Page 33 of 36 FirstFirst ... 233132333435 ... LastLast
Results 1,281 to 1,320 of 1403
  1. #1281
    Veteran Member Four Rings 14S4GWM's Avatar
    Mar 21 2015
    ^ I agree with everything you said. I wish we could tell what tire is actually low. Someone mentioned before you could use the wiper stalk to see what tire but I have yet gotten that to work. Do you know if that is the case.
  2. #1282
    Veteran Member Three Rings SForePlayin''s Avatar
    Jan 11 2014
    2015 Toyota Camry SE, 2015 Lexus IS 250 AWD, 2018 Honda CRV LX
    North Carolina
    I know Carista is available for Android and iOS devices, but I'm trying to find out if it will ever be available in the Windows store, for use on something like a Windows 10 tablet (Surface Pro 4) or laptop. I've emailed Carista Support a couple of times with no response, and nothing on their website. Does anyone know?
    2014 S4 Ice Silver Metallic|Black Optic|DSG|Sport Diff|ADS|Fine Black Nappa|MMI Nav +|B&O|Carbon Atlas Inlays|Supercharged Badges|Advanced Key|OEM Floor and Trunk Mats|Michelin PSS A/S 4|Lamin-x Yellow|deAutoLED|Carista|
    2003 A4 Sedan | Light Silver Metallic | MT6 | 3.0 Quattro | - Traded In
    Instagram - sforeplayin
  3. #1283
    Mar 21 2015
    Quote Originally Posted by SForePlayin' View Post
    I have never read or heard anything about this, not saying it won't happen though.
  4. #1284
    Jan 11 2014
    North Carolina
    I received a response from Support about Carista on Windows:
    Thank you for your interest in Carista. We do not have support for Windows devices, only for Android and iOS ones. We may add support in the future, but we cannot promise anything at the moment. Let us know if you have any more questions.
  5. #1285
    Veteran Member Three Rings PSUGOLD's Avatar
    Mar 10 2014
    Philly Area, PA
    I was a beta tester for Carista and then had a full functioning app. Now I cannot do anything with the app, said I need to buy it, when I had a full feature app a while back after the beta test. Emailed support over and over. They are clueless. Gave up trying to go back and forth with them, none of their responses made any actual sense.
    2016 Daytona Grey Pearl Effect crystal effect , Sports Diff, Adaptive Suspension, Carbon Atlas inlays, Borla Cat Back, DS1 Stage 1 w/ Boosted Euro TCU.
  6. #1286
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by PSUGOLD View Post
    Before they went to subscription mode they offered a back door to be able to purchase the lifetime subscription
    Even as a beta tester I had to purchase the app but I was grandfathered into lifetime subscription
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
  7. #1287
    Veteran Member Four Rings SDV325's Avatar
    Jan 20 2014
    Calgary, AB
    Quote Originally Posted by doug97gxe View Post
    +1
    So glad i purchased the $20 version when i did. Saw that its $10/week or $40/year (with maintenance options included.)
    2016 Audi SQ5 | Technik | Glacier White | Magma | Black Optics | Beaufort Inlays | Roc-Euro | Revivify Graphene Pro | EPL Stg 2 | Eurocode USS | MOOG Endlinks |
    2014 Audi SQ5 Estoril- STOLEN / RIP
    2015 Toyota Rav4 - Family Wagon
  8. #1288
    Mar 10 2014
    Philly Area, PA
    I believe I had done that. WIth one of the last updates it reverted back to not being able to change any settings. THey have been unable to do anything about it so far in support over and over going back and forth.
  9. #1289
    Nov 10 2014
    Apex, NC
    Check your App Store purchases if it's there they should be able to honor ur purchase
    Present:
  10. #1290
    Mar 10 2014
    Philly Area, PA
    Quick question. If you clear a code for something like a check engine light, can the code and fault light still come back on later if the problem persists?? I would worry about clearing a code then having something major happen down the road if the problem actually was more serious.
  11. #1291
    Mar 21 2015
    It will most likely come back after another key start.
  12. #1292
    Established Member Two Rings kynovs4's Avatar
    Mar 08 2016
    2005 S4 Avant 6spd
    Marlborough, MA
    Quick question for anyone using the iOS beta- I just got an invite and I cannot "purchase" any of the pro mode features. I emailed their support a couple days ago and no response yet. When I go to make the purchase, I get the prompt that I've attached here. As you can see it asks for apple id and password but there is only a single input
    EDIT: Disregard. It appears Apple has been having an issue with their Sandbox for in-app purchases.
    2018 Daytona Gray RS3
    2005 Brilliant Black S4 Avant 6-spd
  13. #1293
    Junior Member One Ring
    Aug 28 2016
    [QUOTE=deewan;11760945.
