBK 380mm (front), Stoptech Rotors/Pads (rear), SS Lines | HRE FF01 19x9.5 et45 | Michelin PSS 265/35/19 | ECS Carbon Fiber
    Veteran Member Four Rings mrmomo313's Avatar
    Oct 27 2010
    Audi RS3, Redeye Hellcat
    Michigan
    Fastest b8's are tuned with GIAC and APR. Leaderboards tell the story. You can't go wrong with either of those for your b8. You don't have to send your ecu in anymore. Like mentioned previously, search man there is soooo much good info on here regarding both of those tunes. The new guys on the block have nothing to show other than some cute dyno sheets... I care about how the cars run on the street. Giac and apr have both proven their tunes work on the street/strip. apr still can't tune those 2014+ cars but that doesn't apply to you
    Jan 21 2015
    2015 Infiniti QX50
    Hey I just confirmed with an ex employee for Audi, who has opened his own shop, and is now an APR dealer... Long story short: I was wrong about the checksum... But right that they could find you.
    However, what he explained to me was this:
    Audi dealerships have the ability to read a counter, which indicates how many times a car has been flashed, and they can measure this against how many times they have indeed flashed you. If this number doesn't add up, they will flag you.
    Now he did say, if you had a "connect" at the dealer, they wouldn't report it. But can they see it, they most certainly can.
    BTW Saxon.. Do you work for APR? Im not sure they offer the most cost effective option anymore, un;ess you're getting an employee discount of sorts :)
    Veteran Member Four Rings Usa's Avatar
    Dec 23 2013
    B8 S4
    I just flashed back to stock from my APR tune today at a certified dealer from your website. I'll be giving it a day and then ill be going into the dealership this weekend so we'll see if the TD1 pops up or not.
    S4 (B8) DSG / Quartz Gray Metallic / VAG-COM / 3M Crystalline 70% sides 30% rear / Roc-Euro Intake / APR Stage II / Non-res Milltek / Alu Kreuz Stabilizer / Eurocode Front & Rear Sways & Endlinks / 19x9.5 AG M590 / PSS / RS4 Grill / P3 Gauge / Bilstein PSS10 / AMS Boost Cooler System / ENLAES Rear Spoiler & Diffuser / OSIR Front Splitter
    Jan 21 2015
    2015 Infiniti QX50
    Quote Originally Posted by Usa View Post
    Sweet!
    Keep us posted sir!
    Dec 05 2010
    Los Angeles, CA
    I have had the APR Stage 2 tune on my B8.5 for about 18 months and have been very happy with the performance and support from APR. I previously had two GIAC tunes. They were both great tunes however GIAC was horrible when I ran into a problem.
    http://www.audizine.com/forum/showth...GIAC+nightmare
    2019 Nardo with all OEM options
    Dec 27 2014
    I also want to read what happens. It is almost hit or miss from reading posts on this thread whether or not you can go back and forth and be relatively sure you won't get flagged for TD1.
    Jun 17 2010
    Madison WI
    In reading this post, I'm surprised that APR still hasn't quite figured out the 2014+ ECU as of yet. I was stage 2 APR in my 2010 S4 and it was amazing. I'm hoping that they get this figured out soon, as I recently placed an order for a 2015. I'd consider GIAC, but I have an APR dealer 10 miles from me, and would prefer to give him my business.
    2015 6MT S4, EPL Stage 2 no more...
    2010 6MT S4, APR Stage 2 no more...
    Veteran Member Four Rings espo4442's Avatar
    Jan 14 2008
    Carlisle, PA
    Anyone have any times with solo's tune? Their numbers seem to be on par with GIAC....
    2010 Brilliant Black/Magma Red S4
