Page 14 of 14 FirstFirst ... 4121314
Results 521 to 554 of 554
  1. #521
    Jun 30 2009
    Washington DC
    How are you guys reconnect the trunk latch cable. That one task took my like 45mins to do.
    Camera looks great and the trigger for the manual works perfectly. Very fast transition to camera. Guidelines aren't working though, anyone have any idea why that might be?
    Module switch is currently up up down down
  2. #522
    Senior Member Four Rings Party_Marty's Avatar
    Nov 02 2015
    Sector 9 Long-board, Rugby Kit
    Manchester MD
    Quote Originally Posted by pkny View Post
    How are you guys reconnect the hood latch cable. That one task took my like 45mins to do.
    try flipping the tabs and messing around with it. I would contact the seller about that.
    As far as the wire (I'm guessing you mean trunk latch....) get a pair of long reach pliers. I can have my trunk lid apart and back together in less than 15 min now.
    ---------------------------------------------------------- IG: party_martyy ----------------------------------------------------------------------
    ---------------------14' Phantom Black Pearl Stg2 A4 S-Line -- 6MT -------------- Peep the Build ---------------------
  3. #523
    Jun 30 2009
    Washington DC
    Yes, trunk latch.
    What dip switch settings do you have for your manual?
    We had quite a bit of rain today and i noticed the lens didn't really have a hydrophobic coating over it. Droplets basically blocked most of the cameras view. I don't recall the avant OEM backup camera having this problem with droplets. Going to wipe down the lens with some rainx and see if that helps.
  4. #524
    Apr 23 2015
    Tallinn
    Let us know if you get guidelines moving.. my'n does not move either :)
  5. #525
    Sep 20 2010
    Denver
    Has anyone upgraded the OEM backup camera to something with a higher resolution or better low light sensitivity?
  6. #526
    Jun 19 2016
    Moncton, Canada
    Hi All, got a kit from Eron a few weeks ago and got around to installing it yesterday. Took about half a day, with little trouble. Couple of points for whoever the next guy is:
    1. Don't worry about the extra wires (red, yellow and black) on the power side, they are for the forward camera and not needed for the backup camera
    2. The trunk latch has two little clips on the side, it will not come out until you push them in. Took me forever to find them and I do see that others mentioned them, i guess reading fail on my part.
    2.b: I found it easier to remove the gray metal band, it's two extra bolts, but it makes it easy to see the latch.
    3. If following this video: https://youtu.be/l8w59PEDF3g, on my car (a lowly Canadian "premium") I had two or three empty fuse slots at the top. I only needed to slide the included power line into the right side (when looking from the back), since the left side already had the factory power connected. Then I only needed to add the fuse, and it works, and looks clean.
    4. I was pretty nervous cutting the black & white wire for the reverse light (mine is a manual), but it really was the correct wire, spliced in the reverse signal and everything works fine.
    Overall it's a great product, Eron is very accommodating and I would recommend it, great price.
  7. #527
    Active Member One Ring AlphaMale_DD's Avatar
    May 28 2015
    The Netherlands
    I got my 50/50 OEM rear view camera finally installed. I'm using the OEM camera, but with a Dietz 1110 interface (similar to the Xcarlink version). This allows me to switch inputs with the NAV button as it's connected via LVDS between MMI (2G) and dash screen. I've split the camera's output to the rear cam input and video input 1, so I can monitor the rear when driving (if I want to).
    I decided to use an aftermarket interface with multiple in- and outputs as I'm planning to hook up the front dashcam's CVBS output as well and use the setup for continuous recording (after adding a hdd recorder). Should be cheaper than a dual cam dashcam of decent quality, using already existing cameras and wiring.
    BTW, I had to use a step-up voltage regulator for the rear signal feed as the car's PWM is messing up the 12V trigger.
    A4 B8 Avant | Deep Sea Blue Pearl | Stage 1 | Vogtland Coilovers | Mandrus Millenium Black 19" + Michelin PS3 235-255 | ... some small bits 'n pieces and some coding
    Retrofit: S-Line FL rear bumper | Single L+R exhaust 2x90mm | S-line interior | S-line side skirts | FL LEDs rear | PDC + backup camera
  8. #528
    Mar 07 2015
    i've had this kit installed for a while now and it works great. However, when the camera comes on the screen goes to full brightness. How do i lower it?
