I posted this on AudiSport but i thought i should do it here as well.
Id like to use this thread to start documenting different setups and finding out which setup works best.
Some people like slammed and tucked, while others care more about drivability and maintaing almost close to stock setups. My predicament is that I lean more towards the stance , i want a lil poke,, but i, more of a coilover/handling guy and still need the ability to tear up the mountain roads aggressively. On my previous car i ran an aggressive setup with wide wheels, and although it looked good, it killed the drive. This time around id like to find that happy medium between stance and driveability
This thread isnt about personal preference, and i hope it doesn't get derailed because of that and/or Mono.Pur . The outcome of this thread is to document different setups and find out
the most aggressive setup you can run without any fender mods,
which setups required fender rolling,
and what setups work for slammed/stanced look.
it also seems like the sedan s3 can run a more aggressive setup than the hatch
Issues with rear wheels hitting struts on wider wheels. (has anyone succesfuly run a 10.5?)
Oil pan issues on lowered cars similar to the 8P guys.
If your interested in posting your setups, please provide wheels specs tire sizes, suspensions mods, fender mods etc.
So far, Rabbit222's car is running the most aggressive setup (that ive come a cross) on this site.
His specs:
20x8.5+40 plus a 10mm spacer
235/3520 tire size.
No fender mods, no rubbing.
I think his car is one of the nicest S3's out there. There are more aggressive setups out there, but the Ch-R titanium wheels on sepang blue S3 go unbelievably well together that. Plus i understood that this setup has no rubbing issues and maintains driveability. Win.
Now out in the land of the rising sun, probably one of the first modified S3's and the only true "aggressive" setup out there.
19x8.5+32 plus a 5mm spacer
19x10+36
tires:225/35/19 and 245/35/19
NEX Coilovers SS-type
Modified rear fender
This set up is super aggressive and not for the faint of heart. Those rear fenders were pulled out 15mm to accommodate the larger wheels. I think this looks bad ass. definitely an aggressive setup.
Another Setup in Japan that has me going nuts is this one. unfortunately i couldnt find the exact specs but the setup seems similar to Rabit222's setup.
20x8.5
KW V3 cols
