Results 1 to 13 of 13
    May 07 2014
    Installing coilovers; what other hardware should be changed?
    Hi guys,
    I just received a set of ST coilovers, and will be installing them as soon as the weather turns. Having said that, what other hardware is required when installing the coilover suspension? See the two links below from ECS, are these parts needed/suggested to be replaced?
    Front upper strut mount
    http://www.ecstuning.com/Audi-B8_A4-...2.0T/ES450649/
    rear suspension install kit
    http://www.ecstuning.com/Audi-B8_A4-....0T/ES2762760/
    rear shock mount, alone
    http://www.ecstuning.com/Audi-B8_A4-....0T/ES2724189/
    What did you guys/your mechanics use when installing your coilovers?
    2010 A4 2.0t quattro 6mt
    Jun 14 2007
    2000 S4
    Connecticut
    I highly recommend changing out the strut mounts.. I've had to re-do the coilover job because those were shot and was causing a really obnoxious creak when going over uneven grounds at a slow speed.
    Senior Member Three Rings BaysideS4's Avatar
    Feb 25 2004
    Tampa
    Rust proof coating
    2009 B8 A4 2.0TQ Premium Plus; 18" Sport Package; Meteor Grey; 125,000 miles / New OEM Piston Heads / Ecodes / Eurocode HFC / Revo / 15mm spacers / Bilstein B12 / Alu Kreuz / ÜSS Sway Bars / EC charge pipe and outlet adapter / 3.0TDI IC / RS5 pedals (hecho en China) / AWE exhaust / RIP: Rotamass pulley
    Previous:
    2007 RS4
    2005 S4
    2001 S4
    May 07 2014
    So you mean only the front strut mounts? Not the rear shock mount as well?
    May 07 2014
    Quote Originally Posted by BaysideS4 View Post
    Rust proof coating
    Yup, I definitely will spray all of the parts in there, and the coilovers as well in a liner coating.
    Veteran Member Four Rings o1turbo30v's Avatar
    Feb 06 2012
    Cars, guns, nuts and bolts
    Allentown, PA
    I didn't replace anything when i did mine and its been 50,000 trouble free miles, the only hardware you need to replace is included with the ST's (top nuts).
    Stage 1 more than you RS3
    Veteran Member Three Rings a2 4.0t's Avatar
    Jun 18 2012
    Jimmy Hoffa
    Ocean City / New Jersey
    If you're planning on a very aggressive drop you may want to consider front adjustable upper control arms to get the camber/alignment within spec.
    2012 A4 s-line
    |Carbonio intake | APR quad outlet exhaust with tons of RSC technology | AWE downpipe | s4 rear valence | Vogtland coil overs | Rotiform BLQ's | stage 3+ Chinese turbo whistle |
    May 07 2014
    Thanks for the feedback guys. I'll end up ordering the front strut mounts just for the heck of it. Roads here are absolutely horrific, so it won't be a very aggressive drop.
    Jan 24 2008
    Pennsylvania
    FYI, use a wax-based lubricant for the threaded portion of the coilovers, it works much better than petroleum based lubes. Something like Boeshield T-9
    2021 GMC Sierra AT4 Diesel
    Gone but Never Forgotten:
    Instagram: bluewings460
    Feb 19 2014
    RVA
    Dude! ive been wondering what that was.
    Veteran Member Four Rings bluetori's Avatar
    Jan 14 2010
    Discovery 4, RR7, SP Fireblade
    Georgia
    This may be my problem I have when turning into my driveway, although it has gotten a lot better since replacing control arm bushes.
    May 07 2014
    Quote Originally Posted by o1turbo30v View Post
    I actually got a used set of coilovers, so which part are you referencing exactly?
    May 07 2014
    Quote Originally Posted by Turbavanttro View Post
    Good tip. On my last ride, I did use a standard petroleum based lubes, and I've heard quite a few people suggesting that I slather the threads in axle grease. The Boeshield seems quite expensive for the amounts. Why do you suggest this, and how does it perform in winter conditions?