  9. #529
    Veteran Member Three Rings ducati's Avatar
    Sep 02 2008
    Greater Toronto Area
    Eron is the best for backup camera.
  10. #530
    Feb 08 2017
    Denver,CO
    Quote Originally Posted by ducati View Post
    Anyone has Eron e-mail I have a question for him.I think the module is starting to go....
    zerone.wu@foxmail.com
  11. #531
    Established Member Two Rings blew-dub's Avatar
    May 18 2017
    FL
    Quote Originally Posted by ports View Post
    I would like to know as well.
  12. #532
    Sep 26 2013
    San Jose
    Good info here, can't believe I read most of this 14 page thread. Not surprised I came to the conclusion I suspected on page 1, never buy a knockoff.
    2012 Stronic | Sports Diff Pkg
    SOLD 2010 B8 A4 Tiptronic | Stasis Engine Tune | Michelin Pilot Super Sports | Forgestar F14 18x9 wheels | Stoptech Powerslot rotors | EBC yellowstuff pads | Bilstein PSS10 - SOLD | aFe Pro Dry Filter
    Me @ Laguna Seca Raceway - https://www.youtube.com/watch?v=z7s8S1Uh7uc
  13. #533
    Mar 22 2004
    NorCal
    Yep, good info here. I'm reporting back that my Eron camera has been operational with no issues for 20 months.
    I disagree with audiAYYY4's conclusion. My Eron camera is actually better than my 2010 S4 OEM backup camera. I was quite surprised. Erons camera is brighter, clearer and higher resolution.
  14. #534
    Senior Member Three Rings Antimatter's Avatar
    Jun 28 2016
    MA
    Would like to know this as well. There has to be a way to upgrade the OEM Camera.
    2011 Audi S4 Brilliant Black / Black-Tuscan Brown Interior. DSG, Navigation, Sports Rear Differential, Nappa Leather, Supercharged Badge. Borla Exhaust System.
  15. #535
    Aug 19 2016
    valencia/CA/USA
    I retrofitted factory oem camera on mine. 09 A4
    Overall difficulty 6/10. Not super hard - time consuming took around 6 hours to fully complete. I am ocd about factory. I unwrapped all the tesa tape, installed connections, camera routed all wires in factory loom. Re taped everything with new tesa tape. Would never be able to tell the difference between my install and factory. The parts I got for a bargain. I was able to get camera/handle, wiring and camera mount for free. I paid $100 for camera controller module. I read the forums for coding. Pretty simple. I had already converted Audi concert to 3g+ so everything was perfect. Guide lines are awesome and are calibrated perfectly already. Work was time consuming but works great!! Totally worth it for any DIY guy.
  16. #536
    Apr 14 2017
    Nicosia Cyprus
    To Zerone Wu and to other B8 owners with APS+ with graphical display parking distance control unit and radio concert (I call it mmi basic most sellers call it non mmi)
    Still waiting for a reply.
    Why does your RS-1103 radio concert (non mmi) camera interface does not display radar distance on B8 with APS+ (advanced pdc with graphical display,)???
    Since it is advertised as radar distance capable why doesnt this function work with all B8 (A,4 A5 Q5) made in 2009-2012 to display graphically the proximity radar??
    Why your firmware cannot decode radar signals.
    Also why is your interface not recognised by audi gateway??
    My problem with radar functionality was never resolved.
    What I have not tried yet is to connect directly can-h can-l from HVAC cable harness, cut cables from this harness to cancel and connect canh-l small black plug directly to APS respective cables. (need long cables to test this)
  17. #537
    Senior Member Three Rings kayroccs's Avatar
    Jul 13 2015
    New York
    Hi everyone,
    Is this camera compatible with a Premium Trim?
  18. #538
    Dec 04 2006
    Los Angeles, CA
    Installed the rear camera from Eron - 09 A4 non-mmi
    -it is basically a plug and play system.
