Page 31 of 36 FirstFirst ... 212930313233 ... LastLast
Results 1,201 to 1,240 of 1403
  1. #1201
    Aug 22 2014
    Seattle, WA & Bulgaria
    Hi guys, just letting you know we have 25% off the Carista OBD2 adapter today through Cyber Monday on Amazon. Check it out :)
    About ADS: we still don't have an answer on that. The stuff that affects "safety" systems like the steering is in a weird spot legally, so we have to confirm we won't get ourselves into trouble by offering such an option. But I think there's hope.
    About showing the ECU revision: go into DIAGNOSE -> DETAILED INFO.
  2. #1202
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Quote Originally Posted by blackfunk View Post
    Tudor, any chance we get the key to work with the ignition running?
    Even if your answer is no I could live with that but any answer would be nice.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
  3. #1203
    Aug 22 2014
    Sorry, I missed that one. So far our testing is not showing promising results. We haven't been able to get that behavior to work - it just seems that the car doesn't support it.
  4. #1204
  5. #1205
    Senior Member Two Rings MHSFBay's Avatar
    Oct 17 2010
    Grants Pass OR
    Quote Originally Posted by audibmi View Post
    I had the opportunity to beta test the Carista app for iOS on my iPhone and iPad this morning. My initial impressions of the app are good from a user interface perspective.
    Much easier to enable features compared to VCDS, and more convenient as it uses a wifi connection. When connected, it will take some time before you get to the menu screen. I suspect it needs time to read each control module (similar to how long autoscan takes in VCDS).
    As I have previously coded some features using VCDS, Carista appears to recognize which ones are enabled. Will still need to do some comparison testing to confirm which features actually work. Here are some screenshots that I took (some may be cut off as I had to scroll).
    I purchased my ELM 327 wifi OBDII interface for ~$16 which I have been using with Dashcommand. *Make sure not to accidentally get the cheaper bluetooth version.*
    To make things easier, I use it along with a 1 meter long OBDII flat extension cable so I can see the interface LED's working, and not worry about knocking the wifi interface with my foot.
    wifi interface:
    QUESTION:
    Did you try their interface (anyone), and are there any noticable differences , between Carista interface and this one? I like the ELM.
    REVO Stage II+,Carbonio CAI, Stasis Exhaust, Changed 034 low restriction Cat to a MillTek, 034 Catch can, Stern arms,
    STaSIS springs and shocks (Konis, I guess)
    Stasis-Champion 19x9 Wheels- with the Winter Tires, Michellin 245/35ZR-19 Pilot Sport A/S Plus XL / ADV.1.10's in the summer ( 19x9) 245/35ZR-19 Michelin Pilot Sport XL
  6. #1206
    Oct 31 2015
    Quote Originally Posted by todor View Post
    That's a very exciting update on the ADS, especially if it works on non-MMI without ADS. Hopefully more developments to come soon.
  7. #1207
    Veteran Member Four Rings isles1's Avatar
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Quote Originally Posted by jsh139 View Post
    Battery coding would be a nice feature to have, too.
    x2
    2022 SQ5, P+, Daytona Grey, S Sport, B&O, Black Optic, Black Badges, Dynamic Steering, OEM Sport Exhaust, Black/Black Dinamica.
    2013 S4, P+, DSG, Ice Silver Metallic, Black/Silver Alcantara, Sport Diff, B&O, 19" Peelers, Pilot Sport 4, SC Badges, Alu Kreuz, Endless MX72 brake pads, StopTech slotted rotors (front), APR Carbonio Stage I & II CAI. Winter shoes: OEM B8 S4 18" Wheels w/ Nokian Hakkapeliitta 7 Studless. Original owner; custom ordered.
  8. #1208
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Just got an iOS update that claims to allow adjustment of DRL brightness on the A4 platform. Haven't tried it, but IIRC, that was a feature that required "security" access. If so, then maybe this opens the door for more cool customizations like VIM???
