Page 25 of 36 FirstFirst ... 15232425262735 ... LastLast
Results 961 to 1,000 of 1403
  1. #961
    Veteran Member Three Rings Reckon's Avatar
    Jul 16 2015
    St. Petersburg, FL
    Gear display is one of the final things I am waiting on!!!
    2014 Estoril Blue Audi SQ5 Prestige
    2017 Ebony Black Jaguar F-Pace Prestige
  2. #962
    Veteran Member Three Rings LordMagnet's Avatar
    Jul 20 2015
    Connecticut
    Quote Originally Posted by AudiS4SD View Post
    Oh gotcha. Not a problem in the 6MT :)
    I wouldn't mind the ability to disable the gear suggestion on the dash. "Oh, you're comfortably cruising in 4th? Why not just go ahead and put that in 6th? 600 rpm can be fun too."
    2015 Audi S5 Coupe 6MT | Mythos Black Metallic : Black Nappa : Alu-Optic : B&O : Sport Diff. : 19" RS Rims : Carbon Fiber Inlay | APR Stage 2 : Roc-Euro Intake : AWE Touring Exhaust 102mm : EuroCode Short Shifter : USP Clutch Line : CR-15 Strut Tower Brace : 034 Mounts : H&R OE Sport Springs : 15mm/20mm Spacers : Tint 35% Sides / 20% Rear : Interior LED Kit : E-Codes : Vinyled Grille | 413 AWHP / 375 AWTQ
  3. #963
    May 31 2014
    Alabama
    Quote Originally Posted by LordMagnet View Post
    True, I frequently cruise in 4th around town giving enough power to slow and accelerate without swapping gears every two seconds. It's all about being green though!
    *SOLD* 2014 S4 | Glacier White | Premium + | DSG | 034 Drivetrain Mounts | ECS Slotted Rotors/StopTech Pads | IE Intake |
  4. #964
    Veteran Member Three Rings wangshuo1989's Avatar
    Jan 09 2016
    Quote Originally Posted by yjypm View Post
    I failed to do that on Carista but somehow Vagcom worked for me
    Interesting, when I try to enable that through vag com, it showed me an error. Would you mind sharing your steps?
    2013 S5 Misano Red, DSG, B&O, Sport Diff, MMI+, JHM 207mm crank pulley (7PK1370 Contitech belt), APR Stage II Dual Pulley, APR TCU tune, APR CPS, CR15, IE CAI
    2018 XC90 Inscription, B&W sound, Convenience Pkg, Air suspension
    2014 Mercedes E350 rwd
    2021 BMW 540i
  5. #965
    Established Member Two Rings jjslegacy's Avatar
    Oct 14 2006
    2015 S4/2013 Q7
    Cleveland
    Trying to get the windows to go up/down with the remote - I have enabled in carista but doesn't seem to work.
    This is on a 2015. Anyone else see this?
    JJ
  6. #966
    Veteran Member Four Rings 14S4GWM's Avatar
    Mar 21 2015
    Quote Originally Posted by jjslegacy View Post
    You have to enable them in the MMI under car settings>central locking. Look for central locking.
  7. #967
    Feb 22 2016
    Chattanooga, TN
    Once done in the app you have to set the controls in MMI. Was that done?
  8. #968
    Oct 14 2006
    2015 S4/2013 Q7
    Cleveland
    duh - thanks guys. I am a bit rusty - haven't had to do any of this since my 2010.
    JJ
  9. #969
    Jan 26 2015
    2017 XC90, a workbench
    CO
    I finally contacted carista via the app. I did my own service but could not change the Service Due prompt. They got back to me within 2 days and I got the beta download. The reset service indicator fxn at first did not work, but I retried it after clearing a subwoofer fault code and it worked. The beta also says it supports resetting the launch control # for all of you DSG guys.
    2018 S6 - stock for now
    2014 S6 - Stage 3 - Gone
    2013 S4 - Dual Pulley e85 - Gone
  10. #970
    Jul 16 2015
    St. Petersburg, FL
    Any updates for iOS? Still waiting on gear display!!!
