Hello everyone I am new here and wanted to know what you all thought about the issue I've been having. I scanned it with vagcom when I bought it last Sunday and came up with misfires on all cylinders and camshaft a being to retarded. I removed the valve cover and checked the cam to cam timing and it was off a tooth. So I removed that cam and set it correctly. I replaced all the tty bolts and put the cover back on. It still runs rough at idle but the plugs and cool packs are new (2.0T coil packs) what else could be causing this?
Sent from my iPhone 6+ using Tapatalk