  9. #1209
    Nov 10 2014
    Apex, NC
    Maybe different ECU
    Present:
    2020 Porsche 992S 7MT | Jet Black Metallic | Stock
    2018 Ford F-150 5.0 | Shadow Black | Hellion Twin Turbo..etc
    2018 Suzuki GSX-R 1000R | Black/Blue | FBO
    2015 Audi S5 6MT | Ibis White | EPL Stage 2
  10. #1210
    Veteran Member Four Rings Rodizzle's Avatar
    Jun 17 2015
    Bayarea
    Carista app for iOS beta testing [wrench]
    I just confirmed that the new added DRL brightness on my S4 is fully functional. My original setting was at 26% , changed to 70 % . 100 % looked to bright and afraid that I might cause to much glare .
    Edit: I had to lower my settings to 60% , 70 was just to bright
  11. #1211
    Oct 31 2015
    Quote Originally Posted by Rodizzle View Post
    S4 or A4? Sorry I read the updates and it said A4 so wasn't expecting anything for S4. Will look for it tomorrow regardless.
  12. #1212
    Jun 17 2015
    Bayarea
    S4 ...
  13. #1213
    Oct 31 2015
    S4 ...
    Sweet, thanks, will poke around. Hopefully mine was set low so I can crank it up...!
  14. #1214
    Mar 05 2016
    I know the DRL factory setting at night is 26%, does any body know what's the factory default setting during the day? Is it set at 80% or 100%?
    Audi 2013 S-Tronic | REVO Stage 1+| REVO TCU tune| MercRacing Heat Exchanger | AFe intake | ECS cross drilled slotted rotors | Hawks HPS 5.0| Vibrant 90mm double wall Stainless steel tips | Resonated Xpipe
  15. #1215
    Nov 10 2014
    Apex, NC
    - disable auto stop/start <--- i wonder if that's on the B9? had it in my loaner .. and my wife's truck has it.. that thing is so annoying
    Present:
  16. #1216
    Veteran Member Three Rings bayonet14's Avatar
    Aug 07 2013
    BMW 335i
    Pinelands NC
    Could we get a mute/or adjustment added for the Soundaktor added? Instead of having to pull the fuse
  17. #1217
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Nice!!
  18. #1218
    Oct 31 2015
    S4 ...
    Mine was set to 28% (cranked it up to 75%)... nice find!
  19. #1219
    Veteran Member Four Rings 14S4GWM's Avatar
    Mar 21 2015
    Quote Originally Posted by Chibo View Post
    Mine was set at 26 and cranked it to 50 and didn't notice a change. Someone else mentioned it didn't work for them either.
  20. #1220
    Veteran Member Four Rings jygesq's Avatar
    Aug 22 2014
    1986 Honda CH 150 D scooter bought new
    bloomfield,ct
    Quote Originally Posted by doug97gxe View Post
    Carista will not customize on new. B9 according to their web site.
    2015 S4, P+, Florett Silver,black /silver nappa leather, S-tronic ,sport diff,B&O ,tech package ,supercharged badges. All season tires ,cargo net, factory dip stick
  21. #1221
    Nov 10 2014
    Apex, NC
    Quote Originally Posted by jygesq View Post
    Oh it said A4 I thought only the B9 had that feature
    Present:
  22. #1222
    Oct 31 2015
    Quote Originally Posted by 14S4GWM View Post
    Re-tried this at 15%, 25% 45% and 75%, definitely works for me.
  23. #1223
    Mar 21 2015
    So I wasn't aware that this only worked when your headlights were on. I didn't know that the drl's were already at 100 with the headlights off. Thanks for reporting back though.
  24. #1224
    May 31 2014
    Alabama
    I wonder if you can customize that the DRLs actually turn off with the headlight switch in the off position.
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
  25. #1225
    Mar 21 2015
    Quote Originally Posted by AudiS4SD View Post
    Not with Carista
  26. #1226
    Mar 05 2016
    On Carista there is a feature control DRL YES/NO. If you set YES, you be able to control DRL through the dashboard.
    On the dashboard, you see DRL ON/OFF. Set OFF, the DRL will be off when the Headlights is off and DRL will go on when Headlight is ON.
  27. #1227
    Mar 21 2015
    Quote Originally Posted by TC_S4 View Post
    DRL or fogs? Where on the dash do you see drl control
  28. #1228
    Mar 05 2016
    DRL not fogs.
    On the dashboard go on Car- Exterior Lightnings- Day running lights- On/Off.
