Page 2 of 12 FirstFirst 1234 ... LastLast
Results 41 to 80 of 461
  1. #41
    Senior Member Three Rings iceboss23's Avatar
    Jul 18 2009
    2010 S4, 2001 allroad
    Silver Spring MD
    Quote Originally Posted by John@Unitronic View Post
    We did physically dyno (using a MAHA LPS3000 Dynamometer) a stock car to get a baseline, and then dyno'd each stage as we flashed it including our Stage 2+ Performance Software with our Supercharger Pulley Upgrade. That is precisely what is shown in the dyno graphs above.
    So I am going to ignore all the trolling and go right to the point here. Why use conversion at all? Just show us what the dyno read at the wheels stock then at each stage. Using conversions just muddies the water and makes things less credible.
    |2010 S4|Prestige|Phantom Black|DSG|ADS/Sports Diff|Nav|B&O|APR Stage II+|Stoptech rotors & SS lines|Castrol SRF|Eurocode Intake|Eurocode AluKreuz|Eurocode USS sways and endlinks|034 Trans mount|19" Peelers|various VAG-COM mods|
  2. #42
    Mar 15 2014
    UK-->Toronto (Mar 2015)
    ?? Doesn't look like there's black magic conversion going on here -- they dyno'd on a MAHA (extremely respected and widely used Dyno in Europe) and shared each stage from stock to stg 2 here. Relative results all hold true as they're same car, same Dyno etc...
    Edit -- I don't have a Uni tune at this point
  3. #43
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by iceboss23 View Post
    if its the dyno i'm thinking of.. you take the wheels on.. and connect it at the hub.. it then reads at crank.. not wheel
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
  4. #44
    Veteran Member Four Rings Leor604's Avatar
    May 25 2010
    Vancouver
    Yeah, I'm not too concerned whether the readings are CHP/TQ or AWHP/TQ. I am sure that, whatever the conversion factor to convert from one to another (essentially drivetrain loss), Unitronic is applying the same conversion to all stages of the tune so, regardless of the ultimate number, the gains are valid.
  5. #45
    May 25 2010
    Vancouver
    Quote Originally Posted by doug97gxe View Post
    No, crank hp is with the engine out of the car. Anything connected to the hubs/wheels is not crank hp.
  6. #46
    Stage 2 Banner Advertiser Four Rings John@Unitronic's Avatar
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by Shamu View Post
    Thank you for your input, Shamu. As Shamu said, MAHA Dynamometers are one of of the most respected dynos throughout the worldwide automotive profession/community and are widely used in Europe. I don't want to get this thread too far off topic, so if you're interested in learning more about how MAHA dyno's measure output, please feel free to email me directly to discuss further or check out some of the documentation available on MAHA dynamometers for further information.
    That's a Dynapack, which measures output at the hub, removing the unsprung mass of the wheel/tire from the "equation", but doesn't measure output at the crankshaft.
    UNITRONIC — Performance Software & Hardware for your VW® /Audi® / Porsche®
    Web: GetUNITRONIC.com | Tel: (866) 341-2447
    Follow us on: Facebook | Instagram | Twitter
  7. #47
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by Leor604 View Post
    ahhh thanks
    Present:
  8. #48
    Veteran Member Three Rings soslower's Avatar
    Apr 23 2012
    Audi
    SO CAL
    Andy deal to jump ship from my APR Stage 1?
  9. #49
    Jan 29 2013
    2011 Q5 2.0, 124" HD Dyna Wide Glide
    Philadelphia, PA
    Quote Originally Posted by soslower View Post
    I second this?
    2010 Phantom Black S4 Prestige DSG, Silver Nappa, APR stage 1, Milltek Non-res, AG M510s, BC Racing BR series coilovers
  10. #50
    Veteran Member Three Rings svra42.8's Avatar
    Oct 11 2006
    Bartlett, Illinois
    Can you flash back and forth from stock at home or do you need to visit a Uniteonic dealer for it? Such as if I wanted to do the pulley install myself.
  11. #51
    Oct 11 2006
    Bartlett, Illinois
    Never mind the last post. I see you need to go to a dealer still.
