Results 1 to 18 of 18
    Active Member Two Rings audikid101's Avatar
    Aug 31 2011
    Douglassville, PA
    96 A4 2.8 AFC clutch pressure line
    So I just replaced my clutch and as soon as i started driving it, suddenly the pressure line right by the slave cylinder for the clutch gave out and i need to replace it. Do anyone knows where to find it?? I just simply can't find it nowhere and dont know where to turn. I had to drive to school (UTI) today shutting the engine off at every stop and putting it in gear then starting it to keep going. I NEED HELP ASAP Thanks
    Deactivated Two Rings
    Aug 27 2009
    Minnesota
    http://genuineaudiparts.com/partloca...layCatalogid=0
    This may or may not be the line you are referring to. Maybe try to email the website and/or talking with your local audi dealer to try and find a part number. Sounds like a rare thing to go wrong. Never heard of it happening before.
    Aug 31 2011
    Douglassville, PA
    Thanks for the input. Hopefully this can get somewhere
    Jun 30 2008
    Erie, Pennsylvania
    There is a vin split on this part. This has to do with whether the car came with metal clutch master and slave, or their plastic (Eeww!) counterparts. Early cars (96 and early 97) got the metal parts, and late 97 and up got the plastic. The difference is the connections on the end of the line. The metal units use a threaded flare fitting, the plastic crap uses a "push-lock" aka "quick-connect" type fitting.
    A 96 will definitely have the threaded fittings.
    Part number: 8D1-721-465
    Examples:
    http://www.ecstuning.com/Search/8d1721465/ES433295/
    http://cgi.ebay.com/ebaymotors/97-98...-/130465920623
    http://www.ebay.de/itm/ws/eBayISAPI....sid=p2992.m753
    You don't want to end up with the new style (8E1-721-465-J):
    Examples:
    http://www.ecstuning.com/Search/8e1721465j/ES441687/
    Good Luck!
    Veteran Member Three Rings SS92's Avatar
    Jul 11 2011
    2012 2.0T GTI
    Charlotte, NC
    Getting the new line in is going to be hell and a half without dropping the transmission. Ask me how I know
    2000 B5 A4 1.8T ATW GT2871r, Unitronic/Maestro tune, RaceTec FMIC, etc... - > FOR SALE
    Registered User Four Rings
    Feb 08 2011
    B5 A4 2 liter HTA3586r
    Phoenix, Arizona area
    Actually the hardest part is trying to get the thing out from the battery tray. Other option would be to just replace it with a USP Motorsports SS Line kit.
    This setup but without the metal slave since you already have that stock in your car.
    I run that kit in my A4 1.8t, along with the CM FCV.
    Jun 30 2008
    Erie, Pennsylvania
    ^Yeah, but that's not going to work with his metal master. Unless USP Motorsports will make him a custom line with threads on both ends. They probably would, too.
    Having installed this line during my 5-speed swap (with engine, trans and brake booster/master removed), I completely agree that a braided metal line would be *so* worth it if you are doing it yourself (and probably even if somebody else is doing it!).
    Depending on where the break in the line is, it may be possible to repair it in place. I used a compression fitting on mine to convert a newer "push-lock" line to a threaded fitting. Thus I am running a plastic master with a metal slave using an OEM line. The compression fitting is used to splice the metal part of the line like so:
    You can see in the photo that I've used that fitting to effectively replace the last 6 inches of the OEM line with a piece of my own making. But if the leak is in the rubber hose part...you're hosed.
    Feb 08 2011
    He can always ask them. If the threads are the same on both ends then all it would need is the adapter they already use at the metal body and the AN fitting on the line.
    Aug 31 2011
    Douglassville, PA
    Thanks to all for your input.. it was really needed
    Aug 31 2011
    Douglassville, PA
    LoL how do you know?? i want to know because i dont want to drop that trans again
    Jul 11 2011
    2012 2.0T GTI
    Charlotte, NC
    Quote Originally Posted by audikid101 View Post
    Removing the line alone on my 2000 A4 sucked enough (I was on jackstands) when I installed a SS line and metal slave that M-Hood posted above. But removing it was terrible, I got so frustrated I jut cut it in half and yanked the fuck out of it until it came out.
    Feb 08 2011
    Quote Originally Posted by SS92 View Post
    Which is why I left the stock metal line in my car, it was hard enough to make it move just to plug in/out of the master cylinder. When I am ready to remove it I will have to cut it out too.
    Jun 30 2008
    Erie, Pennsylvania
    Wow, I really owe it to BlkBullit. He is the very nice guy who pulled this line off his parts car and sold it to me at a very good price. I was in a bind and needed this to continue with my swap. He pulled the part and shipped it the very next day after I asked him about it. Arrived in perfect condition, just in time. Based on all your guy's accounts, it sounds like this was not an easy task! (So glad he didn't cut it!)
    Sep 10 2014
    Temeucla, CA
    Sorry to revive this dead thread but i didn't want to start another with the topic already on the table. I just replaced my stock plastic slave cylinder and the clutch line pops out during bleeding process when pressure is built up. I was looking around on USPs site and they have a SS line for OEM slave, http://www.uspmotorsports.com/USPAud...lutchline.html, and was curious to see if anyone has installed it on their b5 5spd.
    Feb 08 2011
    Quote Originally Posted by 98LownSlow View Post
    I know a bunch of Audi owners that run that line, no issues with it. I have been running their SS line with the metal slave body for a few years now.
    Sep 10 2014
    Temeucla, CA
    Quote Originally Posted by M-Hood View Post
    How difficult was the process to install the new line to the master? I have time today to get it all put together just couldn't find a good how to thread. Much appreciated
    Feb 08 2011
    Pretty easy, just have to make sure that the plastic sleeve and 0-ring seal are lined up correctly, plus you get the fitting pushed in all the way.
    Apr 04 2016
    Vancouver
    Revive #2
    I just ordered this: http://www.uspmotorsports.com/Drivet...speed-02A.html , hoping it fill fit my 96 from before plastic slave days.
    It has a 12x1 thread, same as this one (i think?).
    Would that work?
