Results 1 to 24 of 24
    Registered User Four Rings FCPEuro's Avatar
    Jul 30 2009
    Milford, CT
    Post OEM Part Number Look Up (Genuine Audi)
    Hello,
    If you're looking for a specific replacement part for your VW or Audi let me know and I'll be happy to search through some of the resources I have access to.
    I can also look up superseded numbers and check to see if a part is still in production from VW/Audi.
    Dave
    Junior Member Two Rings
    Feb 19 2013
    Provo, Ut
    b5 audi a4 quattro 1.8t, driver rear abs sensor
    Jul 30 2009
    Milford, CT
    8D0 927 807F, ABS Speed Sensor Rear
    We have Pex, Bosch and Genuine VW Audi brands available
    https://www.fcpeuro.com/products?keywords=8D0927807F
    Dave
    Feb 19 2013
    Provo, Ut
    Awesome! Thank you for the quick response!! Not a bad price either! Will be purchasing shortly.
    Sep 28 2006
    Lexington
    98 b5 a4 1.8t quattro manual
    Clips that hold on the under hood mat on, a/c high pressure switch, all power steering hoses
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    K04 | GIAC PC-16 | FMIC | 3" Neuspeed Exhaust | ATP Test Pipe | Raceland Coilovers | N75 Race | Forge 007 | K&N | VDO Boost Gauge | A8 BBK | Rear Fog Light Mod
    07 A4 3.2LQ - K&N
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    pilot bearing for a 1998 Isuzu Amigo 2.2L 2180CC 4cyl
    or
    pilot bearing for a 1993 Mazda B3000 SE pickup 3.0L 2983CC V6
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Sep 28 2006
    Lexington
    Also, does the aeb engines take a oil pan gasket or just silicon?
    No Slip Just Grip!!
    98.5 A4 1.8TQMS
    07 A4 3.2LQ - K&N
    Dec 13 2010
    FL
    Quote Originally Posted by AudiTurbo View Post
    gasket
    Jul 30 2009
    Milford, CT
    893863907C01C Hood Insulation Clip -- 2.89 (Genuine VW Audi)
    8A0 959 483AA, A/C Pressure Switch
    I have this part available in Genuine VW Audi for $95.99.. I just need to get it added to our site.
    8D0 422 891C, P/S Return Hose
    Cooling Pipe to Reservoir
    https://www.fcpeuro.com/products?keywords=8D0422891C
    8D1 422 891J, P/S Return Hose
    Steering Rack to Cooling Pipe
    https://www.fcpeuro.com/products?keywords=8D1422891J
    3B0 422 887, P/S Suction Hose
    https://www.fcpeuro.com/products?keywords=3B0422887
    8D1 422 893AL, P/S Pressure Hose
    https://www.fcpeuro.com/products?keywords=8D1422893AL
    Dave
    Established Member Two Rings okar's Avatar
    Sep 25 2008
    2.8, '63 beetle,66LandRoverIIA
    seattle
    thanks Dave,
    Good to have a genuine parts source. Chinese parts can be faulty right out of the box!
    Veteran Member Four Rings pbcrazy's Avatar
    Feb 06 2013
    VA
    Not a request, but is that a picture of a b5? I've never seen a b5 that has springs? (#13) on the hood
    98.5 Audi A4 1.8T Quattro | 5 Speed | AEB | Laser Red
    | FrankenTurbo F21L | United Motorsports Stage 3 | 630cc Injectors | 3" MAF | ICM Delete w/FSI Coils | Scorpion 2.5" Catback/RAI 3" Test Pipe | Forge 007 | 034 Silicone PCV | Alzor 349 | FMIC | ECS RA4 LWFW/S4 Clutch/S4 P.Plate | AEM | Krauto | etc.
    Dec 03 2014
    1999 Audi A4 Quattro Avant 1.8t 1998 BMW 328iC 1986 BMW 528e
    United States
    Quote Originally Posted by pbcrazy View Post
    Those look like screw-in rubber bumpers.
    My cars
    1998 BMW 328iC
    1986 BMW 528e
    Jul 30 2009
    Milford, CT
    Audi refers to #13 as a Jounce bumper, part number 8D0823481. It's used to cushion underside of hood when closing and also acts as a support once the hood has been closed.
    Jul 30 2009
    Milford, CT
    Any other part requests?
    May 18 2014
    Massachusetts
    What is the purpose of 13 in the diagram you posted?
    Jul 30 2009
    Milford, CT
    Veteran Member Four Rings crazexr7's Avatar
    Sep 10 2011
    1998.5 A4 2.8 Quattro, 2001 Porsche Carrera 4, 1968 Cougar XR7
    Bristol, CT
    Will you guys be doing another group buy for control arm kits in the future? I'm planning on buying a set around late April or early May
    Jul 30 2009
    Milford, CT
    Yes, we'll have the group buy active for Audizine. Just send a PM and we'll get an order placed for you.
    Dave
    Sep 10 2011
    Bristol, CT
    Awesome thanks!
    Dec 05 2007
    Noticed the B6 guys have an OEM clearance sale going on. Anything for the B5?
    Jul 30 2009
    Milford, CT
    Absolutely, there should be items mixed in for the B5 chassis as well.
    Audi Clearance Parts
    Dave
    Dec 16 2014
    Irvine, CA
    I need a part number for the hard plastic vacuum hose that goes from the Blue Vacuum canister to the intake manifold on a 1998 A4 2.8L AHA Quattro Manual
    Jul 30 2009
    Milford, CT
    PM sent
    Jul 30 2009
    Milford, CT
    Anyone searching for anything else?
