Page 2 of 13 FirstFirst 123412 ... LastLast
Results 41 to 80 of 502
  1. #41
    Veteran Member Four Rings blackfunk's Avatar
    Jul 12 2012
    Thats a different style of design. The box being sealed where the mounted sub is more of a ported design. Either can sound good if properly designed. Sealed designs generally have a bit of a tighter sound and tend to be smaller. Being that we have limited trunk space I like the smaller design a bit more.
    Life has taught me never try to make something idiot proof, they'll simply come up with a better idiot.
    I'd agree with you but then we'd both be wrong.
    I have neither the time, nor the crayons to explain this to you properly.
  2. #42
    Veteran Member Four Rings cspcrx's Avatar
    Jan 04 2013
    2009 Tacoma, 2007 Harley Softail, 1986 Honda CRX
    Phoenix, az
    Quote Originally Posted by SteveYem View Post
    The box would hang off the bottom of the rear deck then?
    Yes
    2012 Ibis P+ / DSG / Silk Napa / B&O / Sport Diff. / ADS lite / MMI & Nav / APR Stage 2+ & TCU Tuned / Ultra Charger / 184mm KI LIL BITCH / ECS Kohlefaser Luft-Technik Intake / AMS Alpha Cooler / ECS 2-Piece Rotors / Akebono Pads / VMR 803 19x9.5 ET45 265-35-19 PSS / ECS Drivetrain Bushing Inserts / CR-15
    11.8 @ 116mph 2487DA on 93oct file Stage 2+
    THEN THEN THEN Rinse & Repeat!
  3. #43
    Jan 04 2013
    Phoenix, az
    Quote Originally Posted by blackfunk View Post
    Not sure if your talking about the setup i described, if so it is not a ported encloser. It is a small sealed enclosure, it is just firing up throught the rear deck hole where the stock sub would be.
  4. #44
    Jan 24 2015
    Mid-michigan
    Quote Originally Posted by cspcrx View Post
    Yes
    That sounds terrible. That rear deck would need lots of added weight/dynamat to minimize rattles and would take up usable trunk space.
    2013 Audi S4 6MT - Misano Red - Sport Differential - B&O Speakers - Unitronics Stage 2+ - Roc-Euro Intake
    Tinted Windows - Kinovo BTC450 Hardwired Bluetooth - Soon to have 10" JL sub in cubby box
  5. #45
    Veteran Member Four Rings Deckdout2's Avatar
    Sep 13 2010
    2010 Audi B8S4 Ibis Prestige (SOLD), 2016 Audi C7.5 A6 Prestige (SOLD), 2004 Audi C5 A6 4.2 - 6spd
    Charlotte, NC
    Can't find the thread, but it's been done numerous times in the past. Not the direction I would personally take, but it's been done.
    APR Stage II+ | APR TCU | APR Ultracharger | APR Dual Pulley | APR CPS | APR Open Intake | AWE Non-Res DP & Touring | H&R Coilovers | Hotchkis F/R Sways | Alu Kreuz Stabilizer Bar | USS F/R Endlinks | SPC Adj Arms | 034 Arms Kit | 20 x 9 +35 Rotor Reps | 255/30/20 V12 evo2 | RS6 Pedals Shifter | RS6 Shift Knob | Audison/Hertz Amp & Sub | RS4 Grill | Deval CF Splitter | Facelift Flat-Bottom | S6 Start/Stop Button | oCarbon Red CF | Relak v2.0 Paddles | ECS Stage 1 Brake Kit
  6. #46
    Veteran Member Three Rings Mr. Spectacular's Avatar
    Nov 08 2013
    Houston, TX
    Man!! I'm pretty sure I've travelled 4 out of the last 7 weeks so it's been tough to make headway, but I am working on this stuff whenever I can find time. I've spent a lot of time fine tuning the shape of the original box and am very pleased with how it's coming along! I never knew shaping something could be such a meticulous task. I managed to snap a few shots today though. Here's what I'm working with.
    I like how you can see the contour and unique shape the box requires to fit in that space
    Here you can see where I bowed out the left side for more airspace and so I can make sure that hunk of a magnet on my 10w6 has plenty o' space.
    Finally got all the finish sanding done and primed for coats of wax. Oh and a special project right behind it as well ;-)
    More updates to come!
  7. #47
    Veteran Member Three Rings 13ttaz's Avatar
    Apr 29 2013
    Arizona
    In for updates and one of the first production versions of your cubby box Mr. S. Indeed, my 10" sub is sitting quietly in the garage yearning for a cubby box to call home!
  8. #48
    Jul 16 2012
    Mid-Atlantic
    Oh the money you could make fabbing these for members!