  12. #52
    Mar 31 2014
    2013 Porsche Cayenne Turbo
    Our Stage 2+ Performance Software is optimized for 93 octane, but can be used with 91 octane for folks that don't have access to 93. Stage 2+ results on 91 octane will be a bit reduced than the above figures considering the lesser fuel grade.
    Thanks! I'm in. If you can get your pulley to your dealer in Broomfield, CO, that would be awesome.
  13. #53
    Veteran Member Four Rings RWD2quattro's Avatar
    Dec 29 2011
    Lexus IS250, Volvo 850R, Ford tractor
    The Bay
    Do you conduct adjustments to ECU parameters (timing and/or boost) when using 91oct when compared to 93oct on stage 2+?
    I'm a bit confused with the statement above, usually timing is pulled when dealing with lesser quality fuels.
    Please advise.
    BMW M4CS, Frozen Blue, Full XPEL, CCB, DCT. Dinan HAS kit, Fall Line end links, Hotchkis sway bars, K&N filters, CF interior goodies. More goods are coming...
    Gone: 2014 S4, Audi Exclusive DRM, 6MT.
    Gone: 2012 S4, Brilliant Black, Prestige, S-tragic.
  14. #54
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by RWD2quattro View Post
    Please advise.
    Yes, the ECU will apply correction (pull timing). There is a limit on how much the ECU can adapt, but using quality 91 octane shouldn't reach those thresholds.
  15. #55
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by Laxinthe303 View Post
    Give a call in to Autosport Werks and place your order!
  16. #56
    Jan 27 2013
    NW burbs Chicago
    Very impressed with this tune. Did my 1st one tonight for a very patience and great customer Jay. Drove 2hrs and spent 4hrs with me the best thing was our smiles during the 1st drive.......thanks for the help today John
    VW Master technician
    Authorized Unitronic dealer
    13 CC and 15 Jetta Sport
    2016 Glacier White S3 PP+
  17. #57
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    Quote Originally Posted by vwauditek25 View Post
    It's always a pleasure, Alan!
  18. #58
    Dec 29 2011
    The Bay
    Thanks John
  19. #59
    Mar 31 2014
    They're waiting on you to deliver pulleys! :) That's who I called.
  20. #60
    Jan 27 2013
    NW burbs Chicago
    Unitronic Performance Software & Pulley Upgrade for 3.0 TFSI
    I've learned you just have to call to get things done
  21. #61
    Veteran Member Four Rings DGVR6's Avatar
    Aug 03 2014
    Queens
    Any race file in the works?
    C7.5 S6 P+ Mythos Black
    [email protected] 103oct Stage 2 100 File/RACECHIP
    [email protected] 100oct Stage 1 93 File
    APR Tuned Stage 2 ECU/TCU | Roc Euro | Catless Downpipes | Milltek Resonated
    Previous
    B8 S4 [email protected] 93/e85 93 map - Unitronic Stage 2 B8 S4 6MT
  22. #62
    Established Member Two Rings kandrei's Avatar
    Feb 13 2014
    windsor, ontario
    Yes you get a better tune.
  23. #63
    Apr 03 2008
    MK3 TTRS, B9 RS5
    Laval, QC
    PM sent.
    Quote Originally Posted by DGVR6 View Post
    We'll have options available once UniConnect is available for this platform.
  24. #64
    Registered User Four Rings Jay@JXB's Avatar
    Dec 21 2014
    2018 Silverado 3500 HD DRW, Bart the Big Ass Red Trailer.
    Milwaukee
    Just got the Pulley Kit and Stage 2+ done as mentioned above at VW of Crystal Lake in the west Chicago burbs on my '14 MT. Had a good experience there and John was very interested in the process as we went along. A recap:
    Pulley is a bitch to get on. 400F didn't do it. Alan got it on finally at 475F in the toaster oven while freezing the shaft with a compressed air canister. The heat and repeated handling took its toll on the finish of the pulley. The paint chipped in a few places in contact with the belt. I wasn't too keen on it but Alan backed it up and wrote on the service order that if it causes any issues he'll replace the pulley. I'd say to people doing this at home try it a little lower in temperature than 475 and focus on getting the shaft cold.