  11. #971
    Established Member Two Rings rcz22's Avatar
    Aug 19 2015
    2014 Cherokee Overland, 2011 Ducati 848 EVO
    New Jersey
    Quote Originally Posted by Reckon View Post
    this.
    2014 S4 / Moonlight Blue Metallic / Prestige / Navigation / B&O / JL10W6 custom enclosure + Alpine Amp / Black Optics / Sports Differential / DSG | 19" Peelers / Ziza LED Interior / 35% Tint / VLED VX3 Fogs / CR-15 /
    AWE Touring Exhaust / ECS Luft-Technik Carbon Intake
  12. #972
    Senior Member Three Rings usmc1994's Avatar
    Nov 11 2013
    2014 Audi S4, 2014 Audi A4, 2005 1/2 A4
    Home
    Adjust LED brightness on headlamps?
    Apr Stage 2, Stasis touring suspension, 20x9 Stance Wheels SC-8 with Michelin Pilots, AWE exhaust 102mm tips Vag Com, Alu Kreuz, Awe Boost Gauge
  13. #973
    Established Member Two Rings Arn560's Avatar
    Aug 10 2015
    Toyota Sequoia SR5, VW Jetta
    Monroe, NJ
    I have been able to add: 1. Lap timer, 2. Gear display, 3. oil temp, 4. Widows & roof, 5. Aux heating/Cooling, 6. Brake light flash and 7. Wink delete. To keep foot well lights on, it says I have no further options or something. I need to change a setting in the sub (green) Menu in MMI. I can get to this menu but I don't know what to change without screwing up my existing settings.
    2011 B8 S4 Prestige, Ibis White, B & O, Nav, Carista Mods, Sports Differential, Black hide & Alcantara, CF inlays, S4 rubber mats, 19" Peelers, Ziza interior LEDs Lubed with Mobil 1.
  14. #974
    Mar 21 2015
    Quote Originally Posted by Arn560 View Post
    Look in the vcds sticky for the footwell lights in the hidden menu.
  15. #975
    Aug 10 2015
    Monroe, NJ
    Quote Originally Posted by 14S4GWM View Post
    I printed them out and will find time to sit in the car to see whether I can figure it out. Thanks.
  16. #976
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    Quote Originally Posted by Hofahome View Post
    I looked around in the Beta app, I couldn't find the Launch Control counter at all. Now you're teasing me with this. Where is it in the app?
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
  17. #977
    Veteran Member Four Rings isles1's Avatar
    Oct 24 2012
    2013 S4, 2022 SQ5
    Nassau County, NY
    Quote Originally Posted by amz View Post
    +1
    2022 SQ5, P+, Daytona Grey, S Sport, B&O, Black Optic, Black Badges, Dynamic Steering, OEM Sport Exhaust, Black/Black Dinamica.
    2013 S4, P+, DSG, Ice Silver Metallic, Black/Silver Alcantara, Sport Diff, B&O, 19" Peelers, Pilot Sport 4, SC Badges, Alu Kreuz, Endless MX72 brake pads, StopTech slotted rotors (front), APR Carbonio Stage I & II CAI. Winter shoes: OEM B8 S4 18" Wheels w/ Nokian Hakkapeliitta 7 Studless. Original owner; custom ordered.
  18. #978
    Mar 21 2015
    Quote Originally Posted by isles1 View Post
    +1
    Android or iOS? Maybe its released on one and not the other. The iOS app usually takes longer for the release.
  19. #979
    Jan 26 2015
    CO
    That is what I was going off of
  20. #980
    Mar 21 2015
    ^ That probably just shows the amount of launches on your car.
  21. #981
    Jan 26 2015
    CO
    You are dead wrong. Just kidding, sorry for getting hopes up.
  22. #982
    Mar 21 2015
    Doesn't bother me, lol. Ive never used launch yet.
  23. #983
    Senior Member Two Rings sidkneeeeee's Avatar
    Jul 09 2013
    Fairfield, CA
    I used the beta to try to reset service indicator and it did NOT work.
    1) I connected to my OBDII using wifi, turned the app on and waited till 100%
    2) Then picked the button reset in Tools
    3) Screen says i need to pay $4.99 and need internet connection, i disable WIFI and use LTE to login Itunes to pay within the app.
    4) Turned on WIFI and connected to the OBDII again, and press the reset service button
    5) It told me to connect to internet to pay $4.99 AGAIN!!, so i do the process over again. But it did not work.
    Seems like an endless cycle, nothing was charged, but can anyone help.
    2010 A4 2.0T P+ 6 Speed CPO / ECS Interior + License led lights / RS4 Grill + Honeycomb Fog cover / Sline Rims 255-35-19 Et43 / ECS Spacer 10mmF:12.5mmB / ECS Inlet hose + Dry Filter / B12 KIT (Bilsteins Shock / Eibach Springs) / 10mm+12mm spacers / Wrapped interior + Window trim + Jcodes / ECS Shortshifter / LED 3200K Yellow Fog / Coilpack, NGK plugs / GFB+ DV / Revo Stage2 / Eurocode HFC / Hotchkis F:R Sway Bars / ECS Transmission Mount Inserts/ Future Mods: Podi Boost Gauge ; 3.0 TDI IC
  24. #984
    Aug 19 2015
    New Jersey
    Just started playing around with this app (IOS) cause I bought wifi instead of bluetooth...
    Got the Gear display to work in both D and S
    Removed the "wink"
    Added Ambient light (following the 3 steps in the hidden menu for the 8.5 facelift model) - not sure if this works yet, haven't had a chance to drive at night
    I'll tinker around some more - the IOS app is ok, it crashed on me a few times mid save. And I noticed a few options that were already sent to "enabled" when I know they were not...setting to "disabled" actually enabled the functionality, unless I'm misunderstanding the wording. I sent a note (through the app) to the administrators however no one has responded.
  25. #985
    Active Member One Ring Illestro's Avatar
    Oct 17 2015
    Langley BC
    I just got pushed a new version this morning on my iPhone but it's not clear what exactly, if any new features have been implemented.
    Here is the description from the email I received:
    Carista OBD2 3.0 (300011) for iOS is ready to test
    What To Test:
    New payment model - please try different variants of our 1-week access and yearly subscription. This beta also includes new customization settings and bug fixes.
    To test this app, open TestFlight on your iOS device using iOS 8.0 or later and install the update.
    In order to use Carista OBD2, you agree that crash data as well as statistics about how you use Carista OBD2 will be provided to Prizmos OOD and linked to your email address. Prizmos OOD may contact you regarding this information. You should review the Terms and Conditions of the TestFlight program, as well as the terms, policies, and practices of Prizmos OOD. Beta apps may crash or result in data loss.
    | 2015 S4 Technic | Glacier White | DSG | B&O | Black Optics | Carbon Atlas Inlays | ECS Wheel Spacers | Charcoal Interior | 35% Window Tint |
  26. #986
    Established Member Two Rings Navyseal#6's Avatar
    Aug 17 2015
    Pennsylvania
    Got the new version today, still can't get gear display-2011 S4
  27. #987
    Established Member Two Rings theSaint024's Avatar
    Jul 16 2014
    SF CA
    Version 300009: Successfully disengaged rear parking brake for new pads. That is a really helpful tool, but the proposed pricing seems a bit high for that ($9.99). Especially since I already paid for the app and there are ways around the parking brake issue. Just my two cents on the proposed pricing, but it works great. I also was able to get the gear display. Pretty cool just out of curiosity for normal Drive since it's going through 8 gears. I will eventually switch it to sport shifting only. Did a bunch of other successful tests awhile ago. Don't remember them all, but I was able to get the Service Reminder reset. I wonder if something changed in the revisions? Not a bug, but I do wish the app functions would load up faster. I assume this is an OBD2 limitation. I would also love access to my settings while not connected to the OBD2. Just wishing, pretty pleased as it is.
    2013 allroad - ibis white P+ - The answer is... "it's an allroad bro."
  28. #988
    Jul 03 2004
    Atlanta
    Yeah I'm not fond of this fremium version. I already paid for the "pro" version for $20 and now they are adding micro (fractional?) transactions that are additively far more than the original price the "pro" version. Almost prohibitively so. If I'm going to pay that much for far less features than Ross tech I might as well go Ross tech
  29. #989
    May 01 2014
    New York State
    That is how I feel at this point. Charge me $20 once, ok. But keep nickel and diming me and it gets old, real fast.
  30. #990
    Apr 29 2013
    Ottawa
    I don't know why people are complaining about $10 every time you need to chance your brakes, it's not that big of a deal. The big feature, scanning for codes, is free. Reprogramming the car is free. The few little things you have to do infrequently are a for-pay feature, sounds like a deal to me.
  31. #991
    Veteran Member Four Rings GeoJoe's Avatar
    Jun 08 2012
    Q7, Q5, 2016 Porsche GT4, Subaru Sambar, Honda Acty Van and a 2018 Tundra Loooooooong bed
    ATL GA
    If you track your car and want to swap out street pads for a track set 6x a year or more, it can add up quickly. Get it now?
  32. #992
    Veteran Member Four Rings jsh139's Avatar
    Jan 04 2008
    2021 Audi SQ5 PP
    Philly 'burbs
    I also feel like the nickel-and-diming with the EPB release and service interval reset are ridiculous. I think a lot of us (myself included) purchased the $20 premium version of the app with the thought that any and all additional features they added to it would be included. It may just be 10 bucks here and there, but the whole point of this app was that it was supposed to work with different makes/models and offer a high percentage of VCDS features for a fraction of the cost. With these add-ons, it starts to change that whole paradigm.
  33. #993
    Aug 19 2015
    New Jersey
    Quote Originally Posted by jsh139 View Post
    I agree - Sounds like they've adopted the same model as PushBullet which I used since the beginning until they started making you pay for features which were previously free. The $20 premium should grandfather in early adopters, the new payment model should be for new adopters, I think
  34. #994
    Veteran Member Three Rings BigBluu's Avatar
    Feb 25 2010
    '15 S4, '17 A3 e-tron, '18 Model 3
    The City
    Quote Originally Posted by GeoJoe View Post
    I don't think that's who the app's target market is. It seems geared more toward the casual user. If you're tracking, you're probably doing a lot of other mods and should own your own cable already. I currently don't track, but hope to soon...maybe a couple times a year. I have both the cable and app. Cable is great as it can do everything. Still testing out the app more to see if I can truly go cable-less and sell it off. If you're a casual user, I don't see how Carista is not a win-win. It's about $40 up front and maybe another $60 tops over the lifetime of your car for the other charges. You'll still be ahead of the cable by $250!
    2015 S4 S-Tronic Prem+ Sepang/Magma Sports Diff / B&O / Carbon Atlas / 034 ECU & TCU Stage 1 / ECS Intake / Alu Kreuz / CR-15 / 034 Trans Mount / 034 Rear Sway / Moog Links (F&R) / H&R OE / VMR V810 (19x9.5/ET40) / Michelin PS 4S / Opti-Coat Pro
  35. #995
    Dec 03 2008
    2018 SQ5
    Castle Rock, Colorado
    So, any Android users that can answer my question?
    Torque app is unable to identify IATs. Is carista able to read this value?
    I want to do some testing to see if E85 mix really makes a difference with heat.
    2021 Audi S4, P34 Intake
  36. #996
    Mar 21 2015
    Carista doesn't read any values at all. It wasn't made for that.
  37. #997
    Dec 03 2008
    2018 SQ5
    Well fuck, so is there no other way other than P3 gauge or VAG Com? Maybe a P3 is in my future, unless I can get VAG Com + compatible tablet for same price. My win 7 laptop is shit, plus sucks to lug a huge laptop around. I've just never liked the vent gauge idea. Plus that vent is my favorite/most used, since it warms me hand in the winter, yarrr.
    Is there a similar normal digital/switchable gauge I can use that can be installed in a podi pod?
  38. #998
    Mar 21 2015
    ^ Dell has some cheap 11 inch laptops.
  39. #999
    Dec 03 2008
    2018 SQ5
    I had a ninja edit, sorry
  40. #1000
    Veteran Member Four Rings Whitee's Avatar
    Aug 27 2014
    2001%20B5%20S4%20
    United States
    Does SIR work in released version in iOS store?
    2010 Prestige Ibis White S4
    Rock Euro | P3 Scanguage | EPL Stage 2