    2014 S4 - APR Stage 2 - APR CPS - AWE Touring w/ Resonated Downpipes - APR Carbonio Stage 2 Intake - Alu Kreuz - H&R Front and Rear Sways - 034 Inserts - Focal KX165 + Audison Bit4.9 + Audison 4D - Xpel Front End Wrap - Modesta BC-04 Paint Coating - Rayno S9 Tint - R8 Oil Cap - Porsche 911 Coolant Cap - CR15 Strut Tower Brace - Q5 Brembo Brakes - Goodridge Stainless Brake Lines - P3 Gauge (w/ Track Pack)
    My Seller Feedback Thread - http://bit.ly/2vD36PE
  9. #49
    Jan 04 2013
    Phoenix, az
    I am amazed that a company has not come out with a stealth box or some other designed box for our cars. Are the A4s the same in the truck? If so it would fit at least two models for over 5 years.
    Teylix, not sure why you feel its a "terrible" idea when a lot of BMW guys do this already. A light weight box could easily be made out of mdf and fiberglass then bolted under the deck. Using a thin sub would keep your truck space and the box could go forward some as there is a lot of space up there.
    Excited to see how this works out.
  10. #50
    Veteran Member Four Rings k9lovr's Avatar
    Aug 30 2009
    14 ML350 Bluetec, 17 MKVII
    Fredericksburg, VA
    Quote Originally Posted by Works2shoot View Post
    +1....would be interested as well
    [B]Current: Shopping now....
  11. #51
    Jan 28 2015
    Pnw
    Subscribed...
  12. #52
    Nov 08 2013
    Houston, TX
    Making progress!
  13. #53
    Junior Member Two Rings
    Mar 19 2014
    Count me in, looks awesome.
  14. #54
    Jun 30 2014
    2013 B8.5 S4 Prestige
    Auburn, MA
    Looks good!
  15. #55
    Veteran Member Four Rings B18b1ex's Avatar
    Jul 02 2004
    FL
    Waiting for final outcome.
  16. #56
    Apr 29 2013
    Arizona
    What is that "special project"????? "Enquiring minds" want to know.
  17. #57
    Jun 10 2013
    Miami, FL.
    can this box play the really low frequencies? below 40hz? i have the same sub in a probox and it sounds amazing, but into a small sealed enclosure i would give up alot of that sound. but i love the look.
  18. #58
    Nov 08 2013
    Houston, TX
    Quote Originally Posted by 13ttaz View Post
    haha those minds will have to wait and see! But they should like it
    Quote Originally Posted by UmbroVR6 View Post
    The sealed and ported discussion is another topic in and of itself. There are sure to be differences in the enclosure you have now verses a smaller sealed one. There are lot of other factors too. I know our signals are processed some form the B&O, but I have an audio Control LC2i to aid with the strength of what's sent to the sub. This helps in terms of overall volume and clarity. I knew i was going to redo the box so I never fine tuned the system when it was in my car, but it did get pretty low. I could try and run some test tones once I make myself a new one and let you know what I experience.
  19. #59
    May 06 2014
    Las Vegas, NV
    Do we really need an LC2i type box in our system?. My amp already has a high/low converter.... And bass doesn't seem to roll off. Thoughts?
  20. #60
    Jun 10 2013
    Miami, FL.
    Quote Originally Posted by Mr. Spectacular View Post
    that would be awesome if you could do something like that! thank you!
  21. #61
    Jan 24 2015
    Mid-michigan
    Quote Originally Posted by the4siswickid View Post
    Some amps don't have that high/low setting so yeah, then you need the line out converters. But if you do have one (like my jl 500/1 does) then you dont need one.
  22. #62
    Nov 08 2013
    Houston, TX
    When i was in the research phase, I found that those who had the lc2i were happy with it's performance. I am as well. My amp also has the hi/low input option which can be used to turn the amp on as well, but what i found was that those who opted for this setup has issues with the signal being strong enough in a consistent manner to keep the amp on. I chose to avoid the possibility of this challenge and get the unit so i can't speak on the sound without it. I also do notice roll off with the aftermarket sub in. My setup wasn't fully tuned so I can't say how much of a correction the LC2 makes, but I was able to ensure a clean and simple remote signal by tapping the fuse box in the cubby going through the lc2 and the strongest, cleanest signal possible being sent to my amp and on to the sub.
    Quote Originally Posted by teylix View Post
    Teylix were you using the hi/lo setting as a remote on as well?
  23. #63
    May 06 2014
    Las Vegas, NV
    Ok - excellent tip. I ordered one, so we're good. Any chance your box could be made to fit the low profile JL series woofers WITHOUT a need to relocate a bunch of equipment in that cubby??? I really don't want to move stuff... :-) I'll even go down to the 10" low profile if I have to, but would prefer not. LOL
  24. #64
    Nov 08 2013
    Houston, TX
    Honestly, relocating the amp (and sat unit if you have it) is probably one of the easiest parts of the whole install. Undo a few screws and swing 'em into their new position. A 5 or 6 inch straight iron plate fastened with some screws and you're good to go. With materials in hand, it would probably take 5-10 minutes. It took me longer to get the trim panels off and I knew where to look. Granted now I can remove all the trim in the trunk in less than 5 minutes but that's what experience will do for ya ;-)
    That being said, I get some folks just don't want to move that stuff. I don't know how much space there is but I feel like it's not much. Are you talking about the TW's?
