Just bought a 02 A4, AMB engine code. I'm having cold start misfires, some white smoke for longer period of times then disappears, and random Misfires even when warm. I was told the car needed coolant system bled when I got it. Didnt have to drive far home so never noticed or seen it. But, went to bleed using the Haines manual, can't get the car to bleed...I added a lot of coolant, and kept trying. Car has all new timing components and water pump. (Gates kit with standard gates black belt and metal water pump). Headgasket was also done. Finding traces of Bars Leak in old coolant. Oil seems watery, car will idle at temp, soon as you drive it spikes, top rad hose is hot, bottom is warm, top heater core hose cold, bottom hose hot. Tried flushing heater core, flows smoothly. I can completely pull top heater core hose off. If I rev the car while parked, it will flow but overheat. Seems to use coolant. Chances of a cracked head doing this? Reason I ask is I was getting bottom end noise from the cylinder misfiring but comes and goes. Thinking it's leaking into the cylinder, misfiring and washing the oil off the rod bearing and making noise, then gets lined and disappears. I just want some advice. I'm really leaning towards cracked head as most of the other parts are new for a fact.
