Results 1 to 40 of 78
    Jan 22 2013
    00' A4 1.8Tq,01'Softail, 78' XS400E, 01' Blazer, 00' Passat GLX, 08' Caravan, 85' Sea Devil Cruisers
    Shirley/N.Y./U.S.
    Anyone running the T3 treadstone manifold?
    I've done searches which lead me to another audi sites. The few people said good things but couldn't find pics or talk to anyone. If your running 1 or know some1 running it, can you give me your opinion on it. I'm running a ATP mani & the room to run a 3" intake with MAF is beyond tight. Looks like the tombstone sits the turbo atleast 2" back for more room. If no good I'll get a SPA but already own the treadstone. Thanks.
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    never heard of tombstone manifold. have a pic or a link to it?
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    My best guess is he means T3 Treadstone:
    http://www.treadstoneperformance.com...Turbo+Manifold
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Jan 22 2013
    Shirley/N.Y./U.S.
    Dam I meant treadstone manifold. Can I fix my title now or am I screwed?
    Dec 13 2010
    FL
    Quote Originally Posted by Avant Nate View Post
    tombstone, treadstone. same difference lmao
    Jan 22 2013
    Shirley/N.Y./U.S.
    Ha both great movies too lol
    Oct 10 2013
    98 Civic CX Hatch, 2012 CBR250R
    State College PA
    Are there "bolt on" down pipes for these kinds of set up? I want to do a BT, but the elim kits are obviously the easiest bc they use the same DP and mounting position. But running s t3/t4 flange would flow so much better.
    Dec 13 2010
    FL
    i want v-band inlet
    Jan 22 2013
    Shirley/N.Y./U.S.
    SPA has a down pipe but not stock location like elimin kits. If I run the treadstone I'll have to have muffler shop build full exhaust from mani.
    Oct 10 2013
    State College PA
    That's what I'm worried about is the cost of a custom dp
    Oct 10 2013
    State College PA
    Quote Originally Posted by GrapeBandit View Post
    i want v-band inlet
    I've heard v-bands can be a pita sometimes
    Jan 22 2013
    Shirley/N.Y./U.S.
    The mark up of prebuilt DP's are very high any way. Just like pre made exhaust systems. I don't think $ will b that much more.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    If you need to run an MAF, why not grab a 3" 90 degree bend? I think a lot of people call them a cobra hose or something.
    Here, go to page 218 of this PDF. I am talking about part #2. This is a Cummins 4bt engine
    https://csapps.jlg.com/OnlineManuals...SI_English.pdf
    2020 SQ7- Wife's ride
    2008 RS4- I like this car
    2000 S4- Working?
    Dec 13 2010
    FL
    Quote Originally Posted by redline380 View Post
    cobra is not fully round, its flattened at one point to squeeze in tight spaces.
    Jan 22 2013
    Shirley/N.Y./U.S.
    I have a ATP 3" DP with v band to turbo. It costs like $350 from their website. A local exhaust shop can build it for no more if not less $.
    Oct 30 2008
    B5, B7, B8, 8V, 4M
    Big Lake, MN
    Yeah, I know that. The point is to use that hose and run the intake back up above the wheel well. The "cobra" intake helps you fit the piping in between the turbo and the headlight
    2000 S4- Working?
    Jan 22 2013
    Shirley/N.Y./U.S.
    With my ATP manifold I would have to run a corbra el. Treadstone performance has a 3" for the cheapest I've seen. But they restrict air flow. With the treadstone mani, it sits the turbo about 2" back so a full 3" elbow will fit.
    Dec 13 2010
    FL
    I ran atp mani with gt35r turbo. I made my own intake with 4" 90°silicone. I still have it laying around if anyone is interested in it. I can get pics over the weekend
    Jan 22 2013
    Shirley/N.Y./U.S.
    What year b5 r u grapebandit? With my 98', a full 3" elbow will hit my headlight.
    Dec 13 2010
    FL
    Quote Originally Posted by 99jimse View Post
    it was on my other car that I got rid of. it was a 2001, but same as 98. it touched my headlight, but everything fit
    Jan 22 2013
    Shirley/N.Y./U.S.
    I thought the 1 piece headlights fit more shallower then the 2 piece. I have a 00' n it looks that way but I could be wrong. Would love a pic if u r able too.
    Dec 05 2007
    Dougyfresh from the b6 section was like 5whp shy of 400who running that manifold on a 2L block and not sure what turbo.
    Veteran Member Four Rings ray4624's Avatar
    Nov 27 2010
    mass
    1. 99 and up? whats the deal with that?
    2. lifetime warranty...im interested
    Dec 13 2010
    FL
    Quote Originally Posted by Davdraco1 View Post
    how is that?
    Quote Originally Posted by ray4624 View Post
    whatchu talkin bout willis
    Jan 22 2013
    Shirley/N.Y./U.S.
    Seeriah, thank you, that will be the 1st person that I know of on this site thats running 1.
