Results 1 to 2 of 2
    Established Member Two Rings Leon 20VT4's Avatar
    Sep 03 2012
    Norway
    Alternator problem
    Hey. I got a Seat Leon 2001 4x4 with a non charging alternator. The car has driven 100k km and i think it is a bit early for the alternator to go faulty.
    I tried changing the voltage regulator with a new one, that did not help. It makes no noise... What else can go wrong with these alternators?
    Are there anyhing i should look for or check?
    2011 S5, REVO Stage 1+, S-tronic tune, exhaust + intake.
    1999 S4, Frankenturbo F21, 440cc Green Giants, RS4 MAF, Bosch 044, VAST Stage 4 clutch, H&R coilovers, MTM Downpipes & cat-back, Wagner intercoolers, Forge DV's, JHM Short Shift Trio, 034 CAI, EBC Red Stuff, 2.0TFSI coils, Stern, Apikol, 034 rear arb
    Veteran Member Four Rings offroader1006's Avatar
    Oct 17 2004
    77 International Scout II, 73 911 2.8RS, 2010 Cayenne
    Columbia, SC
    Check to make sure it free wheels in one direction and spins the armature the other.
    I've seen one that wouldn't spin the armature. Other than that, you can get into a bit of checking the internals like the coil resistances and brush contacts.