    About the results:
    1. The car is fast. Like really fast. Stock was pretty quick, this is really quick.
    2. 1st gear is near unusable at WOT with traction control on since the weight shifts to the back so much on stock suspension. You can really feel the nose lift; something you couldn't feel on the stock setup. I'm definitely gonna have to upgrade suspension. 2nd gear is an absolute joy. Stock would put your body back in the seat, now you have to hold your head forward too.
    3. Due to front end lifting, steering is pretty squirrely while accelerating. Goes with the territory I suppose...
    4. 4th gear is my new favorite gear. At 2500 rpm and 40 mph it pulls HARD. As hard as 2nd pulled before the tune. It's the perfect gear to lurk behind that Prius coming out of the stoplight until the passing lane opens up. Then shazam, 40 to 100 without lifting a finger! Showed them. Yeah.
    5. Supercharger whine is increased ever so slightly. Roc-Euro intake shows up this week; can't wait to make is scream!
    6. Exhaust is louder; there's more exhaust going through it...weird.
    7. Somehow, moving the gear lever from 2nd to 3rd is easier. Part of me thinks I'm making this up but I swear there is less resistance in it. **shrug**
    8. Probably my biggest complaint, which is actually pretty minor: the way Audi has Dynamic mode set up the car drives normal up to a certain point when depressing the accelerator pedal, then BOOM, power when you cross that threshold. This is fine on the stock tune. It makes the car feel fast; like when you step on it it gives you everything, makes it feel responsive. Add 75hp to the wheels and this becomes a bit overwhelming. Fun no doubt, but certainly not practical. I autocross with the car, and the key to going fast out of corners is to NOT use the accelerator pedal as an ON/OFF switch. This becomes very difficult when your throttle is set up to be an ON/OFF switch in the name of "sportiness".
    So to the Unitronic guys I pose the challenge of straightening out dynamic mode to make better use of the accelerator pedal. What do you guys think? Can you make it happen?
    9. Oh yeah, donuts are sooo easy now.
    Overall, I am very satisfied. Bill was 2200 USD with tax (3.5 hrs of labor I think, could definitely be done in 2 to 2.5 I think if you get the pulley cooking early). Definitely unleashed the car; I'm very excited to get in on a track. Highly recommend the tune; good value for your $ on a $50k German car, and I feel the guys at Unitronic are genuinely interested in customer satisfaction.
    PS also don't put the pulley on backwards *cough* Alan *cough*, make sure you visualize your motion before you grab it out of the oven. It all happens quick and you risk damaging your pulley if you have to force it back off backwards.
  25. #65
    Established Member Two Rings SeaBassHWD's Avatar
    Feb 18 2014
    Lincoln Navigator, B8.5 S4
    United States
    Quote Originally Posted by jbullin2 View Post
    About the results:
    Very good review. can't wait til Uniconnect comes out. Hmmm... Maybe I'll just get it now and then get it'sconnect when its out. I just did my 15k service so it'll be a while til I hit 25k. Decisions decisions
  26. #66
    Mar 15 2014
    About the results:
    To point 8, what does it feel like if you drive it in comfort or auto mode -- more manageable? This makes it sound like not so linear power delivery which is slightly odd given the supercharger instead of turbo setup...and your comment about "not practical" is concerning :(
  27. #67
    Jul 03 2004
    Atlanta
    Comfort is more linear and dynamic I think is all in the first 30% of travel
  28. #68
    Jan 27 2013
    NW burbs Chicago
    About the results:
    Of course the backwards pulley will never happen again. But man do you have to do it fast and if you just grab and go things happen. The job should be 2-3hrs all said and done. For my first one It was a learning experience with a understanding customer. Thanks for the write up
  29. #69
    Mar 15 2014
    Quote Originally Posted by droopy1592 View Post
    30% of pedal travel is quite a bit before it kicks hard...and I can see what jbullin means about impractical if this truly is the case. Do you have the tune and for what year s4?
  30. #70
    Dec 21 2014
    Milwaukee
    Yes comfort mode feels normal still. I don't want to give the wrong impression here. For normal daily driving and spirited driving there's no negative effect; in fact driving in dynamic mode is a blast with the tune! I'll be getting to the track in a couple weekends and I'll report back after. The flaw isn't with the tune or the supercharger, it's the way the throttle response is set up in dynamic mode. I believe it looks something like this:
    So when you get to the steep part (because it's a supercharger and there's no turbo lag and a ton of power) it takes off quickly. I imagine comfort mode to look something like this:
    Neither are linear like a normal accelerator pedal. I just think there will be some learning curve associated with using the throttle correctly coming out of a corner in dynamic mode.