    -the only time consuming part is taking apart the glove box (about 10 screws) and trim pieces to get at everything.
    -the actual install is quite literally plugging in and tieing up a couple wires
    -non mmi cars-
    no need to take out radio. Pull the trim plate around the screen, pull the bottom hvac unit (trim tools do the job), route wires and plug everything in.
    -swap in the camera latch
    -route the video cable to the front
    -tie in your camera power wire to the purple wire at the control box
    -done
    -PROBLEMS
    -I had an issue where it tested fine, but no picture when I tried to install.
    -Eron was very responsive in helping to troubleshoot
    -It turned out to be a faulty Video cable, which I tested with another one, and works perfectly.
    I bought the unit many months ago, but due to work travel, only got around to installing it now.
    The picture is very clear and the guide lines move wiht the steering wheel, which is nice too.
    All in all, a great addition for not a lot of money. No unnecessary splicing of wires, and if I want to go back to stock, simple plug n play.
    It is time consuming only because of removal of trim pieces. Not difficult, just be patient.
    B8 2.0T QTip
    B6 3.0 QTip Avant
  19. #539
    Veteran Member Four Rings SleeperCar's Avatar
    Jan 03 2012
    Owings Mills, Maryland
    Quote Originally Posted by AudiTLC View Post
    -non mmi cars-
    -done
    -PROBLEMS
    Where did you route the wire from the back to the front specifically?
    2013 A4 Scuba Blue Metallic | APR stage 2 | AWE | Milltek | GFB+ | Suntek | Solo-Werks | Eurocode | Blesk | 034 | ECStuning | CR-15 Strut brace | Apikol | R8 Coilpacks | NGK | Akebono | Hawk |MRR-GF07 19x9.5 ET38 | 18x8.5 peeler reps ET 40 (winter)
  20. #540
    Dec 04 2006
    Los Angeles, CA
    Quote Originally Posted by SleeperCar View Post
    passenger side- I went down the trunk, to the arm (plastic trim pops off, follow other wires) into the trunk(pop open the storage box to access), and the back seat bolster can pop out to give room to route wire
    then down the kick panels to the front, and up into the side. Pretty easy.
    I didnt have to pop off any trim really, just flex it up to tuck the wire.
    Forgot to mention: NO NEED TO TAP A FUSE OR POWER. It is literally a plug n play.
    B8 2.0T QTip
    B6 3.0 QTip Avant
  21. #541
    Dec 10 2017
    Hey AudiTLC,
    I'm about to attempt this tomorrow. I think I also have the kit that does not require tapping a fuse.
    Did you follow the instructions included by Eron exactly?
    I'm a bit unclear on how power gets to the camera. My understanding is this:
    1. At the back of the car, I connect the stubby red wire (coming off the RCA cable) to the red wire on the power cable coming off the same camera harness.
    2. At the front of the car I connect the red stubby wire coming off the other (front of car) end of the RCA cable to the purple wire coming off the module harness.
    What I don't understand is, how does power get from the front of the car to the camera? Does it run in the same sheath as the RCA cable? Am I missing a step?
    And what is the purpose of the black wire coming off the power cable near the camera?
    Thanks in advance,
    NewD
  22. #542
    Jan 21 2018
    Turin
    Hello, I just tried to install the rs-1102 module for Mmi 3g high. I don't have the instructions but I manage to mount the rear camera and the power with can hi low cable. The only problem I have is that I don't understand how the cables are connected to the Mmi unit, module and screen. Please someone explain to me how to connect them. For now the module has a flashing red led and it clicks when I put it in and out Reverse gear that because I have manual transmission and connected the trigger cable . on the screen I see only the oem image with parking sensors like before. Please explain to me how to proper install the Mmi and module cables because I don't want to brick the module or the mmi. Thank you in advance.
  23. #543
    Jan 21 2018
    Turin
    I just figured out what was the incorrect wiring. I still have one noob question : why it works only in reverse? When I put the shifter in neutral or first gear the camera shuts down and on the screen I see the original parking sensors only. It is normal? Also why on the the camera I don't see red lines of parking sensors, I hear only the sound.
