Results 1 to 17 of 17
    Veteran Member Three Rings lyates1987's Avatar
    Sep 17 2014
    Lakeway
    Weird thing happened on my way to work.
    Alright so I hope this is just a case of bad gas but I was on my way to work this morning and I was rolling from a stop and accelerating and either in 2nd or 3rd gear there was a "bump" of some sort that happened but I felt it through the gas pedal and it slightly jolted my car. It did it again while accelerating from a stop a couple mile after the first time. This time i felt 3 or 4 of these "bumps." I took it real easy every time I accelerated from a stop from then on but it didn't do it again. I couldn't pinpoint if it was an engine issue or transmission/transfer case issue. Anyone experienced this madness before?
    Veteran Member Four Rings MikeWire's Avatar
    Mar 08 2007
    Air and water
    SATX
    Motor mount?
    -Mike
    @countdowngarage
    2015 Porsche Macan S | 2021 Atlas SEL-P | 1972 VW Bus | 1965 VW Beetle
    SOLD - 2017 VW GTI APR Stage 2
    SOLD - 2001 Allroad - 6 speed swap thread
    SOLD - 2003 A4 1.8TQM Avant Atlas - 5 speed swap thread
    Established Member Two Rings Arctic Audi's Avatar
    Aug 04 2009
    2013 Audi Q5, 2009 A4, 2007 Buell Firebolt XB12R, Motobecane 29er
    Pennsylvania
    I had this issue before and it was related to one of the coil packs going bad.
    Veteran Member Four Rings Furly's Avatar
    Dec 19 2013
    snub mount?
    i'd get down there and check all the mounts. they may be deteriorated.
    Audi Club Bay Area
    Sep 17 2014
    Lakeway
    Quote Originally Posted by Arctic Audi View Post
    I kinda thought that too, like a cylinder had dropped for a second.
    Jun 27 2011
    I'd vote mounts. A misfire wouldn't make an audible clunk...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Sep 17 2014
    Lakeway
    It wasn't really "audible." It was a slight jolt slowing my car down for a split second. I felt it through my gas pedal too.
    Veteran Member Four Rings MacFady's Avatar
    Aug 10 2011
    330i ZHP
    Prince Edward Island
    Sounds like a misfire to me but I'm assuming you don't have a CEL since you didn't mention it? Sounds like it's only happening when under boost? This describes my symptoms when I first had a coil pack go but if I would get a CEL if I made it happen 3-4 times consecutively.
    It's important you re-iterated the "thump" isn't audible.
    Sep 17 2014
    Lakeway
    Quote Originally Posted by MacFady View Post
    Yea it happened while boosting. It hasn't happened again. I do have a CEL on due to a short to ground at the VVT connection and the upper coolant temp connection at the rear flange. I need to get that fixed since having this damn CEL on isn't helping my gas mileage. I was going to convert to the R8 coils eventually. If I remember correctly you have to trim some rubber to get those to work I think.
    Oct 02 2006
    Wadsworth,OH
    Seems like a misfire to me. Scan to see if you have any misfire codes. Then pull the related coils and plugs. Replace if needed.
    Jason
    Aug 10 2011
    330i ZHP
    Quote Originally Posted by lyates1987 View Post
    I do have a CEL on due to a short to ground at the VVT connection and the upper coolant temp connection at the rear flange...
    Have you scanned since this happened to see if you have P030? code? If you do, swap said coil to another cylinder to see if you can replicate the symptom and rescan to see if it changes cylinders but again, to me it sounds like a coil.
    Jun 27 2011
    ahh, yea, in that case it does sound like a misfire.
    -CP
    2017 Q7 3.0t
    Sep 17 2014
    Lakeway
    i've heard r8 coils work great with the 1.8. Was thinking about going this route. Good idea?
    Jan 10 2013
    03 A4 Avant 1.8TQ
    South San Francisco, CA
    I have R8 coil packs right now. Furly replaced mine for me, just use blade to cut rubber boot from the old pack and slide on to the new pack and oila
    Jun 27 2011
    I'm running 07k coil packs, similar to the R8 ones. They're better than the regular b6 coil packs for sure.
    -CP
    2017 Q7 3.0t
    Sep 17 2014
    Lakeway
    Quote Originally Posted by WB650 View Post
    At one point I remember reading a thread about the proper way to do that. The search is on!
    Sep 17 2014
    Lakeway
    I think the write up for swapping the boot out expired. It's the boot at the top correct? not the one at the end inside the coil?
