Results 1 to 14 of 14
    Apr 06 2009
    Charlotte,nc
    1996 A4 2.8 to 1.8t swap build
    Hello Everyone,
    The story behind this car is basically when I was going through a rough time in my life I was offered this car and it made my life and family transportation so much easier and has lasted me so long that I became attached to it and even when offered money to sell I couldn't let it go.
    First off the setup I currently have is as follows:
    -1.8t AEB drive by cable engine, With Tuned ECU
    -1.8t radiator support
    -1.8t radiator
    -1.8t Power steering resevior and lines
    -1.8t AC condensor etc parts.
    -1.8t Exhaust parts
    -Entire engine. No trans
    -2.8 Trans to 1.8t
    The plan is
    1)Install Pilot Bearing and (Ordered) Clutch Kit
    2)Pull original Engine from transmission
    3)Mount 1.8t Engine to 2.8 transmission
    4)Install 1.8t parts in place of old (ie. Rad support, Radiator, PS ines etc.)
    4)Wire it all up swap out ECU and connections
    5)Start her up and pray it works.
    Feel free to let me know if you have any other suggestions.
    Pictures Below.
    Before
    After
    Apr 14 2014
    concord nc
    I still wanna ask but eh...Lol
    Feb 27 2011
    Winnipeg
    do you have the 1.8t exhaust to swap in as well or are figuring it out after the engines in the car?
    Apr 14 2014
    concord nc
    And i have that clutch. ..it was strong for five minutes and for some reason went soft. ..idk how to explain it. It was squeal wheels to nail gas and dump in like 2 miles
    Apr 06 2009
    Charlotte,nc
    Yes, I have the full exhaust from the 1.8t as well. So that clutch no good? should I got with a stage 1 or 2? any suggestions on clutch?
    Veteran Member Four Rings Avant Nate's Avatar
    Dec 23 2009
    2001 Audi Allroad 6MT,1999 Yukon Denali, 1987 4Runner
    Boulder, CO
    your forgetting the main reason, bigger turbo.
    99.5 1.8T QMS: GT2860RS .63 T3, PSI T3 Mani, Turbosmart 38mm EWG, Unitronic 415, Forge 007,Treadstone TR18 FMIC, Walbro e85 450, FSI coil conversion, 3" DIY Magnaflow/Dynomax VT exhaust
    Depo ecodes, DDM slim 6000k, VDO boost gauge, PLX AFR, Greddy profec B EBC,
    H&R sport springs, 034 rear sway, 034 rear diff carrier, A8 fronts,18x8 OZ Superleggera
    Next up E85, efr 7163 or gtx3071r?
    01 allroad 2.7t 6mt, GIAC stage 1
    Apr 06 2009
    Charlotte,nc
    Nate that is one of my biggest reasons going 1.8t but right now the plan is to swap it with tuned chip and drive it while I accumulate bigger turbo and internals for install. Currently its still got the 2.8 and running strong so It may not be a bad Idea to do before I put the thing in.
    Dec 10 2013
    Borden, Ontario, Canada
    A 97 1.8t parts car would be your best bet. Engine wiring harness and everything miscellaneous you may need.
    Wiring will be your biggest hurdle.
    I'm subscribing as I may want to do this as well in the future
    EDIT: pictures of the car would also be much appreciated
    IG: 24_et
    Sold:
    2010 Deep Sea Blue S4 6-spd
    RIP:
    Oct 30 2009
    Miami, FL
    You'll either need a parts car, or at least access to a few junked cars because there's a ton of small miscellaneous parts you'll need to swap over. I can't possibly list them all since there's so many, it's one of those things where you figure out as you go along. Off the top of my head you're forgetting intercooler & bracket and fuel lines, there will be much more though. When I did the swap the actual work was less than 20% or the time it took, the rest was tracking down parts and waiting. Wiring will probably be a PITA because you have a 12v with the hitachi ecu which uses completely different plugs to connect to the rest of your car, you might end up having to pull your dash and swap the dash harness with one from a 97 or 98.
    2018 S5 Coupe - stock for now
    Veteran Member Four Rings GrapeBandit's Avatar
    Dec 13 2010
    FL
    r.i.p.CASABLANCA B5 1.8t
    r.i.p.BRILLIANT YELLOW B5 30V
    PCV? Just dump it on the ground!
    Apr 06 2009
    Charlotte,nc
    Oh thats something I didn't know. So should I pull entire wiring from motor car, still have access to all of it
    Apr 06 2009
    Charlotte,nc
    Also I do have all intercooler parts, but undecided if i will swap in ebay kit yet. If there is anything else you can think of i would appreciste it. I still have access to parts car so I can still grab.
    Apr 06 2009
    Charlotte,nc
    Thanks grape very handy, i did not find thay in my searches. Nice to find an actual post with real info haha
    Apr 06 2009
    Charlotte,nc
    Just got my Dash, Heater core replacement, and Power steering lines. Now just waiting on clutch kit.
