Page 1 of 4 123 ... LastLast
Results 1 to 40 of 129
    Nov 05 2009
    Denver
    Bosch injectors too short?
    Has anyone encountered this? When the factory clips are installed the bottom injector o-ring is barely seated in the manifold. I contacted the importer and they said do not use the factory clips and it will be ok; so basically float the injector there? Seems sketch. Looking at cups for the bottom, does that affect injector spray pattern and atomization? Will the fuel spray just hit the cup and drip into the manifold (exaggeration)?
    Veteran Member Four Rings hibiscusS4's Avatar
    Sep 09 2013
    2000 hibiscus s4 , 2000 allroad
    Ev14s? Contact o34 they make injector hats for them that make them sit properly
    01 s4 f21 on meth sold
    00 s4 hibiscus six speed swap pj ko4
    00 allroad pj ko4
    Rip mike aka Daz Dillenger
    Nov 05 2009
    Denver
    Thanks biscus. Apikol makes some too and they are local. Do you have any experience using the hats? any issues?
    Veteran Member Four Rings Meow's Avatar
    Mar 08 2012
    MI
    there are 4 different length ev14 injectors, 40mm, 48mm and 60mm and one with an extended tip.
    The 'Standard' EV14 is appropriate for the S4 (for those curious, the 'Compact' EV14 is appropiate for the RS4), therefore a 48mm, o-ring to o-ring, should be used if the option is given.
    Some companies sell the smaller ones with hats to extend them 8mm to fit correctly.
    RIP Daz, you will be missed.
    Veteran Member Four Rings 01audia4's Avatar
    Jan 31 2008
    Philly home of the cheesesteak
    Quote Originally Posted by Meow View Post
    I am almost positive the standards are still too short. I had them; while they fit in the rail the o-ring just sits on on the plenum(when fully seated into the rail); the injector can be pushed down much further into the plenum(this is where the hat would come into play).
    Someone correct me if I am wrong.
    2001 A4 2.8-->1999 a4 1.8tq 220K-->2000 K04 S4--->2001 F21 S4 eating corn w/ stock rods
    Nov 05 2009
    Denver
    The overall injector height was roughly the same as factory but the bottom o-ring barely sat in the manifold. I'll post up some pics later tonight if I remember. We're picking up hats today.
    Mar 08 2012
    MI
    Quote Originally Posted by 01audia4 View Post
    Since you asked, I will correct you, you are wrong. There is no need for hats or fuel rail spacers or anything other than the factory clip when you use the standard length ev14s, unless you have a bent or broken parts.
    Nov 16 2010
    2kS4, 84gli, 84caddy dsl
    WetSide, WA
    I endorse this message
    Feb 06 2012
    Lake Lanier, GA
    x2
    Jan 31 2008
    Boom if that's the case why does this standard EV not sit high enough on the rail when FULLY seated into the plenum?
    If I clip the injector into the rail first then bolt down the rail the o-ring isn't fully in the plenum, but it is enough to seal. So my thoughts are I need hats?
    I've driven both my stage 3 cars without hats using standard ID or EV injectors. But I still believe they can be seated deeper into the plenum..rather then just barley sitting there.
    Mar 08 2012
    MI
    What makes you think they are not fully seated? Do they leak when you boost leak test?
    Shave the mounting point for the fuel rail down a hair if you reallllllly feel it is necessary.
    Sep 09 2013
    I will be running them with hats soon on my build so i could tell you after. I didnt know other
    Companys made hats. Meow from your post the 48mm ones do not need hats?
    00 allroad pj ko4
    Nov 05 2009
    Denver
    My kit came with the extended injectors and I needed to use spacers on the fuel rail; nbd. My friend got the same kit and his appear to be the compact version. He's just going to swing by Apikol and pick them up and not bother messing around with a floating injector. Thanks guys.
    Link to apikol
    http://www.apikol.com/index.php/fuel...h-adapter.html
    Nov 16 2010
    WetSide, WA
    For the standard length like m-9593-g302:
    Best way is to use the hats (they go on the top) and spacers for the rail.
    This will fully seat the orings and everything is snug so you dont need the clips. Up to you.
    You can usually just install them directly and use the clips. This is how I usually install them.
    You will need to check that the lower oring is far enough down to be in the bore, not just sitting on the tapered part.
    Only seen one that was a prob, and that was because the fuel rail was tweaked from incorrect install of longer injectors.
    For the longer m-9593-lu47:
    Not installed these before. Guessing you just need the spacers under the rail and they will fit just fine.
    Mar 08 2012
    MI
    Quote Originally Posted by zillarob View Post
    I prefer just using the standard length ones without hats and without spacers and just using the factory clips. Holds really well for me...
    ^just like that.