  25. #65
    Jan 24 2015
    Mid-michigan
    My JL setup is in my other vehicle (Tiburon) where I have an aftermarket head unit (Eclipse CD5000 with 8V outputs!) with a remote wire in the harness. So I didn't need to bother with the signal sensing setting.
    I'd probably tap the fuse box in the trunk for remote turn-on wire.
  26. #66
    May 06 2014
    Las Vegas, NV
    Yes, exactly. The TW subs...
  27. #67
    Nov 08 2013
    Houston, TX
    Completely agree.
  28. #68
    Nov 08 2013
    Houston, TX
    Those TW's that are 3.25" deep could maybe fit but getting the airspace they need doesn't look promising with keeping the stock amp where it is. It would be an entirely different shape of a box too. I don't think I have the energy or time to fabricate something for it. Sorry bud
  29. #69
    Nov 08 2013
    Houston, TX
    On another note, made good progress today pullin' double duty! Layers and layers. I'm exhausted.
  30. #70
    Aug 30 2009
    Fredericksburg, VA
    coming along nicely!
  31. #71
    Veteran Member Four Rings QuattroRocket's Avatar
    Sep 01 2004
    2103 S4, 2014 Nissan Pathfinder
    Vancouver Canada
    Does that special project have to do with the other side of the trunk ?
    Great work ! I would be down for a prefab setup to save me paying someone to build from scratch once you have a mold to "pop em out" from !
    Gone but not forgotten : 2000 A4, 2002 A4, 2004 A4, 2013 S4 Premium, 2013 Q7, 2017 SQ5 Dynamic Edition
    Current Audi : 2017 RS7
  32. #72
    May 06 2014
    Las Vegas, NV
    Lol... Bummer.
  33. #73
    Nov 08 2013
    Houston, TX
    Quote Originally Posted by k9lovr View Post
    Quote Originally Posted by QuattroRocket View Post
    Haha you guessed it!! I popped the plugs out of the molds today and will be prepping their surfaces throughout the week. You are welcome to get in line
    Lol... Bummer.
    Don't fret. You still have options.
  34. #74
    Nov 08 2013
    Houston, TX
    And now for more updates!!
    As QuattroRocket so cleverly discerned, the other project I was working on was a box for the right side. Last night I finished up the layers of reinforcement for both molds and today I couldn't resist staying home to pop 'em open!
    I started with the left side box. Turns out I neglected to build s flange into the plug so this was a doozie. First I popped it from the platform I used as a flat surface.
    Then I realized I didn't have any leverage to pop it out so I tried to get creative
    That was useless so I tried again. The idea was to brace with my feet and pull and hammer. Exhausting and completely unsuccessful.
    Finally I ran to Home Depot, got some large screws, put the original platform back, and was able to use my wedge and get her open!!
    Success!!
    I will not lie I got a giddie when I finally got her open. I trimmed the flashing and was on to the other mold.
    Then it was time for the other one. Of course I ran into the same issue of not having a flange for leverage, so again with the pulling and prodding. Finally I got this one as well.
    So today was a fun one. A lot of work to get to this point and I can say it felt good to see my molds that I've spent literally the last 5 or 6 weekendstooling over from early morning to sunset finally in the form of an official mold. So here they are in all their glory!
    Now I finally get to spend some time inside prepping the tooling surface. This is has been a very fun learning experience. I've improved my fiberglassing technique and learned how to and successfully made a mold!! So close to having my speaker back in car with the look I was going for the first time
  35. #75
    Sep 01 2004
    Vancouver Canada
    Whats the interior volume looking like ?
  36. #76
    Apr 29 2013
    Arizona
    Nice job Mr. S! Definite round of applause earned. And I particularly liked the final boudoir photo of the cubby twins.
    Obviously a lot of time and effort from you on this project, well done.
  37. #77
    Jan 04 2013
    Phoenix, az
    Well done, and both sides!
  38. #78
    May 06 2014
    Las Vegas, NV
    I want the right side one!!!!! Volume please???? Lol
  39. #79
    Jun 10 2013
    Miami, FL.
    i'd like a right side one too if this project comes to fruition.
  40. #80
    Nov 08 2013
    Houston, TX
    Since a fabricated box will differ from the mold, I can't quite quote exact volume. The right box will spec out for a JL 8w3 though and the left for a 10w3 or w6.
    Thank you very much! The acknowledgement actually means a lot. Though exhausted, I'm excited to actually make a box using the mold. Should be fun and hopefully worth it. Who knew so much time and effort went into these things. A finished box is within reach!
    Yea buddy! Thank you very much
    This makes me happy. I'll let you know what the final volume is once I've made a box using the mold.
    I would hate to disappoint you so I will work on the fruiting lol
    Really appreciate the acknowledge folks. Between the research and fabricating I'm sure there are several hundred hours between these two and the work only continues as I make sure the result is worth it. I've got some plans for my box that if executed correctly should be pretty sick so I'll keep pushing to the finish line!
    Next Steps: Prep the mold surfaces, fine tune the shapes for the face/baffle, make a box.
    Cheers!
