Results 1 to 10 of 10
    Veteran Member Four Rings enigma1406's Avatar
    Sep 17 2006
    2013 S8 | 2006 S4 Widebody | 2014 Q7
    Houston, TX
    Motor Mount code?
    2013 Audi S6 that is throwing a code for module BA-Motor Mounts. Could this be as simple as an unplugged harness?
    Code:
    Address BA: Motor Mounts (J931)       Labels: 4H0-907-145.clb
       Part No SW: 4H0 907 145     HW: 4H0 907 145
       Component: AEM - LEAR    H05 0006
       Revision: 00001001    Serial number: 97804001859904
       ASAM Dataset: EV_AEMLearAU64X 002014
       ROD: EV_AEMLearAU64X.rod
       VCID: 66C8387F998BE011F57-8033
    1 Fault Found:
    1295 - Drivetran Mounting
              C1154 02 [009] - Signal Failure
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 1
                        Fault Frequency: 1
                        Reset counter: 12
                        Mileage: 33933 km
                        Date: 2015.01.22
                        Time: 22:46:59
    2013 S6 | 2006 S4 widebody | 2014 Q7
    Veteran Member Four Rings Xtek's Avatar
    Jun 09 2013
    Based on the reset counter it looks like it might have just been a transient issue.
    - Chad
    2014 S6 Estoril Blue - APR Stage 1, AWE Exhaust
    I have USB HEX+CAN VAG-COM cable, if you need mods let me know.
    May 18 2014
    Dubai
    got the same error, dealer replaced engine mount and some retaining plates under warranty
    only mine did a bit more errors
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 102
    2013 Audi S6 - mtm catback exhaust - AWE S-FLO CF intake - Revo Technik Stage 1 - vKool X15 -
    Sep 17 2006
    Houston, TX
    Quote Originally Posted by siberianwolf View Post
    Thanks for the reply. Mine is at the dealership as we speak. Getting a couple TSBs looked at and the motor mount error looked at. I'll post back with what happens so we have two instances of this for search!
    Jun 02 2011
    Raleigh, NC
    Curios to know what the outcome was, as I too am seeing this error pop up on my vag-com.
    May 18 2014
    Dubai
    mine appeared again and keeps appearing, they wanted to replace mount again even though it's clear it's a contact/harness issue. I swear local dealer SA/techs are mindless drones
    Jun 02 2011
    Raleigh, NC
    Per the TSB, I suspect it can be resolved via the software update to the J931 module:
    http://www.revbase.com/BBBMotor/TSb/...dPdf?id=183808
    Jun 09 2013
    FWiW I wound up having to get one of my mounts replaced.
    - Chad
    May 18 2014
    Dubai
    Quote Originally Posted by headcase View Post
    Thanks! I will print out this and bring it with me when visiting dealer for next service. Problem with them is that for each thing, however small, I complain about they require car to be 1 week with them for "testing".
    May 18 2014
    Dubai