    I didn't know the door handle was an option until I saw the option in the Carista app menu. But it makes sense since you used to use the physical key and turn it one way or another to open/close. Now you can do the same with door handle and holding the lock or unlock areas of the handle with the smartkey in your pocket.[/QUOTE]
    Did you manage to get the windows open using only the door handle? I can close the windows/roof with it, but it doesn't seem to open. I have it enabled in MMI and works with the key fob long press.
  14. #1294
    Veteran Member Four Rings TexasDfwS4's Avatar
    Sep 10 2012
    DFW
    This I will try thanks.
    2018 S6 Glaser white Black/Optics, Sport, ACC, HUD, CF, etc. NO bang/O
    2017 Q5 3.0 Ibis W/ BO with S-line
    Gone 2018 SQ5
    Gone 2013 B8.5 S4
    Gone 2012 S4
    Gone 2012 Q5
    Gone 2009 Q5
  15. #1295
    Established Member Two Rings roydle's Avatar
    Oct 25 2015
    FL
    will the Carista OBD2 Bluetooth Adapter and the app provide IAT accurately? Will it be easy to set up or there some formulas that I will need to plug in? Or does the OBD fusion easier to work with? As u can tell I have never done logging before and will like to start with the most user friendly setup.
  16. #1296
    Mar 21 2015
    ^ Carista doesn't do any type of parameters. The only way you are going to get true boost reading is to use a boost tap. There is a great thread on logging with vcds. Read up a bit so you understand before asking a million questions. You need to log with vcds to get what you need.
    http://www.audizine.com/forum/showth...rmance-Logging
  17. #1297
    May 31 2014
    Alabama
    Unless I cannot find it, is there an option to have ALL exterior lights turn off when the headlight knob is set to OFF? Currently, putting the knob to OFF still keeps the daytime lights on (whether it's day or night outside).
    Sometimes when it's dark outside, but I want to leave the engine running (ex: waiting for friend, but cold weather) and not keep the lights on, I put the knob to OFF. However, if the daytime lights remains on, it's kinda pointless.
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
  18. #1298
    Mar 21 2015
    ^ There is a setting in the mmi to turn the drl's off. No need for carista for that.
  19. #1299
    May 31 2014
    Alabama
    Quote Originally Posted by 14S4GWM View Post
    Ok, but will that turn DRLs off all the time or only when headlight knob is off? I think the MMI solution is strictly to turn the DRLs off completely.
  20. #1300
    May 30 2017
    Utah
    New beta includes ability to enable ADS (Audi Drive Select) for non-ADS trims. Also includes ability to disable Driver Steering Recommendation
  21. #1301
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    New beta ? I use to get update on the beta but I haven't gotten one since last year .
  22. #1302
    May 30 2017
    Utah
    IMO the ADS is the most significant feature of Carista to date for non-ADS folk who don't have VCDS.
  23. #1303
    Veteran Member Three Rings 850tgul's Avatar
    Mar 18 2017
    Plymouth, MA
    Quote Originally Posted by Trogdyr View Post
    Has anyone confirmed this feature to work on a non-ads car yet? This would be awesome.
  24. #1304
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    do you guys always leave the carista dongle connected or you guys disconnect after use.
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
  25. #1305
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by maty360414 View Post
    i don't have a carista dongle but i leave my wifi dongle connected
    Present:
  26. #1306
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Where would the P3 gauge go then? LOL
    Sent from my SD4930UR using Tapatalk
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
  27. #1307
    Jan 12 2010
    SE Pennsylvania
    What would this customization allow us to do in a non ADS S4?
    2014 S4 Prestige l Misano Red Pearl l Black Alcantara l DSG l Sport Diff l Carbon Inlays l 034 Solid Rear Sway bar w/ Moog End Links l Eurocode Trans Insert l ESC Rear Diff Inserts l CR-15 Strut Tower Brace l Uniden LRD 950 Mirror Tap l Chipwerke Pro
    Previous:
    1994 Ford Taurus SHO w/Yamaha V6, 5 Speed
    1999 Ford Mustang Cobra Convertible, Triple Black, 5 Speed
    2007 BMW 335i 6 speed l Tuned
  28. #1308
    Mar 18 2017
    Plymouth, MA
    Quote Originally Posted by 4wheelpilot View Post
    I believe it would allow non ads folks to adjust throttle and steering sensitivity in the mmi
  29. #1309
    Jan 11 2014
    North Carolina
    I disconnect my ieGeek dongle after use.
  30. #1310
    Veteran Member Three Rings VenturiRS's Avatar
    Dec 27 2008
    Quote Originally Posted by Earned View Post
    Same here....
    Can't get it to open, which kinda defeats 50% of the purpose...to aerate the car before I get there.