    Ray, it can be used with all 1.8t long. & transverse. Lifetime warranty & the knew 1s are SS. On the treadstone performance website they have pics of it bolted up & say it will clear a 4" intake setup.
    Nov 27 2010
    mass
    idk in the description is says lifetime warranty
    Jan 22 2013
    Shirley/N.Y./U.S.
    I am big with the search button. I've searched for days on web & UTUBE for people running it or atleast talking about it. I read on vwvortex about 3 guys running & loving it. There are no downpipes for it though so people stay away from it. But I can't see having 1 custom made for you costing more than what they ask for the premade 1's. The SPA 1 is like $300. I have a full 3" DP with vband from atp site that costs $350 n it's like 2' long. I finally had to start this thread to get more feed on it. Ringer-racing sells it too.
    http://www.ringer-racing.com/product...categoryId=492
    Jan 22 2013
    Shirley/N.Y./U.S.
    It says lifetime warranty on ringer-racing site as well
    Nov 27 2010
    mass
    i like the turbo/wastegate location.
    Would make for an easy downpipe build.
    Jan 22 2013
    Shirley/N.Y./U.S.
    Ray, that's what I said. With this mani u can actually keep a eye on wastegate & bolts. Same with the turbo & it looks like there's plenty of room to get to flange bolts. With most manifolds, either the wastegate or the turbo is buried. On my atp the turbo would have to come off to even get to the wastegate.
    Also site says VW is 99 n up. For audi it says all 1.8t
    Nov 27 2010
    mass
    Oh that all makes sense.
    I feel like it would be in a good place in the bay for me (cant run MAFless)
    I remember seeing this mani before but didnt give it much thought. Now that i am looking at some different turbo options it might be something i will look into.
    Jan 22 2013
    Shirley/N.Y./U.S.
    Ray, I'm in same boat as u, same 98.5'. For running MAF, like me, it's looking to be the easiest for room & maintenance. The atp I can say if a bolt comes loose it's a bitch to get to n u need for some to bend up ur own wrench to get to.
    You look like u have a nice setup for a DD. Are u not happy with power & want more. If so, what hp/tq. r u looking for?
    Nov 27 2010
    mass
    well i was happy. But i have an issue with not being able to pass up on deals because they are cheap so i bought a 2.0 stroker bottom end.
    I have a stage 4 UM tune with proMAF now (havent updated sig)
    so the weak point of my setup will be the turbo.
    I want to go with an EFR/fullrace mani combo but thats like 3 grand.
    The pag parts setup also looks really nice and i like the placement of it all.
    My car isnt a daily (i put about 1500 miles on it in 2014)
    I would like 315 or so at the wheels with the eliminator turbo. I would hope to be up around 400 with a solid full frame build and some fine tuning of my tune.
    I will probably get the stroker in and setup by april/may, drive the car all summer and then it will get garaged for a while as i am moving into the city. In the meantime i will be looking for deals on turbos, manifolds and whatever else i need to make more power...probably meth as well.
    Dec 13 2010
    FL
    I didnt have to take off my atp mani to reach the wastgate bolts.
    Veteran Member Four Rings vrmm's Avatar
    Nov 14 2011
    NW
    Fwiw the spa dp fitment was shit on mine at the very least. I know someone else actually sent it back to get fixed. I had to put a new hole in for the rear 02 since it was pointed straight into my tranny, the bracket was way off, and I had to cut the wastegate pipe off. It was off by at least an inch. That being said, it was still worth it given that it still looks nice n' shiny. Plus every exhaust shop I tried wouldn't touch it without a cat. Wastegate bolts are a huge pia on the spa mani. They back out every few months. At some point when its warmer I'm gonna safety wire them.
    Jan 22 2013
    Shirley/N.Y./U.S.
    Ray, dam u got some nice things going on. Hope u do a build thread. Your doing it the best way , waiting for the deals, & you know there out there.
    GrapeBandit, just saying with the treadstone it's right in ur face.
    Vrmm, thanks for the info on the SPA manifold & dp. Yeah, that wastegate placement looks like hell once installed. I was really thinking of going with them but definitely are hearing mixed reviews. Mostly with cracking & fitment but in all most are happy still with performance. I think it's worth going with the treadstone & I will this spring. If the exhaust shops make me get a cat (high flow), I'm ok with that cause NY is very strict anyway with emissions.
    Nov 27 2010
    mass
    I tend to wait for deals on everything. I enjoy spending money on my hobbies and if I can buy and sell some things to help with the cost it doesn't make me feel as bad
    I will probably make a thread but I am hesitant on wanting to open my build up for everyone to comment on.
    Dec 13 2010
    FL
    i will comment in your thread
    Nov 27 2010
    mass
    That's what I'm afraid of!
    Jan 22 2013
    Shirley/N.Y./U.S.
    Ray1- make the tread, it's for you anyways to document ur own build. As far as comments, there will always be neg 1's but u only have to acknowledge the positive or productive 1's. Plus even a negative comment can actually end up helping you.