  24. #544
    Oct 21 2012
    Earth...
    Quote Originally Posted by CarlosFibra View Post
    Because it is audi logic and many places call this camera also as reverse camera(as it is part of the parking system). Read your car owners manual, there is nice info about parking systems. It is possible to override this, but it is not only coding change!
    And what is reason you need or want rear camera picture if you are in D mode?
    Retrofits: FL taillights / MMI 3G & 3G+/ Color Cluster & FL S5 Cluster/ BiXenon/ ADS Lite
    Other: ECU Tune/ VCDS Tweaks/ FL Gearknob/ Soundproofing/ Interior 6D Carbon Wrap/ Rieger Rep Front Bumper Valance/ Basic sound(8) upgrade to "ASS"(9+1) + B/O Tweeters + Activsub/ Efficiency Prog via Cluster & Gateway flash/ Sideskirts/ Window Tint/ Wsp Peeler reps/ License plate & Interior leds
  25. #545
    Dec 04 2006
    Los Angeles, CA
    sorry for the delay, i just checked the forum today.
    The red power wire is imbedded within the RCA plug.
    So you just connect the yellow rca plugs and tie the red power wire at the camera and purple wire at the front.
    ignore the black wire- that is for tapping the rear light for manual transmission I think.
    The rest is plug and play
    You can hide the unit in the dash next to screen and not even route into the glove box
    I routed it to the glovebox by popping out the glove box light and bringing the wires in.
    I just wanted it easier to troubleshoot, in case I needed to. (I havent)
    The picture quality is really good. and the guide lines move with the steering wheel.
    Great addition to the car!
    Quote Originally Posted by NewDirection View Post
    Hey AudiTLC,
    Thanks in advance,
    NewD
    B8 2.0T QTip
    B6 3.0 QTip Avant
  26. #546
    Feb 18 2009
    I have a 16 with Nav (MMI) and and started to install the kit form ERON.
    How does the the LCD get the signal ? the instructions are unclear and there isn't a harness that plugs into the back of the LCD.
    Edit - Ive tried contacting ERON and no answer
  27. #547
    Mar 22 2004
    NorCal
    You can look at the harness here: https://youtu.be/TlAjnSj18iw?t=6m3s
    You plug the cable that goes into the LCD into this harness and then the harness into the back of the LCD. The other, third connector connects to the control unit.
    Make sense?
    B5 A4 -> B8 A4 -> B8 S4
  28. #548
    Active Member Two Rings Silverknife's Avatar
    Jun 17 2015
    Audi A4, BMW 320i
    Quote Originally Posted by kayroccs View Post
    Hi everyone,
    https://www.carsgadget.com/ This online store in USA has backup cameras for all Audi models. Great quality and customer support. It's beed 2 years since i installed their system, still works great.
  29. #549
    Jun 17 2015
    Audi A4, BMW 320i
    Quote Originally Posted by RKsilver View Post
    Have you figured it out?
  30. #550
    Apr 23 2015
    Tallinn
    Still no, sry.
  31. #551
    Jun 17 2015
    Audi A4, BMW 320i
    Still no, sry.
    You can ask this question to CARSGADGET customer support at info.carsgadget@gmail.com. They can guide you through the troubleshooting process. There are really nice guys up there, when i had some questions they responded super fast to me.
  32. #552
    Aug 28 2017
    Minnesota
    Got my kit installed today and I am very satisfied. Total installation was around 3.5 hours. Picture quality is great and Eron was very helpful and fast with shipping and responses. I was a bit worried having to splice the trigger wire because my car is a manual but it turned out great.
  33. #553
    Dec 04 2006
    Los Angeles, CA
    Mine died within a month or so of install.
    Eron said to send it back- but just didnt have time until recently but no response from him
    It would be nice to have the backup cam, miss it now that it doesnt work...
    B8 2.0T QTip
    B6 3.0 QTip Avant
  34. #554
    Jan 21 2018
    Turin
    I have just changed the rear camera because after a month or so it stopped working (black screen). My advice is to be careful when washing your car because this cheap rear cameras (chinese not oem) are not so water resistant as the manufacturer declares.