  31. #71
    Mar 15 2014
    ^ thanks for the clarification -- @John/Uni, anything you can do to the current program to smooth out the dynamic-mode throttle response setting?
  32. #72
    May 25 2010
    Vancouver
    So if I understand correctly, you don't have the tune, have not driven the tune and, based on ONE opinion, are asking Unitronic to modify dynamic throttle response to resemble comfort mode. A bit premature, IMHO.
  33. #73
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    +1
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
  34. #74
    Jan 21 2015
    2015 Infiniti QX50
    Hey guys,
    So after a huge day of serious driving through the city, I tried to get a dyno done at Neetronics here in Toronto. I got a call from Andy who informed me that he couldn't get readings from S4's 2011+, and that he didn't have an OBDII connection to read the RPMS which will give Torque... He couldn't provide me with any sort of timing, only AWHP. I didn't see the value in this, and will schedule another dyno shortly. I'm going to try my luck at Magnus or try to find somebody in the west end.
    What I will say is that I went to a competing dealer of Unitronic to get my parts installed. I told him I switched tunes, and he confirmed that the new tune was definitely more aggressive then the previous tune he had installed for me.
    He wants to become a Unitronic dealer now.
    2014 S4 Lava Grey - DSG - Rear Diff - Dynamic Steering - Unitronic STG2+ - APR STG 2+ w/ DSG Tune - Euro Code AK - Euro Code Front/Rear Sways & End Links - Roc Euro Intake - Apikol Rear Diff Mount - 034 Trans Mount
  35. #75
    May 06 2014
    Las Vegas, NV
    No one should ask for modification to a product they don't own, and second, if Dynamic mode is too aggressive, switch to old lady....er.....um..... Comfort mode.
  36. #76
    Mar 15 2014
    No, u misunderstand. I'm asking john/Uni if they can smooth out the dynamic throttle response with their tune so you don't get this spike/surge, not necessarily to resemble comfort. My original post regarding comfort was to ask if perhaps that setting already did this but per jbullin's response it does not hence my follow up.
  37. #77
    Feb 01 2015
    20ae GTI 1.8BT, CBR F4i, Speed Triple R
    Lancaster, PA
    I gotta be honest, I don't think asking about a product before you buy it is wrong or premature at all. Asking about what is possible, I didn't see him say he SHOULD change it. And the question he asked will lead to a better understanding of the "issue" if we get an answer. Might also lead to UNI seeing a need or want for another feature to add to their product lineup that adds to more flexibility. In what I do, i look for info and ideas everywhere and anywhere, even from people with no or little direct exposure or experience, and try to understand as much as i can to make the best decisions both about purchases and about offerings or approaches to how i operate. I'd also take early feedback and concern very seriously and start brainstorming, but hold off on reacting, so I'm prepared if it DOES become a repeat issue. I'm really not sure what the problem is, here?
  38. #78
    Mar 15 2014
    Nah no problem here! :) everyone's got, and are entitled to their opinion!
  39. #79
    Veteran Member Three Rings Casius's Avatar
    Aug 14 2007
    Ottawa, ON, CA
    Just curious, where you guys getting 93 in Montreal (or Canada in general)? Sunoco/Petro Can have the 94 is that what you're using or you getting something else?
    2010 VW GTI
    Previous cars:
    2003 A4 1.8T APR Stage 1+
  40. #80
    Aug 14 2007
    Ottawa, ON, CA
    If this the dynamic throttle response is anything like the one VW CC I drove I'd hate it too. That thing was terrible to drive. Off the line, I mean in just regular traffic, you'd press the gas and expect to go but all it would do is putter away off the line. You had to mash it to get any go juice but if you mashed it it would just jolt ahead and take off. It seems to be something that VAG likes to do and describing it as a ON/OFF switch is absolutely the best way to explain it. It was horrible and if that's how Dynamic is then a tuner sorting that out would be very much appreciated.
    2010 VW GTI
    Previous cars:
