Ok - maybe old guy or someone that's done this can steer me here -
problem: 2003 A4 B6 1.8t no fuel pressure at rail, I need to know if all the sockets are powering correctly at the relay, so I can isolate it to a possible bad new relay
- New OEM Fuel Pump, New OEM fuel Filter
- New Fuel Relay from auto zone " 167" relay diagram looks correct - 1 large vertical blade (87) , 1 large horiz blades ( 30) 1 middle blade (86) 1 small blade (85) at top
- No power at Pump plug
- No power at fuse
- Pump runs when "hot wired" directly from 12v source and auto ground
- No codes in vagcom
I searched and read an old thread and checked the Fuel pump relay socket, there is 12 V at the Horiz, indicating good 12v from ecu - in the older thread old guy says to check the lower horiz for control voltage but there are no connection to the lower sockets - there is 12 v at the top horiz medium socket - it looks like the really isn't working as the input voltages are there ebut the output to the fuse is not, but I'm sure I'm checking it correctly
thanks
