Results 1 to 16 of 16
    Unitronic k04 file with F21 turbo
    unitronic told me that is was a problem is that true ?
    ''their file is DONE only for BW K04''
    May 20 2010
    That's probably an insurance in case something happens. I'm not really on the up and up on B5s, but business-wise, I am having to deal with a lot of vendors that won't guarantee their products if it's taken beyond what it was qualified to do. Running a different turbo certainly would be in that category.
    Jul 07 2009
    Alberta, Canada
    Different size turbos.
    Ya, they say it for a reason.
    Jul 10 2012
    buffalo
    Quote Originally Posted by JVD View Post
    give me your ECU code I can double check their tune database to see if there is a FT21 tune listed
    Mar 22 2013
    AK
    A KO4 tune will overboost like crazy due to different WG spring set up on the Franks
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Quote Originally Posted by Drehmoment View Post
    This. Not really the "size" that is the issue more or less the fact that the WG pressure is different 12psi vs 8 on a K04(usually)
    I mean I guess if you really wanted you could run it with an MBC..But don't be cheap get the right software for hardware. Contact Daz he does good tunes and for a great price.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Veteran Member Four Rings CELison's Avatar
    Feb 23 2010
    Emmaus Pa
    Quote Originally Posted by 01audia4 View Post
    This. The wg cracking pressure is different.
    B5 S4- K24s, built bottom end, E85 - Gone
    B9 S4- EPL/AWE
    996TT X50 - Marski 700hp
    Veteran Member Four Rings AudiTechS4's Avatar
    Oct 19 2007
    2000 S4
    Scottsdale , Az
    why do these threads keep poping up . get a tune for what you have . simple as that. you have k04's get a k04 tune. you have something else tune for that . what is wrong with people lol its pretty well documented that the turbos has different cracking pressure on the wg and yest people cant read through a few posts and figure it out
    2001 Audi S4 Manual - Nogaro Blue/black - Full AWE stg 3 kit w/ manifolds,h&r coilovers,jhm trans rebuild,UUC VM3 exhaust , 2.5" dp's - Needs Love - Got some love now 442awhp and 512 awtq
    2004 Audi S4 Avant manual - Silver/black - 2.7 swapped ,k24's and srm side mounts
    Established Member Two Rings b5s4carlos's Avatar
    Jul 21 2014
    slammed mkv jetta
    Run it, blow your turbos and then realize they aint for f21's because obviously their for K04's
    Dont cheap out do it right the first time around to avoid headaches later on.
    vroooom vrooooomm
    Apr 07 2011
    Home of the mighty beaver
    I cant believe anybody on this forum would run unitronic after the BS they put some of us through
    Stage 2 Banner Advertiser Four Rings John@Unitronic's Avatar
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    As you discussed with Steve, we do not have a specific "production" calibration for use with the Bosch 550cc injectors and Frankenturbo's you're currently running. We do offer a Stage 2+ calibration for OEM inj, OEM MAF housing and RS4-K04's, but unfortunately as others have mentioned already in this thread, due to the difference in WG preload/response, that cal. won't provide optimal results, allow for proper boost control, or run well with your Bosch 550cc injectors. Sorry! If you have any other questions, please don't hesitate to contact me directly; or Steve if you prefer to discuss in French.
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
    Veteran Member Four Rings zillarob's Avatar
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    Not saying its the best idea with all the fairly priced options nowadays, but parallel mbc might get you by.
    There are only 2 things needed to make an Audi work properly - Duct tape and WD40. If it moves and it shouldn't - Duct tape. If it doesn’t move and it should - WD40.
    it is not a question to be cheap i never realise that when a swap the turbo. i bought a s4 suppose to have BW k04, when the turbo go bad 2 or 3 week after i swap to used F21 i found locally. the turbo remove was k03..... anyway
    Quote Originally Posted by John@Unitronic View Post
    no hard feelings against john I just wanted to check with the comunity , always good to have a second opinion ( no sur that sentence is correct i use google translate ;) )
    Veteran Member Four Rings FlyboyS4's Avatar
    Jan 06 2007
    Mk7 Golf R
    FL
    Quote Originally Posted by Bouhlee View Post
    Looking strictly at the turbochargers, not fueling, it would depend on what boost profile they tuned the K04's for. A tame dc like APR ran would not have the F21's operating much beyond 24-25 psi. I used a k04 wgdc tune to start tuning on my F4H's and nothing extreme happened, it just wasn't as good a match as you'd aim for when tuning the car.
    Actually i boost 20-22 psi so i guess that can do the job for couple of week, I hope so haba
