Results 1 to 10 of 10
    May 24 2014
    United States
    Test-pipe supporting mods??
    I just got a test-pipe for my 2.0t b7 A4 and i was just wondering if there were any supporting mods that i needed to do at the same time if i wanted to install it? thanks!
    Jun 17 2013
    jersey city nj
    stage 2 tune or o2 sensors bungs or cel will be on
    Veteran Member Four Rings Andrew149's Avatar
    Apr 19 2009
    Modesto/CA
    2008 Audi A4 Testpipe Downpipe: http://youtu.be/x0_8hRc-vjk
    Sent from my HTC One_M8 using Tapatalk
    2012 Audi A6 3.0t
    2019 GTi 2.0t 6 speed
    2013 Touareg VR6
    Veteran Member Four Rings Solarsuplex's Avatar
    Aug 20 2011
    Seattle Wa
    A full exhaust helps... haha. Plus then you dont have to take apart annoying bolts twice.
    -James
    F T W L T B D W I C T W
    Moonlight Blue - B8.5 S4
    Brilliant Black - B7 A4
    Senior Member Three Rings Levski's Avatar
    Jan 22 2014
    Dublin, OH
    Would make it easier in the long run if you did the downpipe now as well
    08 Audi A4 Quattro TIP / S-Line / Ocean Blue / Bi-Xenons / APR Stage 2+ / JHM HPFP + FMIC / ECS Snub / RS4 RSB / P3Cars / APR CAI / LED DRL, License, Interior / RS4 Covers / R8 Coil Packs / Spulen TIP / 034 HFC / tt DP / Magnaflow / Cupra R / 034 mounts / Thor Skid / H&R / Hawk HPS / Goodridge / Stoptech / DV+
    Aug 26 2011
    Louisville, KY
    ZERO required IMO. I've been running just a test pipe for the last year with no adverse results.
    Aug 31 2011
    C7 A6 3.0T - D4 A8L 4.0T
    Lathrop
    Oct 22 2014
    Cherry Hill , New Jersey
    You dont really need any. I have the JHM testpipe and i have had 0 issues with it. The 'J' spacer prevents cel's and i have yet to get one so the thing works. Just make sure you have all the hardware, gaskets.. Some people go stage 2 which tells the ecu that there is no cat to prevent cel's.. If you get a test pipe other then JHM you might need to go stage 2.. To get rid of the cel
    May 24 2014
    United States
    Ok i just wanted to make sure thanks!!!!!
    Aug 26 2011
    Louisville, KY
    I'm running the 034 Unit just for reference, and also using the 034 O2 Spacer with no CEL's for over a year. 100% stock otherwise, complete down to the paper filter.
    Oh yea.....buy the gasket and bolt kits. They're worth the extra cash (or at least they were on my 140k mile car).
