Results 1 to 11 of 11
    Active Member Two Rings RandyL's Avatar
    Oct 26 2014
    Yakima, WA
    Vibration when backing up
    Ever since picking up my S4 with 8,000 miles on it (Certified Pre-Owned) I have felt a vibration when backing out of a parking place and turning, which we all do most of the time. I've assumed it was one of the differentials or diff clutches or something and just haven't taken the time to take it back to the dealer to check on it. Anyone else get this, and is it normal?
    2015 S5 manual Ibis White w/black | Premium Plus package | Black Optics package | Nappa | Carbon Atlas inlays
    Veteran Member Three Rings Mr.Tan's Avatar
    Sep 02 2014
    '01 GTI
    York, PA
    does it also do it when making sharp/slow turns going forward? if so, its normal... it has something to do with the way the awd is on the audi... i questioned it too when i first got mine (made a thread here) and asked my buddy who works service at the audi dealership and he explained it to me.
    if it bothers you enough, make an appointment. I have a feeling that is all it is tho
    Veteran Member Four Rings Dr GP's Avatar
    Jun 08 2005
    Lexus RX 350
    SE, PA
    This is a very common question asked by many owners who are not familiar driving AWD cars and it is perfectly normal. When you turn a car at low speeds , the wheels/tires on the inside of the car have a different turning radius than those on the right side. With AWD it is difficult for the AWD system to compensate for this difference at slow speeds. What you are feeling is the Quattro system and the tires on the car compensating for the difference in the radii. Happens on my AWD Mountaineer as well.
    Oct 14 2012
    Empty...for now...
    SE PA
    How far do you have the steering wheel turned when you notice the vibration? I have noticed this on both my old B8 and my B8.5 but in both cases only when the wheel is turned farther than half way to full lock.
    SOLD 2015 Daytona Gray S4
    Oct 26 2014
    Yakima, WA
    Quote Originally Posted by SteveYem View Post
    I only feel the vibration when turning nearly full lock, and it does it both going forward and backward though I think it might be more pronounced when in reverse.
    Sounds like this is likely normal then?
    Veteran Member Four Rings MVR 155's Avatar
    Apr 04 2013
    2018 Audi S6, 2015 GMC Yukon Denali and 2002 Corvette Z06
    Bartlett, IL
    Completely normal for sharp, low speed maneuvers..... nothing to worry about as the others have stated.
    2018 S6 Prestige, Glacier White/Black, S-Sport, Driver Assistance, Black optic, Carbon inlays, Cold weather, Vorsteiner VFF 103's in carbon graphite.
    2002 Corvette Z06
    Dec 07 2014
    Mn
    I've noticed that my 2014 tends to struggle in reverse while going up a slight incline (backing up my drive way into my garage). It's almost like it has trouble transferring the power to the front with the majority of the weight on the front end.
    I know, it's not a vibration, but I didn't want to get yelled at for starting a whole new thread. Any one else experience this?
    Veteran Member Four Rings amz's Avatar
    Apr 29 2013
    Ottawa
    The low-speed vibration, is it the tires scrubbing the pavement, or the traction control system trying to transfer power, or something else?
    2012 S4 ~ Phantom Black - Mustang Brown - B&O - Sport Diff - DSG
    AWE Touring Exhaust | Roc Euro Intake | Eurocode Alu-Kruez | Eurocode USS Swaybars & Solid End Links
    Canada: the land of Quattro
    Feb 25 2013
    MI
    Quote Originally Posted by amz View Post
    The center diff is torque equalizing, not speed equalizing. The issue is the front wheels spin at different speeds than the rear (technically every wheel spins at different rating during low speed full turning, but each axle has a differential - front is open, rear is open or sports diff). You are feeling tire scrub as the effect of the center diff attempting to speed up one axle faster than it wants.
    Apr 29 2013
    Ottawa
    Quote Originally Posted by drob23 View Post
    The center diff is torque equalizing, not speed, the issue is the front wheels spin at different speeds than the rear (technically every wheel spins different at low speed near full lock turning, but each axle has a differential- front is open, rear is open or sports diff). You are feeling tire scrub as the effect of the center diff attempting to speed up one axle faster than it wants.
    Thanks for the answer! I had the same scrub on my 2011 A4 as I do on my 2012 S4 w/ sports diff, so that makes sense. It's the same center diff.
    Oct 29 2007
    So. California
    I miss this... I need Quattro back badly.