    To have acces the the DRL feature on Dashboard you need to activate with Carista first.
  29. #1229
    Mar 21 2015
    DRL not fogs.
    When you use the term "dashboard" are you meaning in the mmi? So you will have to go into the mmi to turn on/off the drl everytime. You make it sound like there is a button on the dashboard that you can use. Sorry for my confusion and thanks for explaining.
  30. #1230
    Mar 05 2016
    Yes, I mean MMI.
  31. #1231
    Mar 21 2015
    Yes, I mean MMI.
    . Thanks
  32. #1232
    Veteran Member Four Rings maty360414's Avatar
    Oct 13 2015
    SoFlo
    Yes, I mean MMI.
    Can I turn off the fog lights when unlocking my car at night? On the Auto mode
    '13 S4 | EPL DP E40 | EPL TCU | AEM W/M | Tampa Ported S/C | 75mm TB | JHM 187 | MercRacing HX/Divorced | Becker TestPipes | AutoTech HPFP | Roc Euro Intake | BFI Engine Mounts | ECS Trans Mount | ECS F/R Diff Mount | H&R Super Sport Springs | 034 Rear Sway Bar | CR-15 | Drilled & Slotted Rotors | StopTech SS | Vertini RF 1.3 | Indy 500 | Sport Diff | BFI Shift Knob | Quattro Grill | ECS Spoiler/Diffuser | RS4 Bumper | J-Code | CWA100 |
  33. #1233
    Mar 21 2015
    Quote Originally Posted by maty360414 View Post
    That should be "coming home lights", it's in the mmi already. If it's not I believe you can change that with Carista
  34. #1234
    Aug 13 2008
    Reston, VA
    On my 2013 S5 cabrio when I first tried the drl brightness it would not save
    I was going from the default 26% to 100%
    But when I tried 50% it worked
    But can't go higher than 50%, if I do it says can't save and the car rejected the change
    Has anyone gotten brighter than 50% on B8.5?
  35. #1235
    Mar 21 2015
    ^ Read this page of posts, yes it's been done
  36. #1236
    Aug 13 2008
    Reston, VA
    I tried again
    I was standing outside the car to see of the brightness was changing or not
    So I tried to switch back to the default 26%
    Got the same "the vehicle is rejecting the new sitting value..." Error
    So I kept trying to save a few times and it finally allowed me to save
    So I tried 100% and it saved!
    So if at first it won't save, keep trying
  37. #1237
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    Changing LED brightness with headlights on worked perfectly for me the first time (2010). Initial setting was 9%, and I bumped it up to 50%. I watched it change. No high-beam flashes at me yet.
  38. #1238
    Veteran Member Three Rings SForePlayin''s Avatar
    Jan 11 2014
    2015 Toyota Camry SE, 2015 Lexus IS 250 AWD, 2018 Honda CRV LX
    North Carolina
    Will the new DRL brightness setting with the headlights on remain the same when the light switch is moved to the side marker light position (one position to the right of auto) and the headlights go off?
    2014 S4 Ice Silver Metallic|Black Optic|DSG|Sport Diff|ADS|Fine Black Nappa|MMI Nav +|B&O|Carbon Atlas Inlays|Supercharged Badges|Advanced Key|OEM Floor and Trunk Mats|Michelin PSS A/S 4|Lamin-x Yellow|deAutoLED|Carista|
    2003 A4 Sedan | Light Silver Metallic | MT6 | 3.0 Quattro | - Traded In
    Instagram - sforeplayin
  39. #1239
    Established Member Two Rings na_v's Avatar
    Jan 27 2015
    2013 s5 went 66% for DRL
    Current : 2013 S5 Premium Plus | Glacier White | Magma Interior | DSG | ADS | Sport Diff | Carbon Atlas | B&O | Adaptive Lights
    AWE Track Exhaust | PUR 4OUR Forged Wheels | ECS Spacers | Carbon Imports Trunk Lip | Carbon Imports CF Mirrors | ECS Carbon Fiber Intake
    Past : 2014 Ibis White Audi A4 Progressiv | ECS Spacers | H&R Sport Springs | APR Stage 1 | RS Grille | US Millworks
  40. #1240
    Oct 13 2015
    SoFlo
    Carista needs Gear Display on D/S