    Nov 16 2010
    WetSide, WA
    Like this
    Works fine if the rail is good.
    If the rail had been previously cranked down on the longer injectors without spacers, or apefisted fktards used a jackhammer to get it off the mani, it can tweak the rail and cause probs. Just need to 2xcheck these things if dropping them straight in.
    Mar 08 2012
    MI
    lol, that would suck.
    Nov 05 2009
    Denver
    Ahhh, hats on top. Cool. Thanks zilla
    Nov 16 2010
    WetSide, WA
    I had a feeling that is where you were heading.
    Dont worry, you arent the first
    Nov 05 2009
    Denver
    I guess that's why the are called hats and not socks :D
    Nov 16 2010
    WetSide, WA
    If he just gets the hats, Lowes has the spacers and longer bolts.
    Senior Member Two Rings falkor923's Avatar
    Dec 04 2006
    B5 S4, 2010 Maxima
    De
    Ahhhhh.......memories!
    Nov 16 2010
    WetSide, WA
    Quote Originally Posted by falkor923 View Post
    Registered User Three Rings S4M3's Avatar
    Jul 12 2007
    B5 S4,B8 S4, E55 AMG
    Atlanta, GA
    www.Solomotorsports.net good place to get them :)
    Nov 16 2010
    WetSide, WA
    Lol, too many threads here where people have problems doing it like we do.
    I got a feeling jackhammers and fktards were more of a prob than the hardware in those cases.
    And then you have the people who sell the hats telling you the car is going burst into flames if you dont use them.
    Dont think this is entirely a $$ thing and I understand where they are coming from. Prob a good idea to play it safe and treat everybody like jackhammer using fktards in case somebody does actually burn their shit down.
    Dec 04 2006
    B5 S4, 2010 Maxima
    De
    One of my bolts backed out a bit last summer and was blowing fuel out between the rail and injector top. I didn't smell it either....just noticed I lost a 1/4 tank of fuel in 20 minutes hwy cruising off boost. The pad under the hood was soaked. I figure they'd been in about a year or so.
    Nov 16 2010
    WetSide, WA
    Wow
    Dont you have the hats, spacers, and the clips?
    Dec 04 2006
    B5 S4, 2010 Maxima
    De
    Wow
    Hats, spacers......the clips would have prevented the gap there. may have opened up at the manifold. Hard to say. Glad it wasn't worse.
    Aug 05 2011
    Memphis, TN for now!
    I used clips on top and used the slightly larger audi orings on the bottom. The rings that come with the injector are ever so slightly smaller than the audi ones.
    Sep 09 2013
    Not to thread jack but i looked up the part number on my injectors and there the standard size
    So these should clip in fine without anything else?
    00 allroad pj ko4
    Nov 16 2010
    WetSide, WA
    Look like the standards in meows pic.
    They should be fine just dropping them in, but in rare cases people have had probs.
    You will need to check that the lower oring is far enough down to be in the bore, not just sitting on the tapered part of the mani.
    Sep 09 2013
    Ok will do im gonna see if i can get outta the snow then report back
    00 allroad pj ko4
    Nov 16 2010
    WetSide, WA
    Oh yeah, can help to use oem orings.
    They seem to be a little thicker on the cross-section.
    Feb 20 2010
    TT225, Touareg, Tiguan, TDI, A3, RS6, Jetta
    Brighton, MI
    OEM rings are thicker. I like to put them in bottom for better fit and seal.
    01 Allroad Tiptronic, TCU tune, mild stg 3 (350 HP) tune (stock injectors) KraftwerkTurbo TM1. Lower, Wider. Custom tip vent pod with Podi
    02 Allroad 6 spd, Kraftwerk Turbo TM6, 750cc, 3" MAF, piggy, FMIC, CM stg 5 (hate). 30 psi at 3600 rpm. Needs stronger rods (coming).
    05 Golf TDI
    Looking for 2001 A4 1.8T quattro manual with blown motor
    www.regulatorfix.com
    www.kraftwerkturbo.com
    Sep 09 2013
    well as soon as my clips come in ill let everyone know how my standard ones fit.
    speaking of that anyone have a set of electrical clips for them they wana part with before i order them new?
    00 allroad pj ko4
    Nov 16 2010
    WetSide, WA
    It works fine both ways. Pick the one you like best.
    Account Terminated Four Rings
    Dec 03 2009
    PNW, Washington
    Standard Ev14's here with fatty OEM o-rings used on the bottom. Factory clips work just fine.
    Nov 16 2010
    WetSide, WA
    What we have been trying to tell you is it doesnt really matter.
    If you think it would be better, run the hats. That simple
    Feb 06 2012
    Lake Lanier, GA
    I've installed countless EV14's. I never used hats.
