Just curious to see who else with the B&O is having this issue. I am currently fighting AoA on this as it seems like there's a bit of denial about if this is a problem or not.
If you are not aware of the issue:
http://www.audi-sport.net/xf/threads...-noises.210006
http://forums.vwvortex.com/showthrea...ackling-Issues
If you have not experienced it you are quite lucky-- but maybe you just haven't discovered it yet, and that is what I am after (trying to see if this is really an issue on all 8V B&O's):
Download this 750Hz tone and play it over an SD card, Bluetooth or AMI (USB or iPod) at volume "25" or higher
https://www.dropbox.com/s/heyawa8b59...750hz.wav?dl=0
Thanks in advance for any info you might have and any testing and reporting back you can do on your system. (Note: if you don't have B&O you shouldn't be affected).