    B8.5 Estoril Blue S4 | P+ | DSG | SD | ADS | B&O | CF | Nappa | Advance Key | CF Badges
  31. #1311
    Established Member Two Rings deewan's Avatar
    Mar 30 2016
    2013 Audi S4
    Cedar Rapids, IA
    Quote Originally Posted by VenturiRS View Post
    Same here....
    I somewhat agree with you. I was hoping to roll down the windows with a long grab of the door handle. But after it didn't work I began to think if I really need or want it to work with the door handle. A long press of the unlock button on the key fob is a deliberate action to roll down the windows and cane be done from inside the house or walking to the car to give it more time to get fresh (cool) air inside. A long grab of the door handle while unlocking doesn't give as much time for fresh car to enter the cabin and may not always mean you want to roll down the windows. You could be you give a long grab of the handle while finishing a conversation to a friend and it would be somewhat annoying if the windows start rolling down if you live in a cold climate. Or grabbing the handle while you try to remember, 'when was the last time I washed my car?' :)
    After some thought, I decided it wasn't a big deal for me if the door handle 'unlock' didn't roll down the windows because if I wanted the windows down I normally do that while walking to the car from 40-50 feet away. That's just my two cents.
    2013 S4 S-Tronic Brilliant Black
    Premium Plus | RS4 Gloss Black Grill | LED Interior Lights | LED Fog Lamps | Alcantara | B&O | AWE Carbon Fiber Cold Air Intake
    I always use a little chewing gum on these rides. It filters out the pollutants. Of course you've got some good grillwork there to keep out the ozone. I gotta get this thing up to 95, uh, check out the fluorocarbon output.
  32. #1312
    Mar 18 2017
    Plymouth, MA
    I downloaded the latest app from the app store just yesterday, received the Carista branded obd2 adaptor today, hooked it all up and enabled the hidden menu via Carista.
    Went into the hidden/green menu via MMI and followed the selections shown here about half way down (skip past the coding section): http://www.audienthusiasts.com/VagCom_FL_ADS.html
    I then reset the MMI and when it came back up the ADS or Individual options (efficiency, off road, comfort, dynamic,etc) were there but grayed out. When I clicked on them I received the message "the selected system is currently not available." I'm really hoping I'm just missing something because the whole reason I purchased the app and subscription was to adjust steering and throttle response for my non-ADS car. I have emailed Carista btu doens anyoen know where I'm going wrong?
  33. #1313
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by 850tgul View Post
    You downloaded the production app or you signed up for beta testing ? 2 different things I believe ADS is only in beta at this time
    Present:
  34. #1314
    Mar 18 2017
    Plymouth, MA
    I think that is my problem. I missed that pet and downloaded the production app. I am in contact with them now.
  35. #1315
    Sep 11 2015
    2003%20VW%20Jetta%201.8T
    Western Mass
    Hi all, 2012 S4, I just enabled ADS drive select step 1, ADS drive select step 2, "show engine option in ADS menu" and "show steering option in ADS menu" using carista. I then went into the hidden green menu, went into cardevicelist, checked the "Charisma" box, then backed out to car menu and realized that I did not have the "carbusassignment" option needed for the next step. See pic. What am I doing wrong?
    Sent from my SM-G920V using Tapatalk
    2015 Mythos Black Pearl BO 6MT S4 P+ | 19" peelers | Nav | Carbon inlays | B&O | Sport Diff | Nappa
    Mods: 20% tint | EPL | OEM Audi Sport plate frame | HOEN fogs |ECS 10/12.5mm Spacers | Hardwired radar | ECS Trans insert | CTS intake | AWE Touring Exhaust - stock DPs | H&R OE Sports + Koni Shocks | Eurocode F&R Sway
  36. #1316
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Just got an email from Carista. Sounds like in an upcoming update we'll be able to enable some sort of visual parking aid? Is this really supported on our cars?
  37. #1317
    Senior Member Two Rings S4ilicious's Avatar
    Feb 09 2015
    2001 A4 2.8 Quattro
    Bay Area, California
    Quote Originally Posted by jsh139 View Post
    Havent gotten any email from Carista regarding this update besides a new update regarding BMW F series Carista updates keep us informed of any new info!
  38. #1318
    Mar 21 2015
    Quote Originally Posted by S4ilicious View Post
    It was in the same email
  39. #1319
    Established Member Two Rings djkyky's Avatar
    May 27 2015
    24 Audi Q3
    Estero FL
    My 2015 S4 does not have this parking feature.
    I only use my Carista to reset the oil change settings every 10,000 miles. I don't like paying the $10 for 30 seconds of use, but cheaper than using the dealer. I have heard they are other obd2 adapters to reset faults that are free to use. ??
    2024 Q3
    Past A3, S4, S5, Q5, Q7
  40. #1320
    Jul 12 2012
    My thought was why would this be better than my camera?
