Results 1 to 4 of 4
    Established Member Two Rings bailor's Avatar
    May 26 2012
    Temecula, CA
    A PCV valve job lasts how long?
    So I've had this car for almost 3 years now. The first thing i did is replace the PCV valve and crank case breather and tubing. It was pretty bad. Everything still looks good, but I'm starting to have oil push up through the oil cap. Could it be getting backed up in the pcv system again? Or could a worn oil cap be the problem?
    Veteran Member Four Rings a4darkness's Avatar
    Dec 01 2007
    San Jose CA
    Had similar issues, turned out to be the gasket and cap. Picked up this nice Porsche one from USP, did the job and looks great.
    http://www.uspmotorsports.com/Porsche-991-Oil-Cap.html
    May 26 2012
    Temecula, CA
    Quote Originally Posted by a4darkness View Post
    Thanks.. I'll give it a try. If it's this easy I'll be really happy!
    Aug 19 2013
    minnesota
    I really am surprised how cheap the pcv valves are in this car. Mine for instance is the small T style. If you use cheap oil you can bet you're coking up your pcv stuff and that small passage in the PCV i'd bet cloggs real good. Just my 2 cents... For the millionth time I hate the plastic parts.
    APR exhaust, HFC, 225 injectors, APR II program, KO4, South Bend II endurance clutch and SMFW, Forge Tip+piping, Apikol SMIC, Stern motor+trans mounts, Stern Snub, 034 street density arms, Hotchkis sway bars, Lemforter links, Bilstein B8, B7 S4 calipers, powerstop braided lines, Centric drilled rotors, PowerStop Carbon Fiber pads, Timken bearings, Gates racing timing belt, DENSO IQ01-27 plugs, R8 coils, Motul Xcess 5w40, MANN 950/4 filter, gear300, CHF202, Motul RBF 660.
