Results 1 to 9 of 9
    Established Member Two Rings A4Mods's Avatar
    Aug 12 2014
    2009 Audi A4 Prestige, 2004 Ford Taurus, 2013 Chevy Malibu, 2017 F150 Sport, 2012 CBR600RR
    Green Bay WI
    Rear Brake Rotors & Rough idle
    Is there a way to check if I have 245mm or 255mm without taking off rotors? I had surgery on my hand a few years back and temperatures have been well below freezing and I don't have a heated garage. So taking the wheel off to check would cause me about 2days of bad nerve pain in my left hand/arm. I've searched high and low and haven't found a sure fire way to check without measuring.
    2004 Audi A4 1.8T Quattro
    Also I still have a pretty rough idle I've been trying to cure but it's not throwing a code. The only code I have has been lean on bank 1 since I installed a test pipe and the rough idle has been happening since way before that.
    Things replaced.
    Coil packs
    Spark plugs
    All check valves
    Breather tube
    N75 Valve
    MAF sensor
    Diverter Valve
    I recently found a youtube video of a guy with the same problem, he replaced the breather tube and breather valve and it fixed it. So when I order my brakes I'll be ordering the breather valve as well. (Only $12 so why not)
    Any other possible solutions would be greatly appreciated.
    Jun 27 2011
    Brake Rotors: http://www.audizine.com/forum/showth...=1#post7357617
    99% chance you have 245mm rotors. My 2004 1.8t had 245mm and everyone else I know with a 1.8t has had 245mm as well.
    When I replaced all my PCV stuff, and check valves and vacuum lines, my idle improved significantly. I know my 3-way check valve was leaking, but my SJP was pretty much shot as well. Replacing those helped. Its annoying spending all that money on stupid plastic parts, but think of it as a ~8 year maintenance item...
    -CP
    2008 2.0t S-Line Ti 6MT Avant
    2017 Q7 3.0t
    Former USP CLUB MEMBER #136
    Aug 12 2014
    Green Bay WI
    I suppose I could have a local parts store measure the thickness without taking the wheels off. If they're 12mm I have 255, if they're 10mm I have 245. Still need answers to the idle problem. =/
    Veteran Member Four Rings imnuts's Avatar
    Aug 12 2009
    '21 F-150 Powerboost Lariat & '14 Acura RDX
    Dirty Jerz
    Have you checked your vacuum lines and PCV hoses and valve?
    Established Member Two Rings UofU_USP's Avatar
    Dec 09 2013
    04 A4 USP 1.8T 6MTQ,09 Acura TSX 6MT
    SLC,UT
    there is a sticker on the car, in the trunk pretty sure that has the codes. 245mm is code: 1KD, 255mm is code: 1KP, look by the spare tire
    Jun 27 2011
    Quote Originally Posted by UofU_USP View Post
    Thats literally what I posted above, except the OP apparently didn't want to follow the link. Or read my post at all.
    -CP
    2017 Q7 3.0t
    Apr 07 2011
    Come on Charles you know we all just scan over your posts. You know, because all you post is nonsense.
    Dec 09 2013
    SLC,UT
    Guess its just easier to put the info here and skip the link? My bad :/
    Jun 27 2011
    Oh no I wasn't mad, haha. More that the OP apparently didn't want to click the link with the info he needs. I guess I could have copied my post from that link, but what's the fun in that.
    Lulz.
    -CP
    2017 Q7 3.0t
