Originally Posted by
EmmanueleDesign
It says right on the product description:
It is a plug and play box that intercepts at the MAP and Boost sensors
Features:
Two position switch:
91+ Premium Fuel / 5 PSI Increase
100+ Octane Fuel / 7 PSI Increase
Wow, that is an unbelievably hack approach to "tuning" a car that I haven't seen done since my RX7 days. Piggybacks and any other device that does nothing but feed garbage data to the ECU are complete jokes, and a great way to blow up an engine. Any one who puts one of these on their $50,000 car because they don't want to lose their warranty is in for a rude awakening.
ModdedEuros
These do raise the boost and are another option than an ECU tune. Remember an ECU tune on any of these cars could put you in trouble with the warranty with TD1. This is why Neuspeed is doing well with the modules. Its another option to get a few extra horsepower out of the car while not voiding anything. This method of tuning is not new and has been done on various platforms for years. Just not going to get the maximum amount of horsepower out of a car.
No offense, but I would personally have a problem with supporting a vendor that pushes and sells such a hack product.
Hspecialist
An ecu tune increases boost too. This piggy reminds me of the "diode mod" most used in the b6 a4 world. I had wished I would have done that vs. my APR stage 1+. The more I read and research my opinion is less is more with this platform. I just wonder how easy the boost sensor is seen and accessed, haven't looked for that while under the hood. Their site shows arm length and I can't remove the pan easily.
Yes an ECU flash increases boost, but also modifies all other parameters to accommodate the increase - target AFR, timing, IAT safe guards, etc.
Bottom line - you have to pay to play. If you're that afraid of getting flagged, don't tune your car. Taking a shortcut like installing this device will do more harm than good.
